#15 |
Drives: Frs
#16 |
Drives: Frs
Hey Joe, thanks. Yes, running on Tien street basis. They run great, although i have this clunking noise on front passenger side. This noise comes when i make a turn on low speed. Seems like the coils dont sit and rattle. Its only that side
#17 | |
Drives: Frs
Sorry, i don't know all the specifics. I didnt get to weigh em since i was stoked and in a hurry to put them on. |
#18 |
Drives: Frs
#20 | |
Drives: Frs
Thanks! Go for it! I first saw them in person on a whiteout.. Its lowered all the way down so can't get any lower. I think they just sit right. Concave gives that aggressive look with this set up even if it pokes out. Here's that pic of the whiteout that convinced me pick up these wheels the following day.. |
#21 |
Drives: Frs
#22 |
NW Region Moderator
Drives: FR-S No More
Combined topics: same wheels with same specs
#23 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
18x9.5 +40 265/35/18 FITTED
brought to you by @AZP Installs give them a shout if you need anything, ESPECIALLY alignments and track prep.
18x9.5 +40 semi gloss black Rays Gramlights 57xtreme 265/35/18 Bridgestone Potenza RE-11 okay here are some recent updates so that people who run something similar dont run into surprises, might as well use my experience to help. First of all, YOU WILL RUB at first. its the plastic part of the rear bumper, its not a big deal and will rub itself out of you can dremel it. (the corner to the bumper inside the fender) Second i had an issue with my passenger fender, it rubbed on the part closest to the sidemarkers. if you feel the fender there, it isn't rolled anymore and flares out, you want to roll that part in to avoid any issues in the future or else you risk chipping the paint or gashing the tire....i luckily caught it early. Third, and probaby most important. once we let the KW's settle we had to take camber out. it settle to around -3.5' in the rear. i did not want to run that much at all, nor do i need that much for clearance issues. we maxed out the camber arms (cusco) which net me a minimum or -2 degrees. once we set the camber to -2 the stock toe arms were simply not enough to fix the toe issue thus i had to order whitline adjustable toe arms. I WILL UPDATE WITH MY FINAL ALIGNMENT SPECS...for now i'm waiting for a few things to be done/come in for the car until i get to drive it and get it back on the alignment rack... ![]() ![]() ![]() ![]() ![]() __________________________________________________ ____________________ ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() __________________________________________________ ______________________ some photos from the cars and coffee meet sunday, car was filthy photo credit to: http://www.facebook.com/ColorCinemaProductions ![]() ![]() ![]() ![]()
| The Following 57 Users Say Thank You to Jive Turkey For This Useful Post: | adprokid (03-25-2013), AE86guy (03-25-2013), Alfalasy (04-15-2013), armythug (03-27-2013), Asphaltfrs1 (04-26-2013), Bcarlos (04-10-2013), bcmakesiteasy (05-01-2013), Beyer Subaru (03-25-2013), Brzzee (04-09-2013), CamryDS (04-17-2013), Cesium Rainbow (08-22-2013), charged86 (04-13-2013), chenshuo (04-11-2013), cocoy_labuyo (05-02-2013), DAEMANO (08-01-2013), DjDATZ (04-11-2013), djdnz (03-25-2013), F1point4 (04-15-2013), FriedRicr (05-26-2013), FT_86_SM_GP (11-18-2014), GaN-MaN (04-13-2013), glorydays (04-20-2013), GregV (03-25-2013), Guff (04-18-2013), HATED1 (03-24-2013), hippari (03-25-2013), horrorbiz (06-07-2013), JDMenrique (04-10-2013), jdzumwalt (03-28-2013), JEFFSTYLE (08-12-2013), Jesse (03-27-2013), Jlturner (04-09-2013), karma003 (04-09-2013), killerkid08 (04-08-2013), MaXimus (03-26-2013), mrxchris (02-20-2015), niceguy21 (04-24-2013), nix (03-25-2013), NorCalRider (03-27-2013), NorseLegend (03-27-2013), oaroyale (03-25-2013), Octoman (07-27-2014), PRORICAN (03-25-2013), R2RO (03-28-2013), SalM (06-03-2013), ShoGun (04-09-2013), ShoNUFF (03-25-2013), Skywgn1 (04-11-2013), SnapOv3st3r (04-22-2013), Spartan65 (04-25-2013), sprintertrueno86 (03-26-2013), SVTSHC (04-04-2013), tranat (04-29-2015), tripjammer (03-26-2013), usptwins (04-09-2013), white_knight (03-28-2013), YW-Slayer (05-20-2013) |
#24 | |
the tuna, no crust.
whitline com C front top hats 2011 sti rear top hats cusco lower control arms. running -2 all around. NO issues. the only place it rubbed was the rear bumper, but that rubbed itself out ![]() i plan on taking some camber out of the rear. -2 is too much IMO. |
| The Following 3 Users Say Thank You to Jive Turkey For This Useful Post: |
#25 |
Ontario's FT86
Drives: 2016 Lexus GS-F
Thanks, definite one of the best looking brz simple and clean
#26 |
Drives: 2003 Subaru Outback
I look forward to seeing this with less camber, not a huge fan of that look. Even so it looks great right now. With this setup would a 275 or 285 wide tire work in the rear? Any pics of clearance to the coilover front and back?
#27 |
Drives: Raven Scion FR-S
275/35s could def fit the rear without any camber or drop at all on the car, I currently run 265/35-18 on a 18x9.5 +38 wheel and there's alot of room
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
#28 | |
Drives: BRZ WRB
looks sick! how much of a drop? I'd be quite conservative running 255\35\18 with same 57xtremes 9.5" ET40 in the rear ) I wounder how negative should I camber them |
| Tags |
| gramlights 57xtreme, toyo tyres |
| Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 | L8Apex | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 71 | 08-05-2023 10:20 PM |
| Wheel Directory: Gram Light 57Xtreme: 18x8.5 +33 / 18x9.5 +40 | jadewbj | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 378 | 06-26-2017 06:57 AM |
| Wheel Directory: Gram Lights 57Xtreme 19x9.5 +43 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 12-04-2014 11:56 PM |
| Wheel Directory: Gram Lights 57Xtreme 17x7.0 +42 | MVJ1975 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 10-05-2013 03:29 AM |
| Wheel Directory: Gram Lights 57Xtreme 18x7.5 +40 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 09-05-2012 01:44 PM |
