#15 |
#16 |
Drives: 2013 Raven FRS
no. I'm assuming you are thinking of real-time transmitting to him?
#17 |
Drives: 13 Asphalt FRS AT
Ooooo! Must... Resist... Purchase... Impulse!!!
#18 |
Drives: 2013 White Out FR-S
I already sent him an update about 30 mins after he emailed me but he sent his car to the dyno with a friend or someone else so i wasnt aware they were there. The new method im using requires all the E85 tuned cars to all be tuned again from a conservative starting point since now were arent using separate tunes for e85 and pump gas. Ecutek allows us to control the fuel system in a more effective manner now so matching with on fuel only conditions is much more simplified. Assuming I start on the rich side using logs is the only manner I have to dial in your tune for you car. I checked all our email correspondences and out of all of them you sent me only one set of logs which i have now supplied you with one update. I sent you that update the same time you dyno'd and today is the 8th and im waiting on a updated set of logs from you. Im always willing to work with all my customers as long as they are able to provide me c=viable information to work from. I honestly find it hard pressed that i knowingly ignored any of your emails.
Your factory wideband is fine for me to make changes but you have to remember just like i told you, it reads only 12.17:1 AFR at its lowest point so anything below that i have no idea what the afr is. So the best option is to do the logs what we discussed and email them to me. Im sure i can get you sorted in out in about 2-3 revising which would literally take you less than a day to record. I would rather trim fuel slowly than swing you to the lean side and hurt your motor doing so. Ill definitely get you sorted out I consider you guys like an extended family instead of a bad house guest
#19 |
Factory O2 is a true wideband? Will the stock ECU work with other wideband sensors that can read down lower?
#20 |
Small penis big dreams
Drives: '13 Scion FR-S
#21 |
I was amazed the first time myself. And his car isnt dialed in yet wait till its all said and done.
#22 |
Yeah, I need to stop being so busy, and so lazy when i'm not being busy.
#23 |
Drives: Whiteout FR-S
| The AVO CEL Saga | AVOturboworld | Issues | Warranty | Recalls / TSB | 41 | 04-23-2013 11:56 AM |
| Who's got the best ECU tune? | RYU | Engine, Exhaust, Transmission | 73 | 01-21-2013 10:24 PM |
| My sad saga | matthewl | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 11-27-2012 09:57 AM |
| Looking for a tune?? | TSLRich | NY / NJ / CT / PA | 0 | 08-01-2012 08:29 AM |
| My BRZ Saga | touge-n00b | BRZ First-Gen (2012+) — General Topics | 23 | 05-21-2012 10:17 AM |
