#15 | |
Drives: None Yet
If you get oil changes done at any shop, whether it's at the dealer or an independent shop, they will never wait for all the old oil to drain out, because they have so many customers to attend to and standing there under the car for 15 minutes just watching old oil trickle out of the hole isn't time or cost effective haha. |
#16 |
wheel gap
Drives: whiteout frs, 04 xrs
#17 |
Proud of BOXER
Drives: Subaru Boxer
I think it would be great if more people could mention checking the passenger side block off plate which he mentioned in the original post was dry.
#18 |
Drives: BR86
I reckon Foobar hit the nail on the head.
I had the same experience first time change & noticed the oil quickly splashed onto alloy shield. When all done I cleaned everything up, checked levels & test drove. The next day I noticed oil level overfilled which I corrected & oil stainage on shield, cleaned it up & it's all OK. |
| The Following User Says Thank You to ZZT86 For This Useful Post: | Marrk (04-02-2013) |
#19 | |
Drives: Honda Fit
I third this. It's possible that some oil, while exiting the drain hole, splashed onto something(s). That splashed oil is now making itself appears bit my bit. How many days has it been since the oil change? Two? |
#20 |
Drives: ZN6
Hey guys thanks again really for the insight. I really hope that's it! I do remember the oil shot out like a rocket when I took the plug off but I don't recall it splashing onto anything but that could be what happen. I just didn't notice.
It doesn't seem to leak when the cars at a stand still hence I left paper towels underneath overnight and nothing. It just shows up after a drive. I'm going to check out the car again in a but and will repost. Yes it has been exactly two days since my change. |
#21 |
Drives: BR86
Take the alloy shield off & clean it & everything nearby with wax & grease remover & drive without shield. It should all be fine, it's highly unlikely it leaks. The oil gushes out quickly jacked up & on an angle & catches the shield slightly causing the stain, it actually falls into the inside & spreads across the shield with airflow when driving.
#22 | |
Drives: 2013 FRS/01 Tacoma
#23 |
Drives: 2013 Scion FRS WhiteOut
worst case scenario if you're sure theres a leak in the system just use engine oil dye it'll show you exactly where its trailing from.
![]() Winnipeg, Manitoba |
#24 |
Drives: ZN6
Hello all! Again thanks for all your insights everyone
it shows how great this community is♥ I ended up inspecting everything today and it ended up what ZZT86 mentioned. What I ended up doing first (which I should have done earlier -_-) was check the oil in my engine by wiping it off the dipstick with a towel and it was still clear and fresh where as the oil I wiped at the bottom was dark brown. I ended up wiping the inner side of the engine cover where I spotted the oil stain initially and low and behold a mini pool of old brown oil Wiped it all clean and went for a drive and all is clear! no more stains! I feel like such a dummy :p thanks again everyone! |
| The Following 2 Users Say Thank You to DSMDave25 For This Useful Post: | 20valvewynn83 (04-03-2013), Clipdat (04-03-2013) |
#25 |
Proud of BOXER
Hey better safe than sorry! Glad everything worked out for the best. Also glad you don't have the leak from the block off plate! Sounds like you're good to go, get out there and enjoy!
| Oil Leaking?? | tonytduc | Issues | Warranty | Recalls / TSB | 371 | 11-13-2016 08:14 PM |
| exhaust cracking and leaking | driver01 | Engine, Exhaust, Transmission | 80 | 09-17-2013 04:25 AM |
| Still Leaking? | 636 | Issues | Warranty | Recalls / TSB | 15 | 01-11-2013 04:41 PM |
| Leaking Oil? | 636 | Issues | Warranty | Recalls / TSB | 11 | 01-05-2013 05:43 PM |
| Tires keep leaking | EvoXDD | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 08-29-2012 04:03 AM |
