Old 03-26-2013, 10:48 PM   #15
d1ck
Drives: Black 2013 FRS
This is something many oems are working on. Everyone wants turbos as they allow you to capture waste heat from the exhaust. However lag has always been the problem here.
IIRC BMW's system uses an electric motor to spool the turbo until there is enough exhaust gas flow to power the turbine. This is going to be a good stopgap measure until thermo-electric generators become cheaper and more efficient. If we could capture even half of the heat which is current wasted out the exhaust and radiator we could double fuel economy.
Lots of people want to think the ICE is dead but the truth is we have a long way to go before that happens.
d1ck is offline   Reply With Quote
Old 03-26-2013, 11:02 PM   #16
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
Need MOAR POWER!!!!
Im going to go out on a limb and say a full reconstruction of OEM voltage (a la 24-48 volts) is a little ways off in the future. Think of the poor aftermarket parts suppliers lol and theres just sooo many places to lose energy in a system like this its crazy!
I suppose they could make it like an aircraft (which btw have 28 volt electrical systems) and have the starter also be be a generator when required to run the turbo at high throttle settings... I'm more than willing to see it in action
RandomHero is offline   Reply With Quote
Old 03-26-2013, 11:06 PM   #17
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
KERS and "mild hybrids" are the key to making electronic turbochargers happen. Alot of racing teams already employ regenerative braking. Some are developing regenerative dampers (using voice coil and piezo tricks). Seebeck generators are only ~5% efficient at converting thermal energy to electricity, so it will be a while for that tech.
If KERS systems become faster and larger capacity, it will be simple enough to integrate an exhaust turbine generator and electric supercharger.
Storage is already getting there. Ultracapacitors (like the Maxwell units) are still pretty expensive, but the technology is there. The car audio competitors have developed some amazing systems that maintain voltage at insane current draw:
Typically DC motors run at 90 or 180V, but you can get custom windings from most manufacturers. I'd imagine the starting circuit will stay at 12 or 24V, but the KERS systems will be stored at a higher voltage and connect via step-down transformers and a really big diode bridge.
side note: If you think the Toyota/BMW collaboration is just about making a car, you're forgetting just how many patents and R&D hours the Prius has clocked. You're also forgetting all the EfficientDynamics research that has gone into BMW's plug-in hybrid turbodiesel.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 03-26-2013, 11:09 PM   #18
Dimman
Kuruma Otaku
Dimman's Avatar
@serialk11r
This is your type of discussion, right?
Because titanium.
Old 03-26-2013, 11:11 PM   #19
jamesm
you need a lot higher voltage to put out the crazy power necessary to compress massive amounts of air really quickly. current brushless motors about the size you'd want in a turbo/supercharger/nutty electric hybrid thing (like a 700 size rc heli motor) can make 6-12hp, and they weigh very little. i'd call it an eventuality at this point... just a matter of time before it's possible, then some day practical.
it makes sense that it would be best used to spool a turbo, since keeping up with the airflow demands at high rpm would require a ton of power (and generate a ton of heat).
Old 03-26-2013, 11:42 PM   #20
Calum
That Guy
Drives: 2013 asphalt FRS MT
That's one of those ideas that's so simple and yet so brilliant. I love it.
There's a really cool duality to this if it plays out the way I think it might.
When diesels first came out they needed a supercharger to run. Two stroke diesels with the ports in the sides of the cylinder walls didn't have the ability to create sufficient suction and keep the intake port sealed off during combustion, so they absolutely had to be force fed.
I wonder how long it'll be before they stop designing intake port head flow to ever work in a vacuum/ And I wonder what that'll do the shape of the posts.
Old 03-27-2013, 12:38 AM   #21
Turdinator
Señor Member
Turdinator's Avatar
This is a much more interesting thread than i expected. You could run an alternator off a turbo exhaust housing also. Not neccesarily as efficient as a normal turbo but would be interesting none the less.
1974 TA22 Celica
2013 86 GT
Old 03-27-2013, 12:42 AM   #22
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
I remember reading about a possible future WRX/STI platform.
Not hard specs, but a supposed theory.
The turbo has an electric motor matted that can engage/disengage.
At low RPM electric motor assist the turbine = reduced/no lag.
Disengages when the engine produces enough exhaust gasses itself to spool.
Thermal energy from exhaust housing is converted to charge the units separate battery.
That battery or cell is also supplied power from vehicles power supply.
Off topic below
Above speculation plus a new light weight, smaller, AWD chassis has me excited.
As of now, one can only dream.
# 1. Always know where your towel is.
ZC6-CBS, is home
Last edited by Floggin Tires; 03-27-2013 at 12:44 AM. Reason: I can't write wright.
Floggin Tires is offline   Reply With Quote
Old 03-27-2013, 12:54 AM   #23
tofufoo
tofufoo's Avatar
Drives: 86/FRS
Don't do it. Been tested don't work. There's a clip on YouTube on those electric turbo.
tofufoo is offline   Reply With Quote
Old 03-27-2013, 01:30 AM   #24
sw20kosh
Drives: 2013 Black FR-S
read
the
thread
this is not about the ebay electric turbos for sale
this is about theory and developing a future electrically powered turbo utilizing advanced battery/capacitor tech
The Following User Says Thank You to sw20kosh For This Useful Post:
Floggin Tires (03-27-2013)
Old 03-27-2013, 02:09 AM   #25
spyingwind
Drives: White '17 86
From my experience from playing with alternators, generators, and electronics with motors. I can tell you that it is possible to do, but this application eats too much efficiency out of the system to be... efficient.
I can see a three phase AC generator being used to power a three phase electrical motor to power the turbo.
The reason that we use the mechanical TC's and SC's is that they have a high efficiency at the moment. Efficiency as in when we convert energy from one system to another we lose energy.
You know that fan motor that you put in font of your car when you dyno it? That is what I'm talking about, or very close. Yes a 120V AC motor would do the job. Now I just need a 120V alternator.
Hm... brb
spyingwind is offline   Reply With Quote
Old 03-27-2013, 07:48 AM   #26
solma
Drives: Raven FRS
Its possible but not worth it, simply due to weight(electric motor+cap/bat+drive) and other way of making more power cheaper/easier.
KERS(at least mecanical one) are use for specific usage in specific race regulation, not as efficient in the real world.
As for voltage or type of voltage, there no really link with the power an electric motor give, its mostly all about want kind of caracteristic you want from motor and how it is built(High amperage generate more heat in component(loss), so best to keep low by having higher voltage).
I think, if I would go for some crazy design(did not say its feasable) for higher power in short burst, I would start by having directly an electric motor that replace the drive shaft(weight would be low as for gravity), possible torque(due to large surface) quite high, could be use as regenerative device, since connect directly with the rear tyre, or with the engine when clutch engage, would not put more stress on the engine. And would not take any efficacy(MPG) out of the current system.
solma is offline   Reply With Quote
Old 03-27-2013, 08:06 AM   #27
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
Lot's of talk about "how" it could work, but what about "how long" will it last? There will obviously be a trade off for useful time and battery / capacitor size, but what do you consider "enough" before it putters out? One lap on an auto-X course? Several laps on a big boy track? Are we only looking for a boost at low RPMs or will this also keep the turbo spool'd in between shifts (mitsu did that right?) because that'll play into how long the juice lasts.
How long would to recharge it would you find acceptable? For instance my very mild hybrid CRZ takes quite a bit longer to recharge when you compare it to the useful battery. It's (lol, sadly) a better hybrid if you switch between normal and ECO modes instead of just leaving it in ECO (eats the battery charge quick).
Chimpo is offline   Reply With Quote
Old 03-27-2013, 08:35 AM   #28
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
The efficiency could be there in a hybrid where you already have a secondary electrical system in place, and get power from regenerative breaking.
As for KERS its not just for race use anymore, new systems are making it into production cars as we speak. Porsche, and Ferrari already have production models with KERS, and Volvo, BWM, and Toyota have systems in development.
Electric FR-S by TGMY Surok Scion FR-S / Toyota 86 GT86 General Forum 39 12-03-2012 03:43 PM
Electric 86 frosty86 Scion FR-S / Toyota 86 GT86 General Forum 8 11-10-2012 02:16 PM
Report: BRZ STI Model Already in the Works, No Turbocharger Sport-Tech BRZ First-Gen (2012+) — General Topics 188 08-30-2012 05:53 PM
WRX Electric turbo Neilus Engine, Exhaust, Transmission 42 05-03-2012 09:20 PM
