#15 |
Drives: 2013 FR-S AT Argento
[quote=ayau;721205]Said it before I could. I do lots of short commutes and am glad 0 weight oil is doing its job as soon as possible. Agreed, heavier oil for short commuted is a mistake.
#16 |
Drives: Some rust bucket
#17 |
Kurenai Samurai
Drives: Red and manual
its almost as if the engineers knew what they were talking about...
| The Following 3 Users Say Thank You to driftartist For This Useful Post: |
#19 |
Could you mix them together? Say 1-5 bottles of 0W20 1-5 bottles of 5W30. So a total of 6 or whatever the recommended amount is.
#20 |
Drives: .
#21 |
Not sure what your goal would be to mix the different oils. I believe the owners manual recommends you to use the same oil unless you can't find the same weight oil.
#22 | |
I believe 0w-20 and 0w-30 will still have different room temperature viscositities. 0w-20 should be thinner at room temperature, therefore, will be "better" for your engine at startup. Bobistheoilguy.com stresses that no matter what oil you put into your engine, it's still too thick at room temperature. I think it's safe to assume that Subaru has the most knowledge about their own engine. If they recommend 0w-20, then you should stick to that under normal driving conditions. The only exception would be if your oil temperature runs very hot due to tracking the car (very low population), then you may want to consider 5w-30 to reduce shearing. |
| The Following User Says Thank You to ayau For This Useful Post: | Huehuecoyotl (03-25-2013) |
#23 |
#24 |
Drives: '89 911, '06 GTI, '13 BRZ
Is that in the owners manual? I wonder what is called for in the Arab states?
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe 2006 VW GTI/DSG 2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten 2014 Nissan Murano SV |
#25 | |
Drives: 2013 BRZ Ltd. MT
The difference in oil spec is, I suspect, due to less government interference, and fewer eco-maniacs, and Tree Huggers. This permits the engineers to specify the more suitable oil weight, not needing to live up to any fuel economy constraints. They’re more free to spec the oil that protects the engine BEST. |
#26 | |
A 5W-20 can also have less evaporation loss than most 5W-30's (measured by NOACK volatility). -Dennis |
#27 | |
Drives: Scion FRS Ht Lva(AT)
#28 | |
A nominate you to do a uoa every 1,000 miles, for a range of different muti-viscosity oils, to see if the viscosity changes. . -Dennis |
| Safe to use DOT 5.1? | mechaghost | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 10-27-2015 04:32 AM |
| Be Safe! | Mr. J | BRZ First-Gen (2012+) — General Topics | 21 | 11-21-2012 06:46 PM |
| Safe at the Dealership? | BP1913 | BRZ First-Gen (2012+) — General Topics | 19 | 06-18-2012 05:52 PM |
| Safe to wax new car paint? | Nitro | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 06-09-2012 02:08 AM |
