Old 04-19-2014, 08:09 AM   #15
MightyMeeple
Slower than Fast
MightyMeeple's Avatar
Drives: BRZ Limited 6MT
So I finally made my decision and have upgraded wheels and tires. I went with the exact same setup as the OP (@FRSFirestorm).
My goals were to get a quality wheel with a weight savings compared to stock and achieve
a better looking offset than the stock wheels provided.
This setup accomplishes all those goals and I'm very pleased with how they look. I haven't had any time to really drive and get a feel for how the wider/better griping tires. There is an immediate difference in steering feel....feels more weighty/heavier. This isn't unexpected, but will take some getting used to. Onto the obligatory pics:
Front wheel offset is just slightly tucked...which to me is perfect. No camber adjustment here.
Edit: 23Apr2014 - by request ( @Caboose ) am adding some 3/4 shots...sorry for crappy phone pics:
MightyMeeple is offline   Reply With Quote
Old 04-19-2014, 03:21 PM   #16
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Nice.
Any have pics of these, or have them, in a wider and/or lower offset? Maybe around a 9" et35?
I'd wanna see if they have flatter/concave spokes and a deeper lip in a lower offset (maybe similar to all the rpf1 9" et35)
fooddude is offline   Reply With Quote
Old 04-20-2014, 10:10 PM   #17
MightyMeeple
Slower than Fast
Originally Posted by fooddude View Post
Nice.
Per the enkei site, this wheel isn't made in a 17x9.
Old 04-30-2014, 03:29 PM   #18
fasteddy
Can you comment any more on the change in the steering feel? I am looking at getting this exact setup. Do you think it is because of the additional tread width, or offset difference? I would think it may feel lighter as they weigh less?
Thanks.
Pat
fasteddy is offline   Reply With Quote
Old 04-30-2014, 05:20 PM   #19
MightyMeeple
Slower than Fast
Thanks.
Pat
Sure. I think it's actually due to both the offset and additional tire width that I'm running. I can say that I've already gotten used to the change, and don't consider it a negative whatsoever. You will notice it the first couple times you drive the car, but you will adjust quickly to it. The increased grip, and the vastly improved ride quality are very much worth it.
As for the weight savings...I've read on the forums that reduced weight in the wheels and improved grip with better rubber should help with acceleration and braking, but is hard to truly notice when driving. I must say that acceleration does feel more brisk to me with this new setup; I would call it very noticeable, but concede were not talking about shaving seconds off your 0-60 times. But I admit I wasn't expecting to really notice this benefit and have been pleasantly surprised by it.
Bottom line: great upgrade for my car, and am very glad I did it.
Old 04-30-2014, 05:35 PM   #20
fasteddy
Thanks for the reply Meeple! I originally had been considering the wheels with the 45 offset instead of the 38 offset to stay closer to stock. I have since figured I would want the extra clearance with the 38 as the rim is a little wider and and the 225 tire is a bit wider as well.
I am going to get these ordered up!
Pat
Old 04-30-2014, 05:45 PM   #21
MightyMeeple
Slower than Fast
Pat
Sounds great; post up some picks once you have them mounted!
Old 08-16-2016, 09:23 PM   #22
Kuya Moose
Drives: Pontiac GTO, Subaru Outback
So no rubbing on hard corners (like U-Turns or tight autocross corners), correct?
Kuya Moose is offline   Reply With Quote
Old 06-19-2017, 10:36 PM   #23
Subsonic
Subsonic's Avatar
Drives: Toyota 86 GTS
+45 Offset version
There is a +45 offset for this wheel as well, there doesn't seem to be another thread for it so I've attached a pic of mine here anyway.
I chose this wheel for it's closeness to the original spec and lighter weight compared to the original. On my household scales they are about 1.8kg lighter than the OEM wheel. I think they suit the car really well. I like these wheels a lot so far.
Michael.
Subsonic is offline   Reply With Quote
The Following User Says Thank You to Subsonic For This Useful Post:
Cheeky (12-07-2018)
Wheel Directory: Enkei EV5 17x7.0 +38 rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 12-17-2016 11:47 AM
Wheel Directory: Enkei Fujin 17x7.5 +40 Grateful Dave Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 57 05-04-2016 09:26 PM
Wheel Directory: Enkei GTC01 17x7.5 +48 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 07-16-2014 02:59 AM
Enkei PF01 Evo wheel interest JoeBoxer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 06-19-2014 09:30 PM
Wheel Directory: Enkei FLC-01 17x7.0 +40 Mr.Jay Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-09-2013 03:44 PM
