Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 10-28-2012, 10:17 PM   #15
86drift
86drift's Avatar
Drives: Toyota 86 GT
Originally Posted by ZZT86 View Post
OK then, looks promising. Your custom plate a forerunner to a future Toyota rally team?
I wish they'd pay for it! How about an 86 one make series
It will be a rally car in the next year or two.
86drift is offline   Reply With Quote
Old 10-29-2012, 05:36 AM   #16
ZZT86
ZZT86's Avatar
Drives: BR86
I could definitely see a one-make series ! Toyota has a rich history in motorsport, especially in rallying. Look forward to more esorst updates.
ZZT86 is offline   Reply With Quote
Old 10-29-2012, 05:58 AM   #17
alexm86
Drives: White GTS Manual
Can't wait to see more on this.
alexm86 is offline   Reply With Quote
Old 10-29-2012, 06:26 AM   #18
llama_au
Loud Noises
llama_au's Avatar
Drives: BRZ & YGZ11 Cube3
/subscribes. Looks promising, I like supporting Australian-made wherever possible
Proud owner of an April 2013 WR Blue Mica BRZ Premium Pack
llama_au is offline   Reply With Quote
Old 10-29-2012, 09:20 PM   #19
Cnidus
Drives: 2012 Toyota 86 GT (Black) :)
Any options for burnt Ti tips?
Cnidus is offline   Reply With Quote
Old 10-29-2012, 09:24 PM   #20
just86
just86's Avatar
Drives: 2013 genesis rspec
Wow those look killer
just86 is offline   Reply With Quote
Old 10-29-2012, 10:03 PM   #21
86drift
86drift's Avatar
You can use whatever tips you like as you can get a version with none and you can use your own. I think it's got 2 1/4 inch tail pipes, same as the factory exhaust.
Old 10-29-2012, 11:05 PM   #22
Panman
Panman's Avatar
Drives: 86 GTS
So what I'd ideally like:
1. Overpipe
2. Front pipe with Cat and Resonator
3. Cat back
All mating up at the factory points so it can mix and match.
Dynos.
Panman is offline   Reply With Quote
The Following User Says Thank You to Panman For This Useful Post:
fuddbutter (11-07-2012)
Old 10-29-2012, 11:25 PM   #23
86drift
86drift's Avatar
1. Overpipe
3. Cat back
Dynos.
I'll have to check the that the front pipe to cat-back flange is in the same position as the factory one.
The front pipe does have a cat and resonator.
The overpipe hasn't been made yet. The thing that complicates it on the RHD models is the proximity to the steering box. It will probably need wrapping or coating.
XForce are in the process of getting their own dyno. So they'll be doing performance testing in house. I want to see the performance difference (if any) between the 2.5 and 3 inch systems.
Old 10-30-2012, 12:45 AM   #24
Panman
Panman's Avatar
Drives: 86 GTS
Gold - If I can buy a proven Aussie design I will.
Overpipe seems to give good results in other testing, however if no overpipe, everything behind must bolt up so not a show stopper if price is right.
Old 10-30-2012, 01:01 AM   #25
Turdinator
Señor Member
Turdinator's Avatar
So there is a 2.5" in development as well? What about a version with Varex?
1974 TA22 Celica
2013 86 GT
Old 10-30-2012, 04:00 AM   #26
JDMSushi
JDMSushi's Avatar
Drives: JDM86
The Xforce full system we ran on our old Crx with a b16a2 gave the best gains.
Ended up with 100kw @ front wheels with the full system.
JDMSushi is offline   Reply With Quote
Old 10-30-2012, 04:50 AM   #27
86drift
86drift's Avatar
The 3" system will be released first then the 2.5" will follow.
I'll find out if they've got plans for a Varex system.
The Following User Says Thank You to 86drift For This Useful Post:
Turdinator (10-30-2012)
Old 10-30-2012, 07:32 AM   #28
ZZT86
ZZT86's Avatar
Drives: BR86
You could stick a lot of bananas in those tail pipes
Exhausts stevo_12v AUSTRALIA 142 03-04-2013 03:00 AM
3 Inch Exhausts? kmbkk Engine, Exhaust, Transmission 9 10-23-2012 02:18 PM
Larini Exhausts? nashsnazzy Engine, Exhaust, Transmission 11 10-23-2012 10:48 AM
Aftermarket Exhausts? devinclfalcons Engine, Exhaust, Transmission 309 10-18-2012 02:07 AM
Exhausts!!!!!! FT86_Zero AUSTRALIA 4 07-02-2012 11:53 PM
