Old 07-04-2013, 03:07 PM   #15
Fabron757
Drives: 2013 blue frs m6 BW EFR 7064 Turbo
Originally Posted by FAER View Post
That's exactly where I want that turbo power in the 4.5k and beyond....
No boost for daily driving but enough to nail your ass to the seat when u press the pedal...
Btw I'll be ripping off your inter cooler design in the future, it's the best I've seen.
Thanks it has shortest distance from turbo to the engine, so the least amount of piping. I drive mine to work everyday. And getting 23-25mpg on e85 @360hp and 310tq. My car pulls hard up top in the power band.
Fabron757 is offline   Reply With Quote
Old 07-06-2013, 11:49 AM   #16
FA20Club.com
Drives: 2013 White Out FR-S
honestly i wouldnt be surprised if this motor spools better than the srt4. i used to work on allot of them and that 8.8:1 cr sucked balls for spool. the air flow in the heads was sub par as well. compared to where the imports were at in 03-05 years when the srt4 was at its peak. heads and CR make a major difference on low hp builds than anything else when it comes to spool.
FA20Club.com is offline   Reply With Quote
Old 07-06-2013, 12:55 PM   #17
Ross
Drives: 85 corolla gts
I would actually love to see this used with the divided housing and a quick spool valve. but on pump gas the exhaust housing you are using should work well. If you have plans for more flow later e85 / built motor then you may want to look at a little bit larger exhaust housing. I love that people are looking into a bit larger turbos now as I personally feel they work great for a daily car. I would really like to install one of the FA20 clubs kits to see how they are first hand with a 60 trim or there 3071 or 3076 options. For an off the shelf kit I am really digging it and glad a manufacturer brought a larger turbo option to the table with a budget in mind (this in no way means to down talk or speak poorly towards other kit manufacturers as I like the design of most of the kits offered for different reasons).
Ross is offline   Reply With Quote
Old 07-06-2013, 01:03 PM   #18
FA20Club.com
thanks @Ross
Old 07-06-2013, 01:07 PM   #19
ft_sjo
Drives: GT86
I don't think that's a good argument. I can build 2 litre engines which are at 1.5 bar boost by 2500 rpm and go on to make over 300bhp. With a compression ratio of ~7.5:1.
Old 07-08-2013, 04:00 AM   #20
FAER
Drives: Silver BRZ
This gives me high hopes for my kit! I loved my srt but fwd was so limiting and a 245 was the widest you could go, no to mention eating input shafts and transmission gears, glad i was able to move on...
I'm hoping with the help of fa20club.com and a boat load of cash i can get back to where i was with the srt power wise. That sir would put a huge smile on my face and a tingling in my ball sack!
FAER is offline   Reply With Quote
Old 07-08-2013, 10:49 AM   #21
mid_life_crisis
Drives: FR-S 10 #103 AT
Too many guys are way too hung up on when the turbo becomes "spooled". All this means is that you have achieved full boost. You need to remember that with a large turbo you are stuffing more air per psi into the engine than you are with a smaller one, so at those lower rpms before you hit spooled state, that big turbo could easily be making enough power to meet your goals. That is what you really need to be concerned about: how much air is my turbo moving at xxxx rpm? There are lots of guys out there making big power in the upper rpms with no loss in driveability using turbos that at first glance might seem way too big. Of course there is a point where a turbo can get so large that the engine simply doesn't create enough exhaust pressure to properly spin it, so don't get carried away with the sizing either.
Old 09-01-2013, 02:54 PM   #22
FAER
Drives: Silver BRZ
waiting on delivery!
@FA20club
Old 09-01-2013, 05:07 PM   #23
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
How much is turbo location going to effect spool? Seems like ptuning is getting very good response from their 3076. I wonder how much of that is the rear/low location vs. say a fa20club header location.
I have a vband billet 3071 laying around but can't decide if it's too big for the car on low boost. 6psi seems stupid when I was running it at 27psi on my gti
Sent from my Galaxy Nexus using Tapatalk 4
cruizin01 is offline   Reply With Quote
Old 09-01-2013, 06:04 PM   #24
FAER
Drives: Silver BRZ
You could easily do 10-12 psi on 93 and almost 20 on e85
Old 09-01-2013, 06:41 PM   #25
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Hou could easily do 10-12 psi on 93 and almost 20 on e85
I guess I should specified. I'm not really looking to make more than 300whp. I already had a car that was overbuilt and made too much power. I want a fun car at hpde not a drag car.
Sorry to thread jack.
Old 09-01-2013, 11:00 PM   #26
mswhong
Just go bi-turbo, one small one big so you can have a nice, smooth and linear power dilvery :P
mswhong is offline   Reply With Quote
Old 09-02-2013, 12:34 AM   #27
FAER
Drives: Silver BRZ
10 psi would put you at 300-350 whp
Old 09-07-2013, 07:26 PM   #28
FAER
Drives: Silver BRZ
@FA20Club.com
Any update? My "tracking number says expected pick up date from you of September 3rd..
But... it has not been picked up yet as of the 7th
Borg Warner 8374 vs Garret GTX35R Z3D Forced Induction 5 02-27-2013 10:27 AM
FR-S work at Best Buy in Warner Robins Bg8780 Southeast 3 02-09-2013 02:29 PM
