Old 06-01-2013, 12:24 AM   #15
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
Originally Posted by feldy View Post
No it does not thank god. That sounds horrible. Why would you want that?
yea, I agree that is just plain dumb. Thank god we didn't get that tranny-AT setup !
rikdrt1 is offline   Reply With Quote
Old 06-01-2013, 10:23 AM   #16
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
A self downshifting trans when slowing allows you to return to speed without lugging, it downshifting for its protection. That function is a good thing.
killerkid08 is offline   Reply With Quote
Old 11-14-2014, 12:20 AM   #17
KelvinBRZ
GBS Mafia Member
KelvinBRZ's Avatar
Drives: with Snow mode on
Bringing this back from the dead - so in theory then, even if I'm accelerating in 6th gear at 40mph slowly to 75mph (as in traffic), no harm is done to the engine?
I notice the RPMs jump a bit higher if the car is going up a hill in manual mode, one time I was silly and forgot to downshift when going up a hill and was losing speed in 6th gear with the pedal depressed all the way. Hope that isn't bad...
GBS Mafia
KelvinBRZ is offline   Reply With Quote
Old 05-24-2015, 02:43 PM   #18
killerkid08
Cool Stuff
Drives: Cool Car
I'm surprised no one actually answered this. The torque converter in your trains isn't a perfect science when driving, in comparison to a manual where direct engagement is governed by your foot. You're not hurting the engine, but the computer should protect itself, by later downshifting if it falls too low in the RPM's and begins to lug.
Old 05-24-2015, 10:00 PM   #19
churchx
churchx's Avatar
Drives: 2014 GT86
I use 6th on MT since 40mph in normal traffic where i don't need fast acceleration and for economy purposes, just to fit with rest of traffic flow, almost all the time. Not seen any ill effects of that. Yes, below 40mph(64kmh), i notice that engine sounds different, like below normal range of working, hence below i switch to lower gears. Or in cases where i need that extra acceleration for quick takeover/merge in and alike. I don't know if this will help you, as too lazy to check if gearing is same on MT vs AT.
Still, i guess that for cases where something may actually hurt AT gearbox or engine, it's management will override manual gear switches you do.
FRS/BRZ Manual Trans Fluid shellslinger Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 131 11-02-2017 10:44 AM
Auto Trans paddle shift issue Craig Issues | Warranty | Recalls / TSB 26 08-17-2015 10:00 PM
FS: 1st 86 DGM/Asphalt Scion FR-S (Manual Trans) Neurytic Cars for Sale/Trade 3 05-22-2013 11:54 PM
AT Trans Shift Knob Replacement sapphire Cosmetic Modification (Interior/Exterior/Lighting) 7 11-14-2012 11:08 PM
Got a line on two unclaimed BRZs (manual trans) Tainen BRZ First-Gen (2012+) — General Topics 0 07-05-2012 10:40 PM
