#15 |
Drives: 13 whiteout scion frs
Wait for whiteline
#16 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
The Perrin bars are solid and rear fitment only, so I won't even consider them - even though there is nothing wrong with the bar from a design or manufacturing standpoint.
Hotchkis makes very good hollow anti rollbar sets. I had a '98 V6 Camaro track car that I put the Hotchkis Sport set anti rollbar (fairly big too at 1-7/16" front and 1" rear), stripped out with Koni Sport dampers on stock springs, spherical ball end rods for the rear suspension. All the camaro guys on forums said it was too much swaybar for stock springs and would only be good for autocrossing, being too unstable for track. Well it handled beautifully even though it was still a heavy pig at ~3200lbs, was perfectly stable and nearly perfectly balanced on track. I like a car I can control with minimal inputs, the more 'sensitive' the better, as long as it's stable and not a chore to control. I do plan on getting the Hotchkis Sport adjustable set for the FR-S... $370 is not a bad price point either. Probably will spend extra and go with the billet brackets as well. ![]() Specifications: Front 1” (25.4mm) Tubular 2-Way Adjustable 500 lbs/in (170 % Stiffer than Stock) 630 lbs/in (245 % Stiffer than Stock) Rear ¾” (19mm) 4-Way Adjustable Blade Style with End Links 320 lbs/in (200 % Stiffer than Stock) 405 lbs/in (275 % Stiffer than Stock) 520 lbs/in (385 % Stiffer than Stock) 700 lbs/in (550 % Stiffer than Stock) Note: Looks like the rear bar fitment for the FR-S may be solid though...hmmm... not good, will need clarification.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#17 | |
Drives: BRZ DGM
| The Following User Says Thank You to Coastermikey For This Useful Post: | Racecomp Engineering (12-15-2012) |
#18 | |
- Andrew |
#19 |
Looking to see some 22mm/16mm adjustable solids, for track use with R tires for max grip...if you plan on a front rate in the mid 400's, figure 440lbs front as a departure point, I will tune down the rear accordingly, presently considering a 430 rear as a departure point. Rear holes on sway should be close together and triple adjust if possible for fine tuning. Front can be spaced with the preference for a longish arm 'far hole'.
Curious what RCE thoughts are, and likelyhood of you REALLY makeing a sway set for the trackster. 20/16's are already available and fine for the DD or DOT trackster at lower rates. I dont want a hollow bar to try and save 1lb, over a solid one. not I. |
| Hotchkis Sway Bars-Group Buy!!! | FBPARTS | Groupbuys | 162 | 11-19-2013 05:23 PM |
| Cusco Sway Bars? | wootwoot | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 08-04-2012 06:31 AM |
| Perrin Rear Sway Bars at Redline360 | Redline360 | Brakes, Suspension, Chassis | 0 | 06-28-2012 11:38 PM |
| adjustable sway bars!!! | carbonBLUE | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 05-04-2012 09:42 AM |
