Old 01-04-2013, 03:54 PM   #15
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by nzer View Post
Yep, although the HKS OB-Link is awesome so if you want to measure stuff over time and be able to select different gauges it is still a good option even if pricy.
A gauge will need to be wired in rather than using the OBD2 connector unless someone can find the PID for oil temp. HKS must be using the non-standard Toyota oil temp PID and if we can find it out...
Here's my samsung 7" tablet running carscope paired with the HKS OB-Link. You can see oil temp is one of the gauges I have selected and it works perfectly.
Being boosted I absolutely need to know what my oil temp is at all times.
Old 01-23-2013, 03:23 AM   #16
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Finally an oil temp gauge that reads through the OBD2 connector.
Mounts in drivers side aircon vent but still allows the air flow
http://pivotjp.com/product/dual-gauge/img/DXW-e.pdf
nzer is offline   Reply With Quote
Old 02-04-2013, 07:01 PM   #17
nzer
nzer's Avatar
Did you chaps see this! Oil temp PID
http://www.ft86club.com/forums/showp...&postcount=123
Originally Posted by andreyiv View Post
Hey guys,
I found the Oil Temperature PID using TorqueScan and verified it by driving, as well as heating up only the oil temperature sensor area with the engine cold (and not running).
Without further delay, here's the info:
OBD2 Mode and PID: 2101
Minimum Value: -40
Maximum Value: 215 (this is just the maximum that this location can support, which does not mean the sensor can read that high)
Scale factor: x1
Unit type: C
Equation: AC-40 (no space between A and C; "AC" is the location within the response)
OBD Header: 7E0 (Auto also works, but seems to take longer)
Just as an aside, I don't know if it's my OBD adapter, or the Header needs to be tweaked (corrected), or if the response is not always long enough but every once in a while I'll get a reading of 189 or 1840 which are both incorrect. I'm not familiar enough with torque to figure out where these glitches are coming from.
Enjoy!
Andrey
The Following 2 Users Say Thank You to nzer For This Useful Post:
jonnyozero3 (04-19-2013), Sportsguy83 (02-04-2013)
Old 03-16-2013, 11:16 AM   #18
ICantAffordAnLFA
ICantAffordAnLFA's Avatar
Drives: Brz, Legacy
Has anyone used this on dash command
Need help with the object settings.
Trackday ride with built motor
Mods: Going, Stopping, Handling
Parts: CP, Pauter, Sprintex, Ecutek, Milltek, STI, Rays, Defi, Essex AP Racing, Bilstein, Whiteline, Perrin, RacerX
ICantAffordAnLFA is offline   Reply With Quote
Old 03-16-2013, 02:11 PM   #19
nzer
nzer's Avatar
Won't work on dash command unfortunately so no iPhone support.
See discussion with dash command asking them and their response here
http://www.palmerperformance.com/for...p?topic=6351.0
Old 03-16-2013, 07:20 PM   #20
kludger
kludger's Avatar
Drives: '13 Boxter S, '13 BRZ(gone)
Thanks, I added a post there requesting it
kludger is offline   Reply With Quote
Old 03-16-2013, 07:44 PM   #21
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Scangauge can be setup to read oil temp
http://www.ft86club.com/forums/showt...ight=Scangauge
The Following User Says Thank You to neutron256 For This Useful Post:
nzer (03-17-2013)
Old 04-19-2013, 08:27 PM   #22
Juan_Ri
Juan_Ri's Avatar
Drives: Scion FR-S
Here are photos with the ipad mini with dashcomand... Hope someone post a way to make it read the oil temp...
Juan_Ri is offline   Reply With Quote
Old 04-19-2013, 08:29 PM   #23
Juan_Ri
Juan_Ri's Avatar
Drives: Scion FR-S
Old 04-19-2013, 08:32 PM   #24
Juan_Ri
Juan_Ri's Avatar
Drives: Scion FR-S
Old 04-20-2013, 01:30 AM   #25
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Uh... where are your HVAC controls?
Old 04-20-2013, 01:39 AM   #26
Blue86
Drives: Sonic Blue 86GT Manual
if you're hot open the window. if you're cold put a jacket on
Blue86 is offline   Reply With Quote
The Following 4 Users Say Thank You to Blue86 For This Useful Post:
EAGLE5 (04-20-2013), ImSixString (04-20-2013), lbroskee (04-20-2013), Sportsguy83 (04-20-2013)
Old 04-20-2013, 06:59 AM   #27
Juan_Ri
Juan_Ri's Avatar
Drives: Scion FR-S
They are behind... Just lift it up, adjust anything and then slide it down.
Old 04-20-2013, 07:26 AM   #28
nzer
nzer's Avatar
As many of you will know you cannot currently add the oil temp PID for the twins to Dash Command to get oil temp to show on an iPad or iPhone even though we now know the oil temp PID.
Best option at the moment is to use Torque on an Android. Not good for iOS users.
If you use an iPhone or iPad and want to be able to see oil temp gauge using dash command PLEASE go to the developers Dash Commnd forum and add you voice to the request thread here.
http://www.palmerperformance.com/for...pic=6351.0;all
They are looking at adding Toyota/Subaru specific sets of data but also other makes. The more of us that request either being able to add specific PIDs or a Toyota/Subaru set the more likely we get to the front of the queue for development.
Also a good idea to write an app review of Dash Command and tell them you have voted it down due to no oil temp for the 86 or BRZ.
Let's get the FT86 Club to put the pressure on their development team! 86ers are go!
The Following User Says Thank You to nzer For This Useful Post:
Juan_Ri (04-20-2013)
OBD2 Port RJ_ AUSTRALIA 33 08-25-2016 10:25 PM
OBD2 Bluetooth Adapter Ravenlokk Engine, Exhaust, Transmission 49 09-04-2013 03:50 AM
OBDII Connector nzer AUSTRALIA 64 05-09-2013 02:44 PM
BT OBDII/Android/Torque Confirmed working Dadhawk Engine, Exhaust, Transmission 54 12-06-2012 12:57 AM
obd2 engine sound app brichard0625 Engine, Exhaust, Transmission 4 09-25-2012 04:36 PM
