Old 04-18-2013, 12:32 PM   #15
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by kioton32 View Post
Yes but I do all my own tuning and internal mods as well... It's not going to have a stock block...with everything I have down so far I should be close to the number on pump gas 93 octane... I just need the twin screw setup from innovate so I van go with a bigger blower, intercooler and fuel system... 340-350 wont be out of the realm... Plus to top it off ill be running slicks at the track...
If you have all that and plan on running it at the strip (which I wanna do to mine ) I assume ur better off with a turbo considering that you are going to build your internals , moaar boost and an anti lag setup or a launch control tune ul be way better then a sc
My 2 cent
Old 04-18-2013, 12:42 PM   #16
kioton32
kioton32's Avatar
Drives: 14' Monogram FRS, ulramarine, white
I don't want the possible boost spike of a turbo though... It's not going to be a straight track car... I will still be driving it on the street and like the reliable boost of an SC over turbo... Plus I won't have to deal with the torque dip that this engine has... But I appreciate the input...
whether it be low and slow, fast and loud, or riding on rails, make it unique and make it your own.
kioton32 is offline   Reply With Quote
Old 04-18-2013, 12:46 PM   #17
Sonolin
That sounds like a killer build. Twin screw on this car is going to fly at the strip, I'm sure you'll get into the 11's with that.
Sonolin is offline   Reply With Quote
Old 04-18-2013, 12:56 PM   #18
SmsAlSuwaidi
Boosted
11's have been done on a stock block already if I'm correct
Old 04-18-2013, 12:58 PM   #19
PrDarkKnight
Director of Awesome!! :)
PrDarkKnight's Avatar
Drives: Scion FR-S
Actually, proper tunning alone should get rid of the torque dip. That plus anti-lag launch control should be ideal for your set up + if you are only looking for a 12-13 sec car and have built internals it sould be safe for DD.
Life is all about the ride, so go full throttle baby!!
[SIGPIC][/SIGPIC]
PrDarkKnight is offline   Reply With Quote
Old 04-18-2013, 01:13 PM   #20
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
With Overboost protection you don't need to worry about a boost spike.
Old 04-18-2013, 02:22 PM   #21
Xdragonxb0i
Drives: ex500r
it doesnt quite matter the methods, just the HP and TQ curves.
500whp will get you in the 12s or less but at this point the the problem will be putting all the power down to the wheels
Xdragonxb0i is offline   Reply With Quote
Old 04-18-2013, 02:34 PM   #22
Supermassive
Supermassive's Avatar
What kills me about that HKS Supercharger making 300HP is how little torque they make. I'm running 7lbs of boost on my turbo setup which is good for 260WHP with 211 Wtq, while the 300WHP HKS setup is making only 222Wtq...
Superchargers are cute...
Also boost spikes come from equipment issues/failures, also if you get a good tune with EcuTek or run an AEM failsafe you can protect your car from such issues.
Supermassive is offline   Reply With Quote
Old 04-18-2013, 02:48 PM   #23
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
It's a RWD car its not rocket science We have a parking lot of street class FWD cars that run mid 8's-9's and daily driven ones that run low 10's.
Jesse@JDLAutodesign is offline   Reply With Quote
Old 04-18-2013, 04:19 PM   #24
kioton32
kioton32's Avatar
I feel more comfortable with the twin screw SC though... Just my preference... To each there own right...
Old 04-18-2013, 04:26 PM   #25
s2d4
s2d4's Avatar
You might want to do some research about it. You can't just wack a bigger blower like the 335 onto a 210 based setup... 210 has a max of 300hp which won't happen either.
Old 04-18-2013, 04:37 PM   #26
QuikSilveRX-8
QuikSilveRX-8's Avatar
Drives: SE3P
Don't try to make a car be something it's not. You can do it, it's not impossible, but you can likely get to that goal cheaper, faster, and more enjoyably picking a car that is already much closer to your goal.
Three moving engine parts, yet complicated... Or do I mean complex?
QuikSilveRX-8 is offline   Reply With Quote
Old 04-18-2013, 08:26 PM   #27
kioton32
kioton32's Avatar
I will be fine taking a base system and modifying it to be what I want... Putting a larger blower means ill have to modify the bracket and base and I'm fine doing that... I know what om doing and am not going to ruin anything... I'll be doing a full build thread to show progress and it will be fine.
Old 04-18-2013, 08:55 PM   #28
wparsons
wparsons's Avatar
Originally Posted by vtmike View Post
That time and trap seems about right. My previous car (neon srt 4) made similar power (230 whp) and had similar curb weight (2890) and ran almost identical time and trap speed.
How much does the supercharger weight? I bet an frs with supercharger is right around the same weight.
Sent from my Galaxy Nexus using Tapatalk 2
SRT4's with stickier tires would easily hit a 13.8 otherwise stock, and since RWD hooks up way better I wouldn't doubt an FR-S could easily hit a couple tenths faster still.
An e46 M3 will run a low 13 with the stock 330hp at the crank and about 600lbs more weight (they're ~3400lbs), so I see no reason why an FR-S making an honest 250whp couldn't run low 13's either.
flickr
1/4 Mile times Boosted2.0 Tracking / Autocross / HPDE / Drifting 368 02-13-2021 07:52 AM
1st time on 1/8' mile FRS8SIX Tracking / Autocross / HPDE / Drifting 1 08-16-2013 06:10 PM
10,000 mile update jeebus BRZ First-Gen (2012+) — General Topics 23 05-28-2013 06:59 PM
My first 100 mile impression bdbx18 BRZ First-Gen (2012+) — General Topics 20 12-12-2012 11:42 PM
Standing Mile _hollywood Scion FR-S / Toyota 86 GT86 General Forum 5 07-16-2012 02:33 AM
