Old 12-03-2012, 12:01 PM   #15
AlexTheGreek
AlexTheGreek's Avatar
Drives: BRZ Premium Black
Originally Posted by Sportsguy83 View Post
This won't do the trick for speed compensation. I didn't even see the option anywhere.
Thanks for giving it a shot. It seems from other threads about TechStream that you can really f stuff up if you don't know what you're doing, so I'm glad you didn't!
AlexTheGreek is offline   Reply With Quote
Old 12-03-2012, 12:03 PM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
haha yeah, I was scared pressing on some of the menus!
Old 12-03-2012, 12:24 PM   #17
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
There are a lot of options around, but the software just does not work. When you try and access it (like say the TPMS, changing VCT/TRAC features) the software tells you the system is not responding or not available.
Where did you get the TS software and what version is it? I can edit the TMPS codes with mine.
Also, OP, keep in mind the stock speedo is off a bit in stock form. At least mine was. When I changed to a taller tire (225/40-18), I verified its accuracy with a GPS speedo (as well as radar). It was reading true up to 80mph. From 80 to ~100, it reads 1mph less. Above that, I really dont care.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 12-03-2012, 12:28 PM   #18
Sportsguy83
Drives: Limited BRZ
I installed it from the CD that came with the cable. It came from China, version 7.2 something...
Old 12-03-2012, 02:38 PM   #19
wparsons
wparsons's Avatar
Where did you get yours? The thing I'm most after is the TPMS code stuff.
flickr
Old 12-03-2012, 02:51 PM   #20
xwd
Subaru guys use this. It uses the ABS sensor signal and converts that to a speed sensor signal. It's pretty basic if you wanted to build one yourself.
http://dccdpro.com/zcart/index.php?m...&products_id=3
Old 12-03-2012, 07:54 PM   #21
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I've got to double check. I got it back in June/July and haven't used it since.
Sent via telepathy
Parting out HERE
Old 12-03-2012, 10:01 PM   #22
wparsons
wparsons's Avatar
Sent via telepathy
Cool, thanks! Shoot me a PM if you don't want to post it publicly.
flickr
Old 12-04-2012, 02:00 PM   #23
Sportsguy83
Drives: Limited BRZ
Sent via telepathy
Post it here for all of our benefit
Old 12-04-2012, 02:04 PM   #24
Sportsguy83
Drives: Limited BRZ
Did you do anything special aside from installing the drivers and installing techstream?
FWIW, I am running it on a virtual XP machine.
Old 12-04-2012, 04:32 PM   #25
arghx7
Drives: car
There are no traditional vehicle speed sensor signals from the transmission or differential anymore. The stability control system uses the four individual wheel speed sensors to calculate vehicle speed. Then it reports the data through a CAN message.
Most likely you would need to reprogram one or more of the modules for the stability control system. Usually it's only the supplier who has access to that.
Basically, unless you interrupt all four wheel speed sensors and hope that you don't trigger a rationality monitor (i.e., throw a code), you're probably not going to accomplish your goal.
arghx7 is offline   Reply With Quote
Old 12-05-2012, 01:13 AM   #26
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Nope just the standard install. I followed the instructions and choose Europe though instead of US.
Sent via telepathy
Parting out HERE
Disp Temperature not accurate marinjim Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 08-22-2012 08:16 AM
How accurate? Maps316 BRZ First-Gen (2012+) — General Topics 18 08-02-2012 08:28 AM
FR-S to BRZ Ratio MannyO New England 11 03-08-2012 02:23 AM
Speed hunters first drive and closer look reviews (with photos of modded blue TRD 86) Spaceywilly Scion FR-S / Toyota 86 GT86 General Forum 19 11-28-2011 10:41 PM
Accurate Engine Impressions S2KtoFT86 Other Vehicles & General Automotive Discussions 1 12-16-2009 12:05 PM
