#15 |
Wayward Member
Drives: Hot Lava 86
I feel like this is supposed to be a manual thread, but I have an auto and it always feels like the 'play' in the shifter is a bit more stiff in the morning before I go to work. It's not hard, per say, but it is easier to put it in park when I stop than it is to put it in reverse to get out of my driveway.
#16 |
The Answer
Drives: Mazda 2
You can try releasing the brake just before putting it in reverse so the car and roll a bit and better align the un-synchronised gears. I don't think I ever had a problem putting it in reverse on mine.
#17 | |
Shift Down
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
only thing ive noticed is the second gear down shift when its cold is kinda tough but again once driven a little its smooth i plan to change the fluid in the diff and trans come spring.
#18 | |
Shift Down
#19 |
Drives: ‘93 MR2, ‘22 GR86, ‘23 GR Corolla
If you're talking about how hard it is to put the stick into reverse (unlocking and putting it in) then I kind of had the same experience.
I had trouble finding the slot because I thought you had to move the stick all the way to the left, so I was forcing mine a bit but it turns out the slot is just in between the end and the first/neutral/second gear slots. It's not all the way to the left. Sometimes you just have to find it but I'm sure you'll get use to it if you take your time to constantly put it in smoothly--then I guess it's just muscle memory from there. But for me Every time I put it in reverse and it locks into the right, it feels like it's going to pop out or something... |
#20 |
First 86
Drives: Whiteout MT FR-S
Usually goes right in for me.
If it's a problem of not wanting to go in when cold, you could start backing in everywhere
Don't shop, adopt!
#21 |
Drives: 2012 honda civic ex
#22 | |
#23 |
Drives: '13 FR-S
+1 That's kind of an interesting statement to make, and then not expand a bit.
Don Ivey
'13 FR-S (Hot Lava) |
#24 |
Drives: 2013 Scion FR-S, M/T argento
Thanks. All my previous cars I left in gear when parked, but I put them in neutral when starting. My concern with the FR-S in cold weather was that leaving it in reverse while starting the engine might be a little more wear on the clutch than putting it in neutral... or not?
#25 | |
I've heard this about "triple cone" synchros, though they are more durable, they are also a little more finicky. But this statement doesn't sit will with me either. It's like saying "they designed it to feel like sh*t." I'm OK with 1st/2nd being stiff and a little notchy when cold, because the transmissions isn't designed to run continuously at very cold temps.
| What kind of computer to use? | skatery1989 | Engine, Exhaust, Transmission | 32 | 10-25-2012 02:45 PM |
| Rotiform BLQ Concave 3-pc | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 09-19-2012 01:23 PM |
| What kind of key we get in FRS? | tintumz22 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-20-2012 06:52 PM |
| What kind of car is this? | switchlanez | Other Vehicles & General Automotive Discussions | 11 | 05-20-2012 04:33 PM |
| I'm kind of afraid... | VenomRush | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 09-14-2010 01:53 AM |
