Old 03-25-2013, 12:08 AM   #15
Pedalincircles
Drives: FRS
Originally Posted by GotM View Post
Ran last week with the new set of tires and wheels. I started off the day at 38psi front and 36psi rear.
The rear pressure seemed to work well, but had to bump up the fronts a few psi to get the wear in the right spot. I think I went to 44psi hot in front and that worked better.
I may have been over driving the car, I am new at this .
I think I will start with 40psi cold in the fron next event and see if this is a better starting point.
Suspension mods?
Pedalincircles is offline   Reply With Quote
Old 03-25-2013, 09:45 AM   #16
Alliedforces86
Flat 4 Handyman
Alliedforces86's Avatar
Drives: Firestone Red FR-S & WRB MY2002 WRX
Great to finally see these on a car. I've been rolling around the idea of getting them for awhile now, was wondering how they sat on the car. I think I'm finally sold. Thanks for being the test subject.
Alliedforces86 is offline   Reply With Quote
Old 03-25-2013, 08:49 PM   #17
GotM
GotM's Avatar
Drives: 14 Porsche Cayman S
Originally Posted by Pedalincircles View Post
Suspension mods?
No, this car is on 100% stock suspension. The wheel gap looks to be gone in the picture above, that is just compressed suspension due to the left turn I am finishing.
Previous cars:
2013 Subaru BRZ (2012-2017)
2009 BMW135 6MT (2009-2012)
1999 BMW M Roadster (2000-2010)
2004 Audi A6 2.7T (2004-2007)
GotM is offline   Reply With Quote
Old 03-26-2013, 07:29 PM   #18
Lakers86
Lakers86's Avatar
Drives: Asphalt FRS
I like simple setups like this. Looks really good. I might consider that same size. Do you have any plans for a drop?
Lakers86 is offline   Reply With Quote
Old 03-28-2013, 12:31 AM   #19
GotM
GotM's Avatar
No drop planned at this time. I want to keep it in the stock category for autocross at this time.
This is a possibility in the future. I do think the car looks better with a slight drop.
Previous cars:
Old 04-20-2013, 11:50 AM   #20
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
How has your Stock/RTR running been with these?
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 04-20-2013, 04:03 PM   #21
Apexer
Drives: 15 Halo
So, I ordered a set from tirerack, and they didn't say anything about hub centric rings, and I'm not sure of the hub dimensions. Do they require them?
Apexer is offline   Reply With Quote
Old 04-20-2013, 04:45 PM   #22
SVThis
SVThis's Avatar
Drives: Scion FRS
No rings required. Machined hubcentric for the car
We're not happy till you're not happy
2013 Scion FRS Whiteout 6MT
SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover.
SVThis is offline   Reply With Quote
The Following User Says Thank You to SVThis For This Useful Post:
Apexer (04-20-2013)
Old 04-20-2013, 05:17 PM   #23
Apexer
Drives: 15 Halo
Awesome, thanks!:happy0180:
Old 08-27-2013, 05:06 PM   #24
Afghan Vet
Afghan Vet's Avatar
Drives: 2002 BMW 325i
Thanks for the pics and the info - especially weights. This is one of the rims I'm considering for my GBS.
2013 Subaru BRZ Limited
Pioneer.Mosconi.Morel.Audible Physics.Ascendant Audio
Afghan Vet is offline   Reply With Quote
Old 09-03-2013, 08:18 PM   #25
CyberCT
Drives: RSX
Those are the wheels that I want. Just under 15lbs each. I was thinking of going with the Continental DWs with stock tire size. It would be a 34lb per corner setup. They're pretty good lightweight summer tires, I have them on my RSX. My RSX has RPF1 17x7 +45 but it's 5 x 114 bolt pattern, so they won't work. Gonna have to sell them cause the RSX is gonna be the winter beater car now.
Seeing how the offset is -6 per corner from stock, would this cause premature wear on the wheel bearings? Shouldn't mess with the suspension geometry right?
I'm going to contact Enkei tomorrow and see if the PF01 centercaps fit in the RPF1s.
Has anyone tried Toyota cenercaps to see if they fit the RPF1s? My Acura centercaps fit perfectly in the RPF1s, but I know Enkei makes most of Honda's / Acura's wheels. I'm just not a fan of the open center.
CyberCT is offline   Reply With Quote
Old 09-04-2013, 04:45 PM   #26
CyberCT
Drives: RSX
I just called Enkei and apparently the difference between the RPF1 and PF01 cenerbore is 4mm, so no the PF01 centercaps won't fit unfortunately Gonna have to figure out a way to make it look nice and clean without the hole in the center.
Old 05-09-2014, 10:52 PM   #27
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
Anything ever come out for caps? Tire rack offers some, but they look pretty bad.
Quentin is offline   Reply With Quote
Old 12-11-2015, 11:40 AM   #28
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Enkei RPF1 17x7 +42 (stock height)
More reference photos:
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
The Following 5 Users Say Thank You to LOLS2K For This Useful Post:
D_Thissen (12-30-2015), Keenercarguy (01-01-2016), Lonewolf (01-31-2016), Mr.Impreza (12-17-2015), TofuJoe (01-23-2016)
Wheel Directory: Enkei RPF1 17x7.5 +48 Guillaume Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 04-12-2021 04:30 PM
Wheel Directory: Enkei EV5 17x7.0 +38 rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 12-17-2016 11:47 AM
Wheel Directory: Enkei RPF1 Type-II 17x7.0 +48 hankster Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 10-05-2013 02:23 AM
Wheel Directory: Enkei FLC-01 17x7.0 +40 Mr.Jay Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-09-2013 03:44 PM
Wheel Directory: Enkei WTE II 17x7.0 +41 stout90 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 01-06-2013 10:18 PM
