Old 05-26-2013, 10:36 PM   #15
White64Goat
It works to do what? Reduce underhood heat? Why not just remove the rubber strip at the top of the firewall..............
Old 05-26-2013, 10:41 PM   #16
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Living in Japan, we used to do this back in high school with our cars. Just added washers. Didn't think they still did that. Brings back memories...
JimmyMac is offline   Reply With Quote
Old 05-26-2013, 11:23 PM   #17
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Yeah, something like that. Import Tuner did some testing of this phenomenon a while back. Here's the article and their thoughts:
http://www.importtuner.com/tech/impp...jdm_hood_prop/
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 05-26-2013, 11:37 PM   #18
Jhon19lopez
Drives: 2013 scion fr-s
Originally Posted by ahausheer View Post
I think certain Evo's had extremely poor under-hood heat management. Not so with the FR-S
Originally Posted by Dezoris View Post
CHAPTER 3: THE MARGINAL FR-S / BRZ FINAL REVIEW
This is the final review in this series. It will prepare the way for the next series which will take people through the process of installing testing and evaluating forced induction.
  • Street Review: Featuring Harry Cash (Comparing S2000 and FR-S)
  • Stock Dyno Test
  • Alignment
  • Safety Prep for Track
  • AutoX: Comparing the Driver Variable
  • Track Test: Gingerman Raceway
0:00 - 3:39 | Dynometer Test: Testing the FR-S on a dyno and issues we saw
3:40 - 9:37 | Test Drive: Comparing S2000 against the FR-S with Harry Cash
9:41 - 16:06 | Autox: Comparing Driver Variable (stock vs. modified)
16:07 - 27:14 | Track Prep: Preparing the FR-S for track use
27:15 - 35:56 | Track Test: At home but far from perfect
VIDEO:
Check out this video and learn about the frs heat problem
Jhon19lopez is offline   Reply With Quote
Old 05-27-2013, 01:05 AM   #19
ahausheer
Re-member
Drives: Toyota camry
Interesting video. There seem to be a fair amount of people that track their car while logging coolant and oil temps who have not had heat issues. Seems like these heat issues are more prevalent on a dyno. I think if you need hood spacers what you really need is an oil cooler and a larger radiator.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
The Following User Says Thank You to ahausheer For This Useful Post:
Tim_Asphalt_FRS (05-27-2013)
Old 05-27-2013, 02:21 AM   #20
Dezoris
Dezoris's Avatar
I've been testing now for a while well naturally aspirated and now supercharged the big thing is idle temps. For example if you are running hard on the street get stuck idling if your oil temps are high they continue to climb and never recover. Coolant temperatures also take a hit under idling. the coolant and condenser fan do not cycle on until 212 degrees which in cases of hard running and then Idle you can and will see temps hitting 217 to 220. Combine that with 230 to 250 degree oil temps and you start to see performance degradation.
Supercharging and turbocharging forget it. I would not even risk running the car without and bigger radiator and oil cooler. i had three full throttle runs in 3rd gear on the street data logging and my oil temps were alread at 240. Coolant was 205 with larger radiator.
And yes there is no place for heat to escape on the frs/brz. Bottom is sealed up, hood has weather stripping on the front and rear of hood and the front grill opening is quote small.
I will have plenty more details in my supercharging video.
Old 05-27-2013, 02:32 AM   #21
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
passwordjdm hood spacer? what's it cost? like $200? not trying to be a hater, but passwordjdm stuff is expensive!
Old 05-27-2013, 07:49 AM   #22
Jhon19lopez
I don't think they make them for the frs/brz that just a picture I pulled from google
Old 05-27-2013, 08:01 AM   #23
Jhon19lopez
Lets put it like this , some one who tracks there car in a hot state but doesn't have 1000+ to do oil cooler and radiator can simply go to a hardware store buy some washer and extended bolts and bam -10 to -15 degrees
WTB: Spacers abutterman Wheels and Tires 3 05-12-2013 07:11 PM
Spacers recomendation, please! kombatlion Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 04-25-2013 06:21 PM
30 mm spacers possible? Maps316 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-08-2013 05:14 AM
Looking for Hood Dampers meant for CF hood. Vicious LED Scion FR-S / Toyota 86 GT86 General Forum 3 12-31-2012 03:47 AM
H&R Wheel Spacers! vividracing Wheels and Tires 3 06-19-2012 06:11 PM
