Old 11-16-2012, 01:31 PM   #15
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Originally Posted by Racecomp Engineering View Post
And yeah, the KW's are great. We're working on our RCE Tarmac 2's, which are built by KW but we've still got some work to do.
- Andrew
Do you guy have a Tarmac 2 thread around here somewhere? I'm highly interested in them. I'm debating between Tarmac 2's and Yellow springs.
Grimlock is offline   Reply With Quote
Old 11-16-2012, 02:15 PM   #16
brianlo622
brianlo622's Avatar
Drives: 2013 FR-S, raven
Originally Posted by koyv90 View Post
Its for a daily driver with some spirited driving(cornering, Auto x) and drifting fun! I don't think price will be a problem. So Sounds like Kw3s or FA. I thought Camber plates are important for alignment and gives you more of a range to control when lowering your car?
I am not sure why you keep on bringing Fortune Auto back
I am also cross shopping coilovers at the moment and I thought I'd share some of the brands I am considering.
RSR i-coilovers: These are roughly $1800 to $2000, price range wise they are just a tad below the KWs.
Eibach Multi Pro R1: They will be roughly $1600, monotube design
Eibach Multi Pro R2: About $2000 to $2200, external resevoir, too much adjustability IMO.
If price is TRULY not a concern like you were saying, I would opt for the Ohlins which are rumored to be between $3500 to $4000.
All the coilovers that I mentioned above do not "cater" to the "HELLAFLUSH" crowd. They are performance oriented, unlike some of the brands that you have mentioned who's primary concern is flushness and lowness.
Brian
brianlo622 is offline   Reply With Quote
Old 11-16-2012, 02:24 PM   #17
cnk
Drives: '13 DGM BRZ Limited
Another option that seems appealing right now are the GC coilovers. It will be interesting to see how they stack up against the KW's as they do offer a lot of bang for your buck seeing as they come with camber plates and a front strut bar as well.
cnk is offline   Reply With Quote
Old 11-16-2012, 02:48 PM   #18
Originally Posted by JoeBoxer View Post
We were discussing rates in another thread, i know the KW is around 6k/7k will the Tarmac's be a little stiffer?
We'll start at 7k/7k but have options on spring rate.
No thread just yet. We want to have a better idea on ETA first.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
dabocx (11-16-2012)
Old 11-16-2012, 02:52 PM   #19
With KW's and stock tophats you can still get a lot of camber. You simply adjust at the lower mount instead of the tophat. Camber plates will let you adjust in a ton of camber (if you want it) and are an all-metal design, which of course can have some drawbacks to the OEM rubber mounts on the street in terms of noise and harshness.
A good quality camber plate is a very good addition for a car that sees the track or autocrosses but isn't a necessity for a street car. There are positives and negatives.
- Andrew
Old 11-16-2012, 04:24 PM   #20
xwd
Like someone else mentioned, I wouldn't discount the Ground Control setup which uses Koni inserts in the front and a Koni shock in the back. They also sell them with camber plates.
Old 11-16-2012, 05:37 PM   #21
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
If the GC's can be specced with an 8011 (I think that's it) level damper like the Zyzzx coilovers that were available a while back for the Impreza that'd be a pretty killer combo.
I would love for a professional driver to take cars out and give input on the strengths and weaknesses of the various systems.
KW, AST, Ohlins and the GC setup are at the top of my list.
Nathan
SubieNate is offline   Reply With Quote
Old 11-16-2012, 09:06 PM   #22
jumbaco
jumbaco's Avatar
Drives: FD
Originally Posted by SubieNate View Post
From what I've read, I'd put the FA's over STANCE any day. STANCE just seems like an expensive BC to me.
I think KW's are in a different league than either of those though.
I'm assuming that most of what you've read was from the internet. And the internet is not exactly a reliable source of information.
jumbaco is offline   Reply With Quote
Old 11-16-2012, 09:26 PM   #23
jamal
jamal's Avatar
Drives: Legacy GT
You basically have two choices when it comes to coilovers. R&D and good damping, or a bunch of "features."
So would you rather have double ride height adjustability, camber plates, and "32-way" adjustment, or good parts that are going to perform and ride well and last for years without issue.
jamal is offline   Reply With Quote
The Following 2 Users Say Thank You to jamal For This Useful Post:
JoeBoxer (11-16-2012), Racecomp Engineering (11-16-2012)
Old 11-16-2012, 09:40 PM   #24
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
I think the ultimate question is what do you plan to do with your car and how much you are willing to spend.
I was actually pinging folks here for coilovers for my Supra. Though 2K for some KW V3's seems fair, I can't justify it since I won't be tracking my Supra.
But if you want an entry level coilover that won't break your wallet, I would suggest talking to these guys. Ain't nothing wrong with the lower tier stuff if you have good valving and Swift springs.
http://rallyracingsuspension.com/page1.html
An example of suspension rankings would be something like this.
Higher tier
-Ohlins
-JRZ
-Moton
Mid
-KW VW
-HKS Hipermax
-Cusco
Lower tier
-Megan
-BC
-K Sport
-Stance
-Fortune Auto
Old 11-16-2012, 09:56 PM   #25
Foobar
SLO NO MO
Foobar's Avatar
They can't put anything on the Internet that isn't true!
I'm a French model. Bonjour!
The Following User Says Thank You to Foobar For This Useful Post:
wparsons (11-19-2012)
Old 11-16-2012, 10:31 PM   #26
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I'm still waiting to see the Bilstein PSS, the Eibach Street series is also an option I actually prefer to use factory top mounts so not having them isn't an issue for me.
JoeBoxer is offline   Reply With Quote
The Following User Says Thank You to JoeBoxer For This Useful Post:
brianlo622 (11-16-2012)
Old 11-16-2012, 11:24 PM   #27
brianlo622
brianlo622's Avatar
Loved PSS9s on Audis and BMWs
Old 11-17-2012, 02:03 PM   #28
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
KWs are the shit.
Stance is pretty damn good, but not as good as KWs-nor, would I expect them to be at half the price.
Fortune Auto IS shit. Dampening adjustability sucks, camber adjustability sucks. In short, they suck.
TylerLieberman is offline   Reply With Quote
HT Autos STI-inspired lower front lip - Subaru BRZ only. Koru Exterior Parts - The Rest 131 06-26-2015 05:04 PM
HT Autos / KORU rear spats - BRZ and FRS - works with OEM diffuser Koru Exterior Parts - The Rest 9 01-25-2013 09:05 PM
Yahoo Autos - FR-S vs Cayman S Synack Scion FR-S / Toyota 86 GT86 General Forum 22 11-25-2012 08:05 PM
Autos the GT-86, BRZ, Fr-s can pose a challenge to drifter FR-S / BRZ vs.... 24 07-28-2012 01:56 AM
