#15 |
Drives: 2013 BRZ Premium 6MT
that sound clip sounds exactly like my rattle. i had the tsb done where they spray grease in the rear shelf area, but that didnt cure it. the noise really only kicks up at highway speeds and when its windy out. started poking around today and moving the liners over the rear wheels does make a similiar sound.
2013 Subaru BRZ Premium 6MT -STOCK!
#16 | |
Drives: Scion Fr-s
Thanks!! |
#17 |
Drives: '13 Ultramarine
You're welcome. I hope that fixes it for you.
There are 3 pins that are a larger diameter (I think it is the ones that also hold the little flap in front of the wheel), and that is where the 3/8" washers would go. It doesn't really matter as long as they take up the slack. I used these same washers to stop a rattle at the 2nd under tray and the reverse light housing.
#18 |
stopped at home depot on the way home and picked up a fistful of rubber washers. also got some spray grease and zip ties. hopefully if its not raining tomorrow im gonnna go rattle hunting.
#19 | |
#20 |
Just a flat bladed screwdriver. Once they pop up about 1/4" or so, they should pull right out. A couple of them were pretty stubborn, but if you if you pry one side of the pin, then the other, they shouldn't be too bad.
#21 |
Drives: subaru brz
im having the the same noise coming from the left side of the rear wheel...started hearing it 2 days ago...my car has H&R lowering springs
#22 |
Power Ranger Elite
Drives: '13 WRB Sport-tech
Just wanted to post an update for anyone still having this problem.
I had a sound coming from the same area as op, so I tired the rubber washer fix all around the wheel well and it didn't really fix anything. What it ended up being was the big white plastic clip underneath the foam tool molds down in the trunk well. I tossed a big piece of duct tape over the clips on both sides and finally the rattle is gone. Hope that helps someone. I have a feeling it was my q300 that was creating the extra vibrations at highway speeds.
| The Following User Says Thank You to jimmillion For This Useful Post: | Tcoat (01-31-2015) |
#23 |
Drives: FRS
Weird Noise during stop and go
I have on recently. During stop and go I hear a weird noise on the pipe. Its annoying already. Anybody experience the same and any suggestions. My FRS is 2015 Automatic. I am looking for a solution or trying to figure out why? It was just a week ago when I hear the weird noise.
#24 |
Wes
Had this noise when I first installed my coilovers but it went away after a while
Instagram: @gt86ws
| FR-S is doing weird stuff | Apoc | Issues | Warranty | Recalls / TSB | 16 | 03-30-2013 11:00 AM |
| 0-60mph Times | boredom.is.me | Scion FR-S / Toyota 86 GT86 General Forum | 81 | 03-03-2013 02:43 PM |
| is it weird? | slidethis | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 01-14-2013 01:07 AM |
| Brake Test 60mph to 0mph **Video** | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 10-25-2012 03:30 PM |
| This might sound weird | mrha | BRZ First-Gen (2012+) — General Topics | 10 | 10-06-2012 06:06 AM |
