Old 06-27-2013, 10:35 PM   #15
polarstorm
polarstorm's Avatar
Drives: Scion FR-S
Originally Posted by br_z1Lch View Post
This wouldn't be an issue, to be honest, but it seems like the "Random -> Folder" option doesn't play sub-folders. And if a folder only has sub-folders, you can't select that folder for "Random" - there has to be a song in it.
The thanks is for ack that there is def something wonky with how the processor is addressing the files on the unit. Wondering what a good oem after market sound controller / stereo would be that fits in the FRS console.
polarstorm is offline   Reply With Quote
Old 06-28-2013, 07:33 PM   #16
br_z1Lch
br_z1Lch's Avatar
Drives: 2013 BRZ(swp) Limited
Originally Posted by polarstorm View Post
The thanks is for ack that there is def something wonky with how the processor is addressing the files on the unit. .
So I took a little extra time and re-organized a bit. Just made folders that have slightly less than 255 songs in it (for example, I have Rock A-F, Rock G-R, Rock S-Z). This is at least allowing all songs to be loaded properly.
A little more investigation into this has led to the conclusion that it's not the USB stick's fault, nor is it FAT32's fault. The fault is with the way Linux natively handles the "loading" of files. It can only load 256 files at once, unless otherwise specified. The "wonky" part about all of this is that the head unit IS actually loading all of those files before it displays them. I noticed that when I view a folder, it only lists the song name - presumably taken from the ID3 tag. This means that the files are all loaded by the head-unit to read those tags, instead of simply listing all of the files out. (This is annoying in itself, just based off of the way I re-named all of the files.)
As for "good" replacement units, I'm not sure. I haven't even really looked into replacing it, although I've seen that there are a few threads about replacement options already.
br_z1Lch is offline   Reply With Quote
The Following User Says Thank You to br_z1Lch For This Useful Post:
polarstorm (06-29-2013)
Works Bell, Nardi, Personal, and Keys Package deals and Shift Knobs Evasive Motorsports Interior Parts (Incl. Lighting) 90 07-10-2017 05:47 PM
I created an automatic Toyota order status notifier for you guys. Check it out. eleu2166 AUSTRALIA 32 03-05-2013 03:18 AM
Advanced Keys Inc + Viper 5904 Iddoit2er Electronics | Audio | NAV | Infotainment 5 02-24-2013 02:50 PM
Tetsuya Tada: Behind-the-scenes story on how Toyota and Subaru created the GT86 / BRZ avusblue Scion FR-S / Toyota 86 GT86 General Forum 63 02-21-2013 10:46 PM
