#15 |
Drives: Mazdaspeed 3
Parking brake is a drum brake. It makes noise. Nothing is wrong with your car, you're fine.
#16 | |
Drives: Attitude
Translation: I left my parking brake up when I pulled away. So there's more than one way...but neither's going to be covered under warranty. |
#17 | |
#18 |
Drives: Attitude
#19 |
#20 |
I usually post drunk
NY? I'll need a mortgage by end of summer.
I remember once when I worked at FedEx this guy did his whole route with the parking brake engaged. I don't know how he didn't notice the smell but god was it potent when he pulled in. |
#21 |
Drives: Attitude
#22 |
Site Moderator
Drives: Stuff
This. My car has always done this, it's a parking brake.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#23 |
As mentioned, the parking brake is just a drum brake. The drum brake uses two half-cylinder shoes that are hinged on one side and pushed apart at the other side to wedge against the inside of the "drum". The pins that keep the shoes aligned rest in elongated holes to allow for this odd movement. It is not precision device, and it's certainly not designed for repeated high stress abuse.
The clunking you're hearing is either completely normal (I've heard it in multiple cars with drum brakes, even normal disc brake pads can clunk from fore/aft movement), or it's caused by excessive slop that you've worn into the mechanism. Either way, I can't blame the dealer for not replacing everything because it's a system only meant to be used while already stopped, not while gently rolling to a stop, or while hooning. I'm sure it's not the mechanic's first rodeo, they see the gamut nearly every day and they can certainly decipher the difference between normal wear, anomalous wear, and abuse. Remember, the 86 is still just a passenger car, not a purpose built competition drift car with a high leverage hydraulic brake system specifically designed to lock the rear wheels. Solution? Either A- ignore the sound and keep on keepin' on, and perform frequent inspections and replace parts yourself as needed, or B- Stop misusing the handbrake for hooning. Oh, and nobody is buying the "only a few times" BS... |
#24 |
#25 |
Drives: 1985 P-Type
You know it's a winner when the thread gets exciting with talk of mortgage origination.
#26 | |
Drives: White Virgin frs
#27 |
That guy
Drives: Ultramarine mt FR-S
I don't suppose you're licensed in Chicago, the gf and I are going to get a house very soon.
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
#28 |
damn I could have used this info. What are your typical costs in closing, fees etc...
| Anyone doing brake bleeding with the "Gravity Method"? | Hanakuso | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 03-03-2013 02:53 PM |
| "Official" Suspension/Brake Thread | NYC BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 06-27-2012 09:14 PM |
| Parking/Emergency Brake - "Clunk" | EsoBOFH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-24-2012 11:43 AM |
| pulling e-brake with auto tranny | carbonBLUE | Engine, Exhaust, Transmission | 2 | 05-16-2012 04:27 PM |
| Limited gets brake "upgrade" over Premium - Canada only? | Sport-Tech | BRZ First-Gen (2012+) — General Topics | 25 | 05-15-2012 12:35 AM |
