#15 | |
Drives: 2014 Subaru BRZ
For sure clean our filters with foam filter cleaner, we use the Uni Filter cleaner, and it works great! Normally they only need to be cleaned every 7-10,000 miles or so. |
#16 |
Drives: '11 535i
It may seem like a tighter fit if it is not sitting in the air box correctly and the bottom hinges are not lined up. The best way to ensure that it is seated correctly, is to simply remove the air box from the vehicle and install the filter and then reinstall the air box.
| The Following 3 Users Say Thank You to PERRIN_Mladen For This Useful Post: |
#17 | |
Drives: Skoda Yeti DSG diesel 4x4
Thanks. I found one. [ame="http://www.youtube.com/watch?v=xvtDj37Dp-0"]True Flow Filter Comparison Video - YouTube[/ame] Last edited by sierra; 02-27-2013 at 08:52 PM. |
#18 |
Drives: '11 535i
#19 |
Drives: Whiteout FR-S 6spd
Not meaning to thread jack or anything but is the HKS drop in the same foam/build pretty much as the perrin?
#20 | |
Ridge Racerrrrrrrrr
Found it for ya!
#21 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
#22 | |
The filter was certainly oiled when I got it because I kept it in the spare room with the Nameless exhaust and you could smell the oil, even through the plastic bag it was in. That shows how important it is to get it right re-oiling because done right it filters perfectly without releasing any oil. |
| The Following User Says Thank You to sierra For This Useful Post: | Turdinator (02-28-2013) |
#23 |
Drives: MT WRB BRZ Limited, 2007 911s
Just installed mine. Taking out the airbox and then replacing it is DEFINITELY the way to go with this. Three bolts to get it out and way easier than trying to shove it in through the narrow opening with it in.
#24 |
Drives: Black 86
How does it feel? Pulls harder? Did you reset the compbox? Via unplugging the negative batt terminal?
#25 |
#26 |
Drives: 2013 Whiteout FRS
looks like i'll have to go with perrin.
#27 |
I reset my ECU a month ago, just to see what would happen.
I regretted doing it as soon as I drove it after letting it idle for the prescribed time. It was flat and the throttle pedal delay was back almost as bad as when it was first learning out of the showroom. There was a noticeable loss of power at the top end but it's all come good after taking some time to optimise itself again. It wasn't in my head. I was expecting a power gain and the fact that it lost power stood out like dog's balls and I was instantly depressed in case it stayed that way. Luckily it didn't! How that relates to resetting the ECU on the dyno you have to wonder? |
#28 |
Drives: Black 86
Thanks for the tip. Now I am hesitating on doing the ecu reset...but a lot of people do it before doing dynO runs....hmmmmm
| cosworth panel filter | BadLuckZN6 | Engine, Exhaust, Transmission | 9 | 03-27-2013 11:13 AM |
| FA20CLUB AVO Silicone Intake Tube & Panel Filter Sale $190.00 Shipped | FA20Club.com | Engine, Exhaust, Bolt-Ons | 2 | 02-08-2013 07:24 PM |
| What's better HKS, greddy or perrin oil filter? | J-Money | Engine, Exhaust, Transmission | 3 | 01-19-2013 11:11 PM |
| FS [WA] AVO Panel Air Filter | stevo_12v | Australia Classifieds | 2 | 10-19-2012 11:26 AM |
| AVO High-Flow Panel Filter! | AVOturboworld | Engine, Exhaust, Bolt-Ons | 0 | 08-24-2012 07:02 PM |
