Old 12-14-2012, 09:23 AM   #15
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by F n' A Automotive View Post
Hahahha it's all good man! No blaming or anything going on from either end either lol. I read that diagram and see where it goes to and everything, it just sucks that the car we worked on didn't have it and theres no limited BRZ's that I can get in our shop to take a look. Pictures will help, but that still won't put the problem in front of me to work on it, to try and fix it, which sucks. So the best bet will be, take pics and when your free to work on it, call me (you should have my number), and we'll try to figure it out over the phone.
Thanks
Sounds like a plan, Thanks!
Old 12-14-2012, 12:23 PM   #16
jazztennor
jazztennor's Avatar
Drives: Scion FR-s
Interesting i hope your car doesn't go back into lip mode. I wonder if anyone else has had this problem. I want to do this mod but i don't want that to happen.
Upgrades
EVO 3 Exhaust,Emblem swap,Full Carbon Interior,Greddy intake
jazztennor is offline   Reply With Quote
Old 12-14-2012, 12:40 PM   #17
Sportsguy83
Drives: Limited BRZ
You would be fine, the problem I am 99% sure has to do with the BRZ Push Start Key Fob, because in my car there is an antenna in the bumper and the wire runs through the grommet you would use. For the FR-S, that grommet has no cable running through it so you should be good to go.
Old 12-14-2012, 12:47 PM   #18
F n' A Automotive
F n' A Automotive's Avatar
Drives: 11 STi Sedan
Your car doesn't have the cable running through the grommet like he stated, the cable is specific to BRZ Limiteds. If you'd like a kit, feel free to shoot me a pm and I'll get you an invoice.
We'll get it figured out.
F n' A Automotive is offline   Reply With Quote
Old 12-14-2012, 12:52 PM   #19
johnb831
johnb831's Avatar
Drives: SWP 2013 Subaru BRZ Limited
yea mine has the cable running through it too. I put a little slit through the grommet and put the wires from the kit through it. I haven't really driven the car since i installed it but i will update if the lights do go on again.
johnb831 is offline   Reply With Quote
Old 12-14-2012, 01:17 PM   #20
OrbitalEllipses
Drives: Attitude
For proper draining of the battery: unhook negative lead, press brake pedal. Powering the brake light should drain any residual charge faster than waiting 5 minutes.
I'm bad with wiring diagrams (though this service manual is lightyears ahead of my GD Impreza wiring diagrams) so I'm not sure where to follow up on WHAT that key antenna is/does, though the word "key" is key here. Hehe, stupid pun.
Old 12-14-2012, 01:25 PM   #21
Sportsguy83
Drives: Limited BRZ
The Limited Key Fob has a transmitter and that cable ends with an antenna that picks up the key fob signal. This will let the car know the Key Fob is close so it is ok to allow the trunk to be opened via the trunk release.
Old 12-14-2012, 01:26 PM   #22
Sportsguy83
Drives: Limited BRZ
I did the same thing, and it was HARD. Last night I ended up cutting the grommet and tying the cable together. I will test it out like this and if they limp mode comes up again, I will insulate the cables and try again.
Old 12-14-2012, 02:30 PM   #23
johnb831
johnb831's Avatar
I just turned on the car this morning and drove around a bit just to make sure and no lights.
The Following User Says Thank You to johnb831 For This Useful Post:
Sportsguy83 (12-14-2012)
Old 12-15-2012, 12:09 AM   #24
Sportsguy83
Drives: Limited BRZ
@johnb831
Ok, I figured this out tonight. If you turn your car with the lights on (lights set to auto or completely on), the car goes to limp mode. My guess is that antenna cable in the bumper is extremely sensitive to any amount of electricity and since you are turning the car on with the taillights on, some electricity leaks to it, and it calls for the car to go on limp mode.
On the other hand, if you turn the car on with the headlights off, the car starts up and behaves normal, no limp mode at all.
Tomorrow I am going to use some heat shrink isolating tubes around the antenna cable to see if I can completely insulate it.
I will post updates here.
Good night.
Sent from my HTC One XL using Tapatalk 2
The Following User Says Thank You to Sportsguy83 For This Useful Post:
johnb831 (12-15-2012)
Old 12-15-2012, 12:19 AM   #25
johnb831
johnb831's Avatar
Sportsguy83 thanks for going through the trouble to figure it out.
Sportsguy83 (12-15-2012)
Old 12-15-2012, 12:25 AM   #26
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
@johnb831
Good night.
That's weird... I have started the car with the headlights on "Auto" before and there was no problem.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 12-15-2012, 01:04 AM   #27
Sportsguy83
Drives: Limited BRZ
Do you have a rear fog light kit installed like us, and do you have a limited BRZ?
Edit: I see you do have the limited BRZ. But this issue is specific for the rear fog light kit installed through the bumper grommet shared with the rear key fob antenna.
Old 12-15-2012, 01:09 AM   #28
DaJo
FT86Club Vancouver
DaJo's Avatar
Ahh!... Gotcha! I guess I missed the part where it says about the rear foglight kit...
My bad!
2000 MR-S 5MT
2010-2012
The Following User Says Thank You to DaJo For This Useful Post:
winter mode notFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 01-02-2013 03:59 AM
My Winter Mode M3MPHIS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 12-25-2012 12:41 AM
My limp speedometer bothers me FastLap Scion FR-S / Toyota 86 GT86 General Forum 29 08-27-2012 02:30 PM
snow mode = girlfriend mode? Nepenthe Scion FR-S / Toyota 86 GT86 General Forum 9 07-01-2012 03:02 PM
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 11:50 AM
