Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 03-10-2013, 10:09 PM   #15
Blazereaper
Drives: Ae92
@Skorov, oooooo enlightened (sorry)
btw did it take you long to remove all the fiddly bits dash and etc to change the LEDs? how many were there approx can you give an idea? and was it a soldering job or a change bulb job?
Blazereaper is offline   Reply With Quote
Old 03-11-2013, 06:09 PM   #16
Skorov
Skorov's Avatar
Drives: 86 GTS White
All good!
It takes about 20-30 minutes to remove all the trim to get to the a/c and gauge cluster if you know what you're doing. Might take a bit longer if you're a first timer like I was.
For me, it was a straight swap job. The LEDs are all PLCC2 SMD which means they have to be unsoldered and soldered back on. There is one 3mm bulb in the LED bringness control switch/wheel (the one under your steering wheel, to the right). And I'm not sure about the door controls yet.
In total, there are about 60 separate LEDs to swap out. (Not counting the system lights which I left OEM)
Skorov is offline   Reply With Quote
Old 03-11-2013, 06:12 PM   #17
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
The switches on the driver's side closest to the doors are bulbs.
-Acree
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
The Following User Says Thank You to Acree For This Useful Post:
Skorov (03-11-2013)
Old 05-12-2013, 08:01 AM   #18
BRZ080
Drives: BRZ Limited
Question
Hey Skorov,
Nicely done, I have just finished completing the centre section with 3528 SMD's, but noticed the colour looks a little aqua... not bright blue.
I was wondering did you remove or cut out the tinted grey plastic rubber from inside the light housing for each smd?
Although turning the dash light adjustment up helps it seem not to be a true blue as in the original smd color.
BRZ080 is offline   Reply With Quote
Old 11-12-2013, 04:58 PM   #19
Dantical
Drives: Mr2 3S-GTE GEN 3 - GT86 MT
damn this nice,.. can you post more Infos about leds and the "Change"?
which leds did you use,.. do you have more Pictures how you did it ?
Dantical is offline   Reply With Quote
Old 11-12-2013, 11:08 PM   #20
Skorov
Skorov's Avatar
What do you want to know? The LEDs are of type PLCC 2. They are surface mount (SMD). To change the LEDs, I used a soldering iron with a very thin tip. To remove the OEM LEDs, you can either use 2 irons or just quickly alternate between the 2 sides of the LED until all the solder is melted and the LED slides off. (This can be tricky at first.)
Clean the mounting plates with some soldering wick and solder on the new ones.
Sadly I don't have any more pics. It's quite a big job so I didn't want to extend it by taking photos every 2 seconds.
Old 11-12-2013, 11:25 PM   #21
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Where abouts did you get the LED's from.. .
i am kinda keen to do this, kinda worried about my shakey hands..
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 11-15-2013, 08:33 PM   #22
Skorov
Skorov's Avatar
Element14. They are based in Sydney but ship anywhere.
The Following User Says Thank You to Skorov For This Useful Post:
fuddbutter (11-16-2013)
Old 12-12-2013, 04:01 AM   #23
JakeG
JakeG's Avatar
Drives: MY15 GTS 6AT
I just ordered my GTS and apparently this is now an option for $250 or something...so I got it...it will be interesting to see if it's really worth it...I'm sure it is
JakeG is offline   Reply With Quote
Old 04-02-2014, 10:30 PM   #24
Drebin252
Drebin252's Avatar
Drives: GTS 86
How'd it turn out? Got any pics?
Drebin252 is offline   Reply With Quote
Old 04-03-2014, 08:09 AM   #25
JakeG
JakeG's Avatar
well, i changed my order to a MY15. I have to wait until July!
If it's too loud, you're too old.
Old 09-23-2014, 03:23 PM   #26
CJBRZ
Drives: 2015 Series.Blue
Where you able to find out the LEDs needed for the door?
CJBRZ is offline   Reply With Quote
Old 09-23-2014, 09:35 PM   #27
Skorov
Skorov's Avatar
Yea. The door ones are PLCC2 also. The only one that was different was the LED for the interior brightness knob. From memory I think that one was a 3mm LED bulb.
Old 09-23-2014, 09:41 PM   #28
CJBRZ
Thanks! Where there any problems that you ran into while swapping out your LEDs that you'd like to share, or was it pretty straight forward?
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
2JZ swap? jordydiaz Engine Swaps 44 05-21-2015 10:19 PM
Ej Swap koyv90 Engine Swaps 50 11-14-2013 07:59 PM
Key Fob Swap joergasm BRZ First-Gen (2012+) — General Topics 1 10-02-2012 11:40 PM
2UR-GSE Swap czar07 Engine Swaps 9 08-29-2012 01:43 PM
