Old 02-12-2013, 12:04 PM   #15
TCHawk
TCHawk's Avatar
Drives: Ultramarine FR-S
Like everyone else has said keep practicing. I'm in the same boat with 2nd. Sometimes it's good sometimes not so much but this is my first manual and I learned in it so keep at it because it's that much more rewarding when you everything clicks in place.
Also once your car is a bit more broken in you may be able to feel the catching point a bit more. My clutch feels way different from when I first got it (though could just be all the practicing too, lol. I'm At 2700 currently today)
TCHawk is offline   Reply With Quote
Old 02-12-2013, 12:39 PM   #16
Colominicano
Colominicano's Avatar
Drives: 1997 Honda Prelude 5spd
Just more practice man. Got to find the right release point in the clutch while applying gas. The more you drive, the better you'll get at it.
Don't worry so much about accelerating faster cause of the people behind you. They can either wait or switch lanes. Focus and feel your your clutch.
Colominicano is offline   Reply With Quote
Old 02-12-2013, 12:49 PM   #17
Ingen
Drives: Ultramarine FR-S 6MT
I've found it helpful to lift my heel up and bend at the knee slightly when releasing the clutch. I dunno why, but the ankle-pivot throws me off sometimes. I'm planning to do the clutch mod as soon as I get a nice warm day to play with it.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 02-12-2013, 01:05 PM   #18
whtchocla7e
Drives: 2013 FR-S Hot Lava
This is my first MT also and the 1-to-2 shift is something I still can't get right all the time. Any other up-shift is no problem.
I had to develop a whole separate technique for the 1-to-2 and in the process, I learned that it actually makes the other shifts better as well... lol
In other words: practice and experience.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 02-12-2013, 05:59 PM   #19
Carbon420
Drives: 2013 FR-S Raven with carbon fiber
It was about 1500k befor I got the hang of it and still do it from time to time. As long as your still only shaky and not stalling your doing good. But simply try to have it at atleast 1500 rpm befor you let the clutch out enough to grab.
Carbon420 is offline   Reply With Quote
Old 02-12-2013, 06:36 PM   #20
Colominicano
Today I test drove the FR-S and I must say that even I had a hard time getting use to the clutch. The clutch on this car is VERY soft compared to the one in my Prelude. Took me awhile to get use to it. Make sure you practice and try not to gas it above 1500RPM while releasing the clutch.
Old 02-12-2013, 06:49 PM   #21
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
plz direct your attention here. the first to second gear shift is common for all our mts. you can read this thread or continue to work too hard to shift in and out of second. good luck
http://www.ft86club.com/forums/showt...t=gear+synchro
bdanisi is offline   Reply With Quote
Old 02-12-2013, 06:59 PM   #22
luuser75
luuser75's Avatar
Drives: M/T Raven FR-S
do you have pentosin in your tranny? i noticed that you're in socal also and was debating on which fluids to swap in. I assumed that it doesn't get that cold down here compared to other regions therefore I thought thinner fluids wouldn't be necessary.
luuser75 is offline   Reply With Quote
The Following User Says Thank You to luuser75 For This Useful Post:
5th 86 (06-17-2013)
Old 02-12-2013, 07:20 PM   #23
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
the thing is cold is subjective, but not for this car, imo under 50 its a pain to get into second. even when its warm like 80 outside getting in and out of second is still vastly too rough. im in oc, if youd like to drive my car to see the buttery smoothness yourself ill show you.
Old 02-12-2013, 08:42 PM   #24
ThePoet
Drives: Scion FR-S
The 1-2 shift in this car is abnormally tricky to get completely smooth. I think it has to do with the fact that the ratios between the two gears are so far apart you could drive a truck through them, mixed with the revs not falling off quickly enough after you depress the clutch. (It holds them for just a second after you press the clutch, and it pisses me off)
ThePoet is offline   Reply With Quote
Old 02-12-2013, 09:02 PM   #25
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
practice practice practice ..then do the mod. It's worth it.
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 02-12-2013, 10:04 PM   #26
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
I must be getting old. I saw "Jerky / shaky sharts"
Don't overthink it, that's what usually causes it and prolongs the learning curve. Eventually, with enough practice it will all fall into place for you.
CircuitJerk is offline   Reply With Quote
Old 02-13-2013, 12:08 AM   #27
Travis
Travis's Avatar
Drives: FR-S 6MT Whiteout
The car has an awkward clutch plain and simple. 1st gear is tough to get smooth regardless of your practice with the car or manual transmission experience
Follow me on Instagram @filthytravis
Travis is offline   Reply With Quote
Old 02-13-2013, 01:08 AM   #28
Mandy
I came from a motorbike
Mandy's Avatar
Drives: Firestorm 2013 FR-S 6MT
I was dropping off my girlfriend today, and I was low on gas, so I figured that I would grab a tank, and then on my way home, I decided to have some fun, and play around with starts from a complete stop and shifting into second.
Now personally, the way I found it easiest to get consistent, smooth, starts from a complete stop is too try and keep your RPMs as close to 1000 as possible until you fully disengage the clutch (should happen around 6MPH), and then you give it a little gas. Blipping the throttle or easing out the clutch before giving it gas generally wound up in rough starts.
As for 1st to 2nd, it's still a work in progress for me. I generally wait for the RPMs to drop a bit while fully depressing the clutch, if I'm consciously thinking about it; however, I never consciously think about it whilst driving.
That's just my sub-500 miles experience. I'm sure I'll have a revelation, but I did find I drove better after having a beer. Please take that advice with a grain of salt, I'm not encouraging driving with alcohol in your system, but it helps to take the edge off.
Mandy is offline   Reply With Quote
2011 Nissan GT-R Pricing Starts at $85,060 vh_supra26 Other Vehicles & General Automotive Discussions 195 05-18-2023 09:12 PM
Evasive Motorsports Project BR-Z officially starts now!!! Evasive Motorsports BRZ Photos, Videos, Wallpapers, Gallery Forum 154 09-30-2014 04:23 AM
Cold morning starts coldy CANADA 43 04-23-2013 02:30 PM
Issue: Cold starts jesseps CANADA 7 11-24-2012 11:26 AM
I Hope FR-S Pre-Ordering Starts Soon! Jokester Scion FR-S / Toyota 86 GT86 General Forum 15 02-22-2012 10:07 AM
