Old 04-21-2013, 02:14 AM   #15
Newguyottawa
Drives: Brz black
Agreed. It is likely a locked steering wheel. Wiggle it. I have had it happen several times.
Newguyottawa is offline   Reply With Quote
Old 04-21-2013, 11:24 AM   #16
eprosenx
Drives: 2013 Subaru BRZ
Originally Posted by 86•BRZ View Post
If the steering is loaded against the steering lock the car can't remove the lock pin it will fail to start. Easy to work out once you know what it is.. This is a possibility...
Hmm, in both cases I don't think that the wheels were cranked at all one way or the other so I don't think there should have been tension up against the steering wheel lock.
If it happens again I will see if the steering wheel moves ok when in the "wedged" state. Thanks for the suggestion!
As to others comments about power lines, no, neither of these were anywhere near power lines.
Also, as to the link to another thread about things not starting: This is not even cranking the engine, so it is a totally different issue.
-Eric
eprosenx is offline   Reply With Quote
Old 04-21-2013, 05:14 PM   #17
Trog
I've had three start-refusals to date. The first was right in the dealers lot. In all cases I got out of the car. Closed and locked the door. Waited a few minutes.. then it will fire right up. Last week, I had an odd event when I shut the motor down after a drive, and it restarted all by itself!
I HATE keyless entry. If anyone made a KEYLESS entry delete kit, I would be first in line to buy it.
Trog is offline   Reply With Quote
Old 04-22-2013, 12:29 AM   #18
eprosenx
Wow, it started by itself? Do you have an automatic transmission or a manual? If it cranks the engine without the clutch depressed in a manual that could be dangerous!
I like the keyless entry/start feature a lot (have had other cars in which it has worked flawlessly).
From the posts here it sounds like several folks have had this happen. Perhaps if we can catalog everyone having this issue it would help raise visibility to Subaru.
-Eric
Old 04-22-2013, 07:16 AM   #19
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
That kit already exists, you just missed it!!
Its called the BRZ Premium.
The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post:
dori. (04-28-2013), FRSBRZGT86FAN (01-27-2016), Ozzman (10-21-2013), PandaSPUR (01-22-2016)
Old 04-22-2013, 10:26 AM   #20
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I love old style insert key and start.
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Ozzman (10-21-2013)
Old 04-22-2013, 12:23 PM   #21
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
They don't have those in the North.
Old 04-22-2013, 12:30 PM   #22
Sportsguy83
Drives: Limited BRZ
Oh...
Old 04-22-2013, 01:56 PM   #23
Trog
-Eric
Very spooky indeed!
This is what happened; arrived home, pulled into the driveway. Pressed the clutch and brake, then hit the STOP button. Engine stopped, and immediately restarted. Like I said, very spooky!
Old 04-22-2013, 04:43 PM   #24
Porsche
Drives: 2013 BRZ Ltd. MT
I am wondering if I have run into a "race" condition bug in the engine ECU where I provide control input (i.e. start signal) too soon while it is in the process of booting up still, and I get it into a "wedged" state.
The steering wheel lock is in a “wedged” state.
This second time I decided to video tape my troubleshooting procedure so that I can help the dealership/Subaru troubleshoot. See the video below:
And your video proves it.
There’s something different in your video between the initial failed attempt to start and the final successful attempt to start.
For those of you who enjoy a challenge and a puzzle, I’ll put a bit of white space between this text and the solution below. See if you can find the answer without peeking at the solution below; it’s right there. What's different?
The green key symbol begins blinking rapidly at about twice per second when the START button is pushed but the steering lock fails to release. The car won’t initiate its starting procedure. Normally, the key symbol blinks slowly at about once per second. That’s the “key” to understanding this non-start phenomenon. The green key symbol is NOT blinking on the display at the end when the car starts properly. That’s what differs in the video and it’s what signals the nature of the problem.
What did the driver do differently? What he did was more inadvertent than deliberate; he moved the steering wheel slightly with his hand or leg as he entered/exited the car, freeing up the steering lock, so that now the car would start normally. It had nothing whatsoever to do with fuses, keys-on-the-roof, or anything else; just the steering lock.
Very simple.
See page 165 in the Subaru Owner’s Manual.
I’ve explained this before, yet, oddly, many people reject my explanation. I’m right, though. And if you refuse to believe me, then enjoy your walk home.
This should be in a sticky, since some owners may truly be faced with walking home, and the solution is not intuitive, however obvious it may be when once seen.
Porsche is offline   Reply With Quote
The Following 5 Users Say Thank You to Porsche For This Useful Post:
IntotheOcean (02-16-2014), JSUB (10-21-2013), Marchy (04-25-2013), MaximaZero (10-23-2013), sklimo (10-22-2013)
Old 04-22-2013, 05:03 PM   #25
Porsche
Also, I have noticed the passenger side window is not doing "auto-down" very well today perhaps due to the humidity. I have to press the button harder, or multiple times. Not sure if it is a switch issue, or if the force limiter is causing the "auto" down feature to kick off since there is too much friction.
It could be a switch issue; I understand there may be a modified part available now or soon.
Then again, it may just be the routine business of needing to reset the window "logic" when the glass gets stuck in cold temps. It's annoying, but apparently necessary as the glass barely clears the metal car body if closed in the fully up position; a little flex and the glass could hit the body and shatter. So, it moves up and down, but at the "expense" of regularly jamming in freezing temps. This car does not like the winter. (I love it anyway.)
To reset the passenger window, go sit in the passenger seat and perform the following: using the passenger door window switch, open the window fully, then briefly pull the switch UP momentarily, partially closing the window, repeat , and finally a third time, this time holding the switch in the UP position until the window is fully closed and then continuing to hold for a few seconds more. You may hear a click sound as the system resets itself.
Now, return to the driver side and see if the window operates properly. Hopefully, it will.
Old 04-22-2013, 08:18 PM   #26
Porsche
Oh, I should add for the very young drivers who may not realize the obvious solution: Just wiggle the steering wheel WHILE pushing the START button, which will free up the steering wheel lock and allow the car to start. That's all one need do.
Note, too, that unlike the conventional key in the ignition lock routine where one turns the key and HOLDS it turned until the engine starts, this push start system does not require one to HOLD the START button down. Just give the button a brief press and the computer will start the car, engaging the starter for as long as necessary.
Think kindly of elderly Porsche as you DRIVE home, rather than walk. We Old Farts can still be useful from time to time.
The Following User Says Thank You to Porsche For This Useful Post:
sklimo (10-22-2013)
Old 04-25-2013, 01:35 AM   #27
eprosenx
Porsche- I tested this a couple times today and it looks like you are 100% on the money. Thanks much!
Video proof of me re-creating the issue is here:
[ame]http://youtu.be/qCIxFpxjLYk[/ame]
Indeed, this should be sticky'd!
P.S. I don't get why having the steering wheel solenoid engaged/disengaged would have any bearing on it cranking the engine for you or not, but hey, whatever... I had no clue the car could even tell if the solenoid successfully engaged/disengaged or not!!!
-Eric
Old 04-25-2013, 02:20 AM   #28
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
-Eric
So this is exactly what I said in post 11, 4 days prior!
For understandable reasons, you don't want your car starting with the steering lock engaged.
86•BRZ is offline   Reply With Quote
Car fails to start. ericvanderwoodsen Issues | Warranty | Recalls / TSB 8 03-14-2013 12:36 AM
Door Handle Proximity Lock Marcoscrdo DIY (Do-It-Yourself) Guides 4 01-07-2013 12:00 AM
I start at Quirk Subaru this week! Turbowned New England 22 10-23-2012 10:54 AM
2013 Subaru BRZ Limited Start Up, Exhaust, and In Depth Review delta86 BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-26-2012 03:25 AM
