Old 05-20-2013, 02:00 PM   #15
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Update,
I didn't sleep because I was working on this spoiler. I took a nap around 9:15am and woke up around 1:30pm. I'm off to Home Depot (wire for door lights) and Radioshack (side marker LED bulbs and resistor.)
@MyRx @Sonolin
@ everyone else
Under the shell is a lightly modified TT-01E. I would not recommend the RTR for two reasons. (1) The car is not desirable in its RTR state. You need to start from scratch to install the essential parts. (2) I honestly do not know what kind of transmitter you get. You end up spending less with your own setup than you would if you bought the RTR and switched stuff.
Essential upgrades:
- bearings (stock comes with these plastic bushings...what )
- aluminum drivshaft
I also have adjustable upper arms, but they aren't necessary. I do want some decent shocks though.
Load out:
- stock brushed motor (plenty for drifting)
- stock ESC
- Spektrum SR200 Receiver with a Dx2e transmitter
- Turnigy 3600mah 2S 30-40C discharge.
- HPI T-Drift Tires
Want:
- 4300kv-5000kv 4 pole Brushless 3650 Inrunner
- appropriate brushless ESC
- Real oil dampened shocks
- lower offset (which I think is actually higher offset in the RC world) wheels that match what I'll be putting on the real thing.
This will be my show build. It will only be driven if the ground is near free of debri (sand, rocks, parking stops, curbs...etc). I had to cut my old body to get the spoiler off, but I'll patch that up to the best of my abilities. The original plan was to use that one as a beater.
The problem is that Tamiya is so generous, they provide the bodies with the mounting holes already cut/drilled out. Oh well though. I'll be velcroing it.
The Following 2 Users Say Thank You to boredom.is.me For This Useful Post:
MyRx (05-20-2013), Sonolin (05-20-2013)
Old 05-20-2013, 06:20 PM   #16
boredom.is.me
Custom User Title
Just for gits and shiggles.
Size:  152.0 KBName:  ImageUploadedByTapatalk1369084738.831109.jpg
Size:  161.9 KBName:  ImageUploadedByTapatalk1369084836.976150.jpg
Sent from my mind using telepathy.
The Following User Says Thank You to boredom.is.me For This Useful Post:
MyRx (05-20-2013)
Old 05-20-2013, 07:05 PM   #17
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
So you want yours to look like mine?
ntron1 is offline   Reply With Quote
Old 05-20-2013, 07:31 PM   #18
boredom.is.me
Custom User Title
That's exactly what I'm going for! :happy0180:
Old 05-20-2013, 07:33 PM   #19
MyRx
MyRx's Avatar
Originally Posted by boredom.is.me View Post
Update,
@MyRx @Sonolin
@ everyone else
Essential upgrades:
Load out:
- stock ESC
- HPI T-Drift Tires
Want:
Nice list of parts. They should be readily available at your local hobby shops or online. I see you have a brushed motor but want a brushless esc, make sure the BL esc is backward compatible to a brushed motor. Check out rctech.com classifieds for parts, motors, esc, etc.
Good luck with your build. Can't wait for the result. Thanks for sharing.
Old 05-20-2013, 07:47 PM   #20
ntron1
Sarcastic Bastard
Please post a picture of the chassis without the body. Also, motors are not rated like that anymore. They are rated by Stator turns of wire. The motor in the car picture was a 13.5. The lower the number the faster the motor. The car in my picture has more motor than you could ever use without gearing down a ton.
Old 05-20-2013, 08:47 PM   #21
boredom.is.me
Custom User Title
As far as I'm aware, there is no brushless ESC that is capable of running a brushed motor.
I'm fully aware of how motors are rated. A 4 pole bl motor has much more torque than a 2 pole bl motor.
I've been building and flying RC planes, boats, hovercraft, and more for years. I'm in no way new to this.
Old 05-20-2013, 08:52 PM   #22
boredom.is.me
Custom User Title
Here is a few of my more recent stuff.
My 5" class fiberglass race boat. It's new and I haven't had much time to get it going.
Mine is the orange Slick
Not me, but my glider. I like to fly this one about 6" off the ground.
My 32" beater Slick turned into a night flyer.
My now night flyer and its twin. I built both.
I micro EDF to mass awareness and made nano class jets possible. The smallest jet in the world (6" I believe) has my ducted fans. He is now working on a 4.5" version of his A10.
My precision flyer that lasted one day. What a fun day that was.
12" version of my ultralight aerobatic design.
My mCPX next to my 450 (Both sold)
MY Zipper. 6.7" wingspan ogival delta design made purely for speed. I still haven't maidened it.
Ammonia (10-07-2013), u/Josh (05-23-2013)
Old 05-20-2013, 08:55 PM   #23
ntron1
Sarcastic Bastard
Good Luck. Maybe we can race them when I go to Florida next year for the World Championships.
Old 05-20-2013, 09:08 PM   #24
marky
marky's Avatar
Drives: 2020 BRZ tS #54
i see someones likes rc too
i fly helis/drift/off road too
painted them pearl with just like my 86 and tint the windows
Old 05-20-2013, 09:15 PM   #25
boredom.is.me
Custom User Title
Nice, what event are you running in?
Ya you're not alone. :happy0180:
I've never worked with rc clutches before. I swapped a Castle 5700kv into a friend's Traxxas Slash. The clutch doesn't hold though. It did this on the stock motor too. Any ideas?
Old 05-20-2013, 09:16 PM   #26
boredom.is.me
Custom User Title
Here are the chassis pics. The receiver sits on top of the steering servo. I'm repairing the Slash in the background for a friend and put the receiver in it.
Size:  246.1 KBName:  ImageUploadedByTapatalk1369098872.907313.jpg
Size:  250.6 KBName:  ImageUploadedByTapatalk1369098903.138503.jpg
Size:  241.4 KBName:  ImageUploadedByTapatalk1369098953.315256.jpg
Old 05-20-2013, 09:28 PM   #27
marky
marky's Avatar
time to upgrade clutch.. could be worn out or adjusted wrong/too tight..
clean the slipper plates and check the pads.. if you hold the rear wheels and give it power the fron should push up slightly and adjust to how you drive.. i only race mine on indoor track no basher
Old 05-20-2013, 09:41 PM   #28
ntron1
Sarcastic Bastard
I'll be at Snowbirds in Orlando with 700 of my closest friends. Thank god for sponsors, I could never justify the cost if I had to pay myself.
Full shocks are easy for that chassis. HPI, Tamiya, Associated and a bunch of others make them. Motor gearing is a little more difficult with the limited adjust-ability of the kit. For a speedo, Novak and Tekin make mid priced ones but they are all brushless now.
The Following User Says Thank You to ntron1 For This Useful Post:
marky (05-20-2013)
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 06:26 AM
How often to rebuild coilovers or stock shocks? stockysnail Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 12-24-2012 12:54 PM
Mini NSX M-17 Other Vehicles & General Automotive Discussions 43 11-09-2012 10:10 AM
My Mini FR-S Supermassive Off-Topic Lounge [WARNING: NO POLITICS] 13 08-23-2012 01:53 PM
What about that 1.5L Mini FT? LexusFman Scion FR-S / Toyota 86 GT86 General Forum 39 04-10-2011 09:54 PM
