Old 11-29-2012, 06:22 PM   #15
invisage
Drives: Thunder Silver 86 GTS
Originally Posted by S1000rr View Post
100% meth is not very safe. Water also helps dilute the meth in order to keep things safe under the hood. As you said though water is used for cooling which actually sweats on the cylinder walls. A 60-40 mix would probably be good, but in our case E85 would probably be a lot easier to accomplish the power gains.
A 50/50 ratio is what most meth kit companies consider to be the optimum blend. And I think this is aimed more at those who don't have easy or no access to e85
invisage is offline   Reply With Quote
Old 01-28-2013, 05:27 PM   #16
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
I'm looking into this for my BRZ. Alaska's highest octane is 90, but minimum required is 91.
I'm told to look into the Honda high compression motors to see what people have used there. I messaged Snow Performance to get a better idea of what to do.
Water/meth has been around since 1920's, so I'm not too concerned with what can happen to the engine. I just don't like pumping 90 octane in it all the time.
Old 02-15-2013, 05:16 PM   #17
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Talking to aquamist about getting a kit. Several hundred bucks, just a couple hundred to install and tune. Not bad.
The Following User Says Thank You to chanomatik For This Useful Post:
Jaylyons1 (05-08-2013)
Old 02-16-2013, 10:50 AM   #18
eightsix
was when i was born
Drives: 2010 Turbo tC, 2011 rav4
Originally Posted by Grishbok View Post
Injecting nitrous is much safer. I explained in another thread, but will do so again, that nitrous is n2O, meaning two nitrogen and an oxygen atom. During the combustion process the nitrogen is seperated form the oxygen, leaving free floating oxygen in the combustion chamber, oxygen is air, meaning your doing nothing more than putting more air into the combustion chamber, the free floating nitrogen acts as a buffer to prevent detonation and compressed nitrous sprays at a temperature of +- -127*F
The increased power comes from the combustion of the pure unbonded oxygen. Obviously trying to shove 500hp shot is not safe, but a 50shot would be perfectly fine. even a 25 shot or a 20 shot if they made nozzels that small would be able to produce more of a hp/tq # than methanol.
How about both?
Ptuning FTW
eightsix is offline   Reply With Quote
Old 09-03-2013, 03:01 AM   #19
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Originally Posted by FA20Club.com View Post
The kit is here just have to find some time to get it installed on a stock car for testing....?
So did you guys ever test this?
hmong337 is offline   Reply With Quote
Old 09-03-2013, 04:26 AM   #20
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
You'll make more power with nitrous, but meth is a lot easier to come by...
Plus way cheaper
I'm personally thinking of throwing a meth kit on the car.
Keep in mind you'll need a tune to take advantage of using meth
Old 09-03-2013, 01:36 PM   #21
hmong337
Emperor JDM
hmong337's Avatar
Plus way cheaper
Not looking for nitrous. Hate it. Plus, it's not easily accessible whatsoever and highly illegal where I'm from.
I want to know if somebody has tested a meth kit on our cars yet. Being as we have a very high compression ratio, I think we might benefit from meth injection to keep detonation down.
Old 09-03-2013, 11:44 PM   #22
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Self install is possible !
448hpsti is offline   Reply With Quote
Old 09-04-2013, 11:59 AM   #23
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
NEVAR!!!
Nah, you're probably right. I'm still not sure if I want to go this route anyways. I know it's tried and true for many applications since World War II planes, but not sure about 2013 FT-86 application.
Old 09-04-2013, 12:47 PM   #24
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
I have the wires to the ecu down so its not rocket science as far as which wires to tap, using positap its clean too, no need for extension harnesses, and a plug n play location for tank etc in our car if you use the same tank as me. the venting of the tank i did a custom job on but its not hard. You do drill holes to mount the pump but its easy drilling. If you run a vortech, they recently supplied me with a dimpled cast pipe that's plenty thick to tap for a jet. I been busy on test an install stuff, I need to tune next and last for power.
Now, I can't comment at all on its value in a NA application, but as its new to me, it comes pretty well recommended from more than a few of the tuners I trust for FI.
Old 09-05-2013, 10:52 AM   #25
hmong337
Emperor JDM
hmong337's Avatar
NEVAR!!!
As long as you've got some form of internal combustion there's way to make it work.
I think for a high compression NA application like our 4ugse, a small port injection system using a sophisticated monitoring and injection system would make water/meth injection beneficial. It's like "helper octane" when you need it; and cleaner too! But most importantly, it's the cleaning action that injection creates that makes me a fan of water/meth injection systems. I have one installed on my MR2 turbo and my butt-dyno agrees with the horsepower increase. It's also great to know that my internals are getting steam cleaned. Injection is a must to have installed on any forced induction system.
But the reason why I ask about a water/meth injection kit is that the only clean gas around my parts is 91 v-power. The fa20 requires 93 to run optimally. I hate choking the motor with 91 so I am looking for an alternative way to increase octane points effectively and easily.
The Following User Says Thank You to hmong337 For This Useful Post:
chanomatik (09-05-2013)
Old 09-05-2013, 12:42 PM   #26
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Good points. My interest in it is because Alaska's highest is 90 Octane. However, several tuners have told me that the ECU learns to compensate for the "poorer" gas, so it's not actually hurting anything, but you are losing optimal power. So for me, water/meth would be nice for maximizing power. I think once I go header, intake, full exhaust and tune I might as well include water/meth because if the engine goes, it's going to go no matter what, water/meth or not.
Old 06-03-2014, 05:08 PM   #27
Jonsey
Jonsey's Avatar
Reviving an old thread. Has anyone actually hooked up a meth injection or meth/water injection system on an FA20 yet?
Beginning the research phase now in contemplation of adding this in conjunction with a Phantom ESC versus simply running E85.
Jonsey is offline   Reply With Quote
Alcohol Injection Ess Vee Forced Induction 34 01-28-2016 07:43 PM
Meth/Water Injection question showbe Engine, Exhaust, Transmission 9 10-18-2012 07:25 PM
ever seen fuel injection like this? carbonBLUE Other Vehicles & General Automotive Discussions 1 10-17-2012 02:17 AM
Gasoline Direct Injection... DoogenBurns Engine, Exhaust, Transmission 5 05-21-2012 02:05 PM
Nitrous Oxide/Meth injection JDLM Engine, Exhaust, Transmission 6 12-17-2011 04:23 AM
