Old 04-23-2013, 05:43 PM   #15
Lytheum
Drives: 2013 BRZ Premium 6MT
that sound clip sounds exactly like my rattle. i had the tsb done where they spray grease in the rear shelf area, but that didnt cure it. the noise really only kicks up at highway speeds and when its windy out. started poking around today and moving the liners over the rear wheels does make a similiar sound.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 04-23-2013, 08:51 PM   #16
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Originally Posted by roddy View Post
Mine sounded very similar to yours, but not as constant. This sounds like the fender liner to me. If you have the time and a few dollars in your pocket, try the fix I posted above.
So after work I stopped my home depot and got some washers like you said. 2 different sizes but I didn't know what size went where so I was like f it, anywhere they fit should be good. Long story short took the car for a drive, didn't hear anything...... Yet lol
Thanks!!
Juanito08 is offline   Reply With Quote
Old 04-23-2013, 09:25 PM   #17
roddy
roddy's Avatar
Drives: '13 Ultramarine
You're welcome. I hope that fixes it for you.
There are 3 pins that are a larger diameter (I think it is the ones that also hold the little flap in front of the wheel), and that is where the 3/8" washers would go. It doesn't really matter as long as they take up the slack. I used these same washers to stop a rattle at the 2nd under tray and the reverse light housing.
Old 04-24-2013, 06:07 PM   #18
Lytheum
stopped at home depot on the way home and picked up a fistful of rubber washers. also got some spray grease and zip ties. hopefully if its not raining tomorrow im gonnna go rattle hunting.
Old 04-25-2013, 01:15 PM   #19
Lytheum
did you use a special tool to pop out the smaller plastic pop clips? the larger ones came out with ease, but i cant seem to get the others loose.
Old 04-25-2013, 08:26 PM   #20
roddy
roddy's Avatar
Just a flat bladed screwdriver. Once they pop up about 1/4" or so, they should pull right out. A couple of them were pretty stubborn, but if you if you pry one side of the pin, then the other, they shouldn't be too bad.
Old 06-30-2013, 06:21 PM   #21
subibrz
subibrz's Avatar
Drives: subaru brz
im having the the same noise coming from the left side of the rear wheel...started hearing it 2 days ago...my car has H&R lowering springs
subibrz is offline   Reply With Quote
Old 01-31-2015, 01:08 PM   #22
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
Just wanted to post an update for anyone still having this problem.
I had a sound coming from the same area as op, so I tired the rubber washer fix all around the wheel well and it didn't really fix anything.
What it ended up being was the big white plastic clip underneath the foam tool molds down in the trunk well. I tossed a big piece of duct tape over the clips on both sides and finally the rattle is gone.
Hope that helps someone.
I have a feeling it was my q300 that was creating the extra vibrations at highway speeds.
jimmillion is offline   Reply With Quote
The Following User Says Thank You to jimmillion For This Useful Post:
Tcoat (01-31-2015)
Old 03-05-2018, 11:39 AM   #23
aysnat
Drives: FRS
Weird Noise during stop and go
I have on recently. During stop and go I hear a weird noise on the pipe. Its annoying already. Anybody experience the same and any suggestions. My FRS is 2015 Automatic. I am looking for a solution or trying to figure out why? It was just a week ago when I hear the weird noise.
aysnat is offline   Reply With Quote
Old 03-05-2018, 11:47 AM   #24
StraightOuttaCanadaEh
Wes
Had this noise when I first installed my coilovers but it went away after a while
Instagram: @gt86ws
FR-S is doing weird stuff Apoc Issues | Warranty | Recalls / TSB 16 03-30-2013 11:00 AM
0-60mph Times boredom.is.me Scion FR-S / Toyota 86 GT86 General Forum 81 03-03-2013 02:43 PM
is it weird? slidethis Scion FR-S / Toyota 86 GT86 General Forum 11 01-14-2013 01:07 AM
Brake Test 60mph to 0mph **Video** FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 10-25-2012 03:30 PM
This might sound weird mrha BRZ First-Gen (2012+) — General Topics 10 10-06-2012 06:06 AM
