#16 |
Drives: 2013 FR-S whiteout
http://www.ft86club.com/forums/showthread.php?t=39769
I don't know anything about the SRT exhaust, but it's a bolt-in deal, right? |
#17 |
SLO NO MO
Wait, what? Why would you weld headers on to your block? And I also see that you've welded your SRT exhaust in place, welded on to what?
#18 |
Drives: GT86
Da fuq did i just read
| The Following 4 Users Say Thank You to JiB For This Useful Post: |
#19 |
Drives: frs
#20 | |
Grip>Slip
This is a photo of a Cosworth F1 engine. Take note of how the header (exhaust manifold) is bolted to the block. If it's good enough for F1, it's good enough for your 86. ![]() Bolt them on. Your factory headers are bolted on and are fine, the FA20Club header will be the same. Put new gaskets on and you should be golden. You could probably even reuse the OEM gasket, but as cheap as they are, i'd put new ones on the first time. |
| The Following User Says Thank You to xjohnx For This Useful Post: | Frsexxxy (06-26-2013) |
#21 |
You couldn't weld them onto the block even if you wanted to, as the block consists of aluminum and the header consists of steel.
| The Following User Says Thank You to rx3 For This Useful Post: | DylanFRS (06-26-2013) |
#22 |
Add lightness!
Drives: 17' WRX
Is this code for butt sex? Can't keep up with the lingo.
| The Following 3 Users Say Thank You to industrial For This Useful Post: |
#23 |
That guy
Drives: Ultramarine mt FR-S
Ohh baby.. I want to weld my header to your exhaust port!
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
#24 |
#25 |
I welded a turbo to a manifold before. I'm not proud of it but it happened. 16g CRV
#26 |
AKA Mugen Dom
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
The OP may mean did you weld you header to the overpipe
#27 |
Drives: White Virgin frs
#28 |
Drives: 2013 FRS
If you buy a quality header and use new quality gaskets you shouldn't need to weld them. You can weld aluminum to steel but the process isn't easy.
| Tags |
| gloriously dipspastic |
| Pinch weld jack point paint damage? | Ingen | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 37 | 10-12-2015 09:43 AM |
| Weld Drag Rims | JerryMichaels7 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 06-12-2014 09:24 AM |
| Headers | cuddefred | AUSTRALIA | 4 | 05-25-2013 07:16 PM |
| protecting the pinch weld lifting points | midnitz | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-08-2013 10:36 PM |
| All it needed was some JB Weld... | 82mm 4g63 | Other Vehicles & General Automotive Discussions | 2 | 09-15-2011 09:12 PM |
