#15 |
Driveway labs.
Drives: '13 BRZ Limited, 6sp, SWP
First off, I'm not a Subaru guy. Don't really care what they came off, just know they go on my brz. And, I can't figure out how to change the thread title.
Fronts: went on perfect, no adapters or cutting or anything. Rears: need adapters and the wrx rotors won't work due to our ebrake system being huge in comparison. They bite hard in comparison to stock, which may be attributed to the ebc red pads and ebc rotors. The loss in weight is well worth the money since these are much cheaper than the aftermarket bbk's. I also get a woody having "Subaru" brakes instead of some other brand, I think it just looks cooler.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list) -'13 Town and Country Limited (Mods: too many kids) |
#16 |
Drives: 2013 FR-S whiteout
#17 | |
Drives: Attitude
The adapter part is correct...but you should be able to use your OEM rear rotor. Pre-08 (non STI) parking brake diameter: 170mm STI and all 08+ parking brake diameter: 190mm Centric part numbers and diagrams below. 06-07 WRX rear rotor: ![]() 13 BRZ rear rotor (high-spec):
#18 |
Driveway labs.
#19 | |
Driveway labs.
#20 | |
Drives: Attitude
This bracket should work; if it doesn't call Ken. I know that you need to modify something very slightly or at least you had to in early versions. EDIT: Install PDF http://knsbrakes.com/RearBremboV2ALL.php |
#21 |
Drives: 2013 Subaru BRZ
Did you not have to change anything with the fluid lines on the front? I know on the wrx the calipers sit on the back side if the rotor where ours sit on the front.
I've been looking into doing this upgrade for the front for awhile now but I'm waiting for a good deal to pop up for some used calipers.
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=43355 |
#22 | |
- andy |
#23 |
#24 | |
Drives: 2013 BRZ SWP 6AT Ltd
I didn't know that the WRX version calipers are aluminum and was under the impression they were all cast steel. And to clarify you can get the Black version with a flat Subaru sticker now like mine. The older JDM versions did have raised lettering. |
#25 |
Drives: 2006 STi
so much want
#26 | |
Drives: Attitude
Also, I'm looking to get the black version, but I'm not having luck. You got a P/N or are they still a JDM item? If they still a JDM item, got a JParts P/N? |
#27 |
Driveway labs.
Correct! No changes to lines, although, I highly recommend braided steel lines with these.
#28 | |
I got em from sgp - http://www.subarugenuineparts.com/pr...cb7e31499676cd I'm with you on the 300Z brakes. I just tested my buddies 300z calipers on his 240 and they are aluminum. But I'd really like confirm on the fronts as a 2lb difference between steel and aluminum doesn't seem possible. |
| Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling | Hachiroku | BRZ Photos, Videos, Wallpapers, Gallery Forum | 113 | 11-21-2020 01:02 PM |
| Subaru BRZ - RAW Subaru | Official Subaru Australia Ad | Hachiroku | BRZ Photos, Videos, Wallpapers, Gallery Forum | 15 | 07-20-2012 08:20 AM |
| Subaru BRZ vinyl wrapped MATTE WHITE , Showing @ Subaru Summer Solstice 2012 | Premium Auto Styling | Southern California | 2 | 06-22-2012 07:34 PM |
| Subaru/Toyota Coupe spotted in Socal with Subaru Plates | owsiu | Scion FR-S / Toyota 86 GT86 General Forum | 150 | 05-25-2011 10:27 PM |
| Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show | C-Bone | BRZ First-Gen (2012+) — General Topics | 39 | 03-24-2011 09:22 AM |
