Old 11-30-2012, 12:03 PM   #15
pr086
Drives: fast
heres a picture of someone's perrin drop in filter which was confirmed to be installed correctly. i guess it's meant to be raised like that
pr086 is offline   Reply With Quote
Old 11-30-2012, 03:13 PM   #16
Razz
Razz's Avatar
Drives: Fast
It's a cheaply manufactured car. Looks like the pressure has forced the plastic to bow and now it is permanently like that.
Razz is offline   Reply With Quote
Old 11-30-2012, 03:21 PM   #17
pr086
Drives: fast
have you checked your car?
Old 11-30-2012, 03:25 PM   #18
reeves
When you pry open the cheap plastic airbox to get the filter in/out, it WILL BULGE like that. Nothing wrong with it functionally.. it just looks incorrectly put on.
The clamps essentially "pull" the two plastic halves together to create a tight seal on the edge of the air filter, so there's not really any danger of having unfiltered air bypass the filter.
reeves is offline   Reply With Quote
Old 11-30-2012, 03:30 PM   #19
pr086
Drives: fast
thats what i was thinking, seems like a tighter seal that way then plastic on plastic. i've yet to see one picture of it closed any other way, maybe it is actually designed to close like that?
Old 11-30-2012, 04:20 PM   #20
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Mine is the same way. Probably normal.
Braces is offline   Reply With Quote
Old 11-30-2012, 04:26 PM   #21
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
I have a K&N in mine but I didn't notice any material sticking out like that. I'll check tonight.
Scott
naikaidriver is offline   Reply With Quote
Old 11-30-2012, 07:06 PM   #22
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
I just noticed a pic of a preproduction Subaru BRZ with it poking out too. It seems to be common...
Toyota + Subaru =
Bristecom is offline   Reply With Quote
The Following User Says Thank You to Bristecom For This Useful Post:
CrazyWookiee (11-30-2012)
Old 11-30-2012, 07:12 PM   #23
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
Just looked at mine...same thing. However it looks as if all is OK and it is sealing just fine.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 11-30-2012, 07:24 PM   #24
FRavenS
FRavenS's Avatar
Drives: 2013 Scion FRS
Mine is the same way. I'm sure it's normal.
FRavenS is offline   Reply With Quote
Old 11-30-2012, 08:07 PM   #25
roddy
roddy's Avatar
Drives: '13 Ultramarine
Mine is like that as well. I don't find the airbox too bad to put together with the stock filter, but as someone else said, it is a royal pain in the ass with the TRD filter.
Check out this FR-S Redline360 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 08-06-2012 11:58 AM
Check out these wheels Redline360 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 07-26-2012 12:13 AM
Got to check out the FR-S... r4m3n FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 75 03-02-2012 09:18 AM
Check in, eh? NorthFool CANADA 24 02-23-2012 07:32 AM
Check this out nogaroblues4 Electronics | Audio | NAV | Infotainment 6 02-20-2012 08:34 PM
