Old 02-14-2013, 09:46 AM   #15
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Yes, the power starts to flatten out at 7000-7200 and then tapers at 7500 depending on what type of fuel and how much timing is added. It is not wise to rev a motor past its powerband. We always set the rev limiter higher just to sample it on the dyno and then go back and set our limits.
We are working on some cams to test and hopefully make this thing breath past 7500 effortlessly.
FullBlown is offline   Reply With Quote
The Following 4 Users Say Thank You to FullBlown For This Useful Post:
Pure Automotive (02-14-2013), Sportsguy83 (02-14-2013), Tansey86 (02-14-2013), TyperRspec789 (02-14-2013)
Old 02-14-2013, 09:56 AM   #16
fenton
Thanks for the answers
fenton is offline   Reply With Quote
Old 02-14-2013, 12:01 PM   #17
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Are you guys just regrinding the stock cams or are you guys gonna make your own new cams
Tansey86 is offline   Reply With Quote
Old 02-14-2013, 12:38 PM   #18
FullBlown
FullBlown's Avatar
Drives: Scion FRS
regrind till we find the right combo.
Old 02-14-2013, 12:51 PM   #19
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
dig it.
TouchMyHonda is offline   Reply With Quote
Old 02-14-2013, 01:24 PM   #20
swift996
swift996's Avatar
Originally Posted by fenton View Post
How come you aren't tuned out to 8000rpm or a little above like the other kits?
Is it your fuel or something that is stopping you or just personal preference?
Thanks,
A larger bore x stroke ratio would help achieve this. There are only a handful of squared motors that run to 8K rpms. The piston speeds get too fast too quick.
In fact, the only 3 engines that I'm aware of that run to 8K with a bore x stroke that isn't over squared (over 1:1 ratio) are:
- B18C (Honda - GSR) 81mm bore - 87mm stroke
- K20 (Honda - RSX/Civic Si) 86mm bore - 86mm stroke
- 2ZZ-GE (Toyota - Celica GTS/Lotus Elise/Exige) 82mm bore - 85 mm stroke
They all have very sophisticated head work with special camshaft/valve lift designs.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-14-2013, 01:45 PM   #21
OrbitalEllipses
Drives: Attitude
Be my valentine?
Old 02-15-2013, 11:40 PM   #22
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
Updated with gas mileage data.
TyperRspec789 is offline   Reply With Quote
Old 03-08-2013, 04:17 PM   #23
TyperRspec789
3/8/2013 Update:
- RPF1 staggered setup w/ BFGoodrich KDWs- 255 on 17x9 rear, 235 on 17x8 front
- 2.75" Overpipe-back exhaust- J2 Engineering test frontpipe mated to Greddy Evo3
- Front grille removal w/ Perrin license plate relocator
- Custom intake air inlet
- GT86 Fog bezels
And yes... My car looks like a Hitler FRS... Why? Because... Fuctional.
The Following 4 Users Say Thank You to TyperRspec789 For This Useful Post:
cmss2000 (03-08-2013), ftc~brz (04-04-2013), NorCalRider (03-09-2013), Sportsguy83 (03-08-2013)
Old 03-08-2013, 04:32 PM   #24
Opposed
Drives: 2013 Asphalt FR-S
Car looks great man! I will be having some work done at Fullblown on Tuesday. You better convince me NOT to spend my tax money on a turbo kit...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 03-08-2013, 04:45 PM   #25
TyperRspec789
It's the best kit on the market.. Hopefully, that helps!
The Following User Says Thank You to TyperRspec789 For This Useful Post:
crook (03-08-2013)
Old 03-08-2013, 04:49 PM   #26
Opposed
Ugh, I already knew that, so no, it didnt help Glad to see your enjoying it and I look forward to more long term reviews. Do you daily drive this car? Im looking overall for long term. It will be drivin all year round, and in Minnesota, that means 90 degrees and humid in the summer, below zero digits during the winter peaks, and everyting in between. I don't have any doubt that they wouldn't produce a quality kit that wouldn't hold up.
Old 03-08-2013, 05:01 PM   #27
TyperRspec789
I believe I have around 1300 miles since being turbo'd. The only reason why I haven't driven more is because I've been prepping the car to compete at a drag racing competition in MD. I did a lot of trading/selling/buying to accommodate the extra power. But honestly, it's a suitable daily driver. The only altering factor is your clutch selection. I hated my ACT 6 puck at first, but I got used to it.
Do you have another car? I mostly drive my WRX to keep the miles down on my FRS (the car is too damn enjoyable to drive...)
Old 03-08-2013, 05:22 PM   #28
Opposed
I do not. I use to have a Civic for a daily driver when I had my S2k, but part of my excuse to by a new car was to not have two cars anymore and go down to one, so the FRS will remain my daily. I have considered the clutch thing. LJ told me we would just keep the boost down to around 250-260 whp to make the stock clutch last as long as possible. But yet, I wouldn't want a clutch that would be annoying to drive daily. Excited to see what kind of times you can pull off at the track! Good luck!
The Following User Says Thank You to Opposed For This Useful Post:
TyperRspec789 (03-08-2013)
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
Full Blown Motorsports Stage 1 Turbo Kits PROVEN POWER!@ Pure Automotive Performance Pure Automotive Forced Induction 86 11-26-2013 08:27 AM
AVO Turbo Kit Stage 2 - work in progress AVOturboworld Forced Induction 202 06-18-2013 12:35 PM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Forced Induction 68 02-25-2013 12:06 PM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Mid-Atlantic 61 01-30-2013 08:38 PM
