#15 |
Drives: Toyota 86 GT
#16 |
Drives: BR86
#17 |
Drives: White GTS Manual
Can't wait to see more on this.
#18 |
Loud Noises
Drives: BRZ & YGZ11 Cube3
/subscribes. Looks promising, I like supporting Australian-made wherever possible
Proud owner of an April 2013 WR Blue Mica BRZ Premium Pack
#19 |
Drives: 2012 Toyota 86 GT (Black) :)
Any options for burnt Ti tips?
#20 |
Drives: 2013 genesis rspec
Wow those look killer
#21 |
#22 |
Drives: 86 GTS
So what I'd ideally like:
1. Overpipe 2. Front pipe with Cat and Resonator 3. Cat back All mating up at the factory points so it can mix and match. Dynos. |
| The Following User Says Thank You to Panman For This Useful Post: | fuddbutter (11-07-2012) |
#23 | |
The front pipe does have a cat and resonator. The overpipe hasn't been made yet. The thing that complicates it on the RHD models is the proximity to the steering box. It will probably need wrapping or coating. XForce are in the process of getting their own dyno. So they'll be doing performance testing in house. I want to see the performance difference (if any) between the 2.5 and 3 inch systems. |
#24 |
Drives: 86 GTS
Gold - If I can buy a proven Aussie design I will.
Overpipe seems to give good results in other testing, however if no overpipe, everything behind must bolt up so not a show stopper if price is right. |
#25 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
#26 |
Drives: JDM86
The Xforce full system we ran on our old Crx with a b16a2 gave the best gains.
Ended up with 100kw @ front wheels with the full system. |
#27 |
| The Following User Says Thank You to 86drift For This Useful Post: | Turdinator (10-30-2012) |
#28 |
Drives: BR86
You could stick a lot of bananas in those tail pipes
| Exhausts | stevo_12v | AUSTRALIA | 142 | 03-04-2013 04:00 AM |
| 3 Inch Exhausts? | kmbkk | Engine, Exhaust, Transmission | 9 | 10-23-2012 03:18 PM |
| Larini Exhausts? | nashsnazzy | Engine, Exhaust, Transmission | 11 | 10-23-2012 11:48 AM |
| Aftermarket Exhausts? | devinclfalcons | Engine, Exhaust, Transmission | 309 | 10-18-2012 03:07 AM |
| Exhausts!!!!!! | FT86_Zero | AUSTRALIA | 4 | 07-03-2012 12:53 AM |
