Old 03-03-2013, 10:40 PM   #15
Vanga
Vanga's Avatar
Drives: 07 Hyundai Tiburon SE
Originally Posted by infinite012 View Post
You didn't have to cut the moisture barrier... it has that black goop/gummy stuff that will allow you to pull off the moisture barrier and stick it back on.
I'm sure you could definitely take a heat gun to undo that black silicone, do whatever work you need to do and then use the heat gun again to re seal it, I just didn't think about that at the time. Either way it will work.
Vanga is offline   Reply With Quote
Old 03-04-2013, 08:58 AM   #16
infinite012
Drives: 13 DGM BRZ Ltd
You can pull it off without a heat gun. In fact, using a heat gun will just make it a terrible mess.
But yeah, I'm not going to comment on the lights in the door speaker grill since it's not my cup of tea.
infinite012 is offline   Reply With Quote
Old 03-04-2013, 02:29 PM   #17
Vanga
Vanga's Avatar
To each their own!
Old 09-02-2013, 08:11 PM   #18
Imperius
Imperius's Avatar
Drives: Subaru BRZ
Can you connect this controller to Acc
so every time you switch the ignition the leds will go on with the rest of the lights ?
OR
do you have to use the remote every time ?
Imperius is offline   Reply With Quote
Old 03-15-2014, 10:40 AM   #19
sirisvirus
Drives:
Sent from my Subaru BRZ Limited using plastic cup 2.0
sirisvirus is offline   Reply With Quote
Old 03-15-2014, 03:05 PM   #20
SixthElement
Drives: 2013 black limited
You're correct sir. It would be much better for others who try this to not cut the plastic.
If you simply pull the plastic a little so the black "tar" starts to stretch you can cut it apart with a razor blade and when you are done it sticks right back to itself with no need for a heat gun at all.
Looks cool, good write up!
SixthElement is offline   Reply With Quote
Old 05-29-2021, 04:33 AM   #21
ojuniour
ojuniour's Avatar
Drives: Subaru BRZ 2017
and better yet.. you could have just tapped into one of those wires for power instead of running the wires for power source back ..
ojuniour is offline   Reply With Quote
door speakers not working number1Tango Electronics | Audio | NAV | Infotainment 23 04-03-2022 08:03 PM
wire routing for door speakers derka-derka Electronics | Audio | NAV | Infotainment 6 12-13-2012 10:49 PM
Front door speakers. Calum Electronics | Audio | NAV | Infotainment 5 08-11-2012 05:49 PM
Just replace door speakers? industrial Electronics | Audio | NAV | Infotainment 0 08-02-2012 03:57 PM
Installed new in-dash, lost sound from door speakers Nitro Electronics | Audio | NAV | Infotainment 2 06-04-2012 09:53 PM
