Old 04-18-2013, 10:57 AM   #15
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
how would 18x9 or 18x9.5 square set up compare to a 17x9 square setup? thanks
DAN_BRZ is offline   Reply With Quote
Old 04-18-2013, 11:10 AM   #16
leon78
leon78's Avatar
Drives: 13 Whiteout
See sig...b/c Racecar!
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 04-18-2013, 11:38 AM   #17
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
18x9 or 18x9.5 is ok as long as it's a forged light weight rim, or rpf1s
People don't recommend 18x9 or 18x9.5 because they are generally very heavy, >22 lbs, which can decrease the performance a lot.
But if you get light weight rims, it would be ok. 18x9.5 TE37s weight around 17 or 18 lbs IIRC. So in that case, it's actually lighter than a lot of the 17s in the market like rota, xxr, tsw.
shu5892001 is offline   Reply With Quote
Old 04-18-2013, 11:45 AM   #18
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Are you on stock suspension? I was told that 9's couldn't fit in the front without coilovers.
Old 04-18-2013, 11:53 AM   #19
shu5892001
Ontario's FT86
depends on your offset, if you have something like +45 then it probably won't fit
Old 04-18-2013, 12:00 PM   #20
DAN_BRZ
DAN_BRZ's Avatar
i wont be going with something heavier then stock, i had rpf1's on my previous setup and was originally going to use those but unfortunately the bolt pattern is 5x114 so they wont fit. rpf1s are also played out imo. i am leaning towards the gramlights 57DR, which also seem to be a popular choice on these cars. you are running the same suspension set up ill be running on my car, i already have the RCE's the konis will be next. im liking the weds tn105, the te37s are nice as well. too many decisions!!!
Old 04-18-2013, 12:03 PM   #21
DAN_BRZ
DAN_BRZ's Avatar
im runnig RCE's at the moments, and will swap the dampers out for konis down the road.
Old 04-18-2013, 12:04 PM   #22
shu5892001
Ontario's FT86
IMO, skip the gram lights as they are not exactly "light".
I would choose between te37 and tc105. If you can soak up the beans for TE37 then go for it. If not then go with 17x9 tc105s.
That was my selection when I ordered rims.
Old 04-18-2013, 12:05 PM   #23
DAN_BRZ
DAN_BRZ's Avatar
im thinkimg a +35 or +38 offset, dont want the wheels to be sunken or poking, just want the hella flush look!!! i really want to avoid the poke, dont want shit off the tires hitting the side of my car.
Old 04-18-2013, 12:08 PM   #24
shu5892001
Ontario's FT86
Yea those offset should be safe for 9 or 9.5 wheels. I would do 35 in a 9 wheel and 38-40 for a 9.5 wheel
Old 04-20-2013, 01:37 PM   #25
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
What offset will fit with stock suspension..if I go with 17x9" square
Old 04-20-2013, 01:38 PM   #26
shu5892001
Ontario's FT86
35-40 you should be golden, not sure about 40+
Old 04-20-2013, 01:57 PM   #27
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
If I go with 17x9 +35 square..that is no need to lower the car ..right? I can just stay with stock suspension?
Old 04-20-2013, 02:03 PM   #28
shu5892001
Ontario's FT86
Yep no need to lower, 35 to 40 offset you should be fine
Wheel Directory: ESM 004 17x9.0 +38 Scott Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 06-26-2017 04:54 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WEDSSPORT TC105N 17x8.0/17x9.0 and 18x8.5/18x9.5 *** with Special. Ed Sticker *** RavSpec Wheels and Tires 47 06-22-2013 11:49 AM
FS in FL: Drag DR-31 17x9" Square setup 5x100 (or 5x114.3) +38 GTB/ZR-1 Wheels and Tires 1 12-06-2012 07:22 AM
