Old 10-17-2012, 10:57 PM   #15
Racecomp Engineering
Originally Posted by FRS-HHH View Post
i PM'ed you before on how to purchase the lite kit and you never replied bro
PMing you now...sorry if a PM slipped through!
- Andrew
Old 10-17-2012, 11:04 PM   #16
coyote
coyote's Avatar
Drives: Slowly
Originally Posted by ModBargains.com View Post
Something to consider as well, if you have the ability of saving up just a bit more, then KW's would be something to look at, as their quality, their performance is unmatched. A lot of these other coilovers are great, don't get me wrong, a lot of them I would look at and seriously consider as well, but honestly at this point, nothing will be as outstanding as KW is on, and off the track.
Unmatched?
coyote is offline   Reply With Quote
Old 10-18-2012, 01:04 AM   #17
D1cker
Drives: B9 S4/ND2
I would save up for the KW V3's if it's going to be primarily a street car, the valving is pretty good. The Scion FRS Formula D car is great, but it's not running V3's, it's using high end KW competition dampers.
D1cker is offline   Reply With Quote
Old 10-19-2012, 01:32 AM   #18
Danzzt231
Drives: GT86
If it is mainly daily driver, with the occasional track use, I would suggest to wait for Bilstein PSS if coilover is in mind.
KW V3 is nice, but it is in my opinion overkill for the OP's need. For the money of V3 I would try to buy few suspension components to go with the coilover, instead of just coilover.
This is the setup I would suggests either all in one go, or step by step:
1. Bilstein PSS or similar (KW V1 for example, is also a good buy)
2. Cusco camber plate (for wheel alignment purposes)
3. Adjustable endlinks (for swaybar tuning purposes)
4. Swaybars (select moderate up-size, not too big)
Spend on proper wheel alignment to tie everything together.
I use basically the same setup as above for my ZZT Celica, and the car was used for daily drive, road trip and race circuit. Tons of fun.
Danzzt231 is offline   Reply With Quote
Old 10-19-2012, 02:22 AM   #19
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
gracias
FRS-HHH is offline   Reply With Quote
Old 10-19-2012, 02:30 AM   #20
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
well after doing some searching..and emailing Bilstein wont prob have parts for the FR-S until mid next yr :/ and KW i couldnt find V1 i tried looking at a lot of diff online stores..frsport, vivid, ft86speedfactory, to name a few and no low..any other good coilovers you may know of???
Old 10-19-2012, 04:07 AM   #21
Danzzt231
Drives: GT86
Koni, H&R, Eibach, Drummond Motorsport (DMS), and Ohlin.
Old 10-19-2012, 11:58 PM   #22
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
some of these companies dont have coilovers for the fr-s yet
Old 10-21-2012, 12:11 AM   #23
Danzzt231
Drives: GT86
It is still early, and i do suggest you wait until theres more available.
But if you want one right now, and if you want the best then kw v3 is it.
If not, then the cusco would be ok too. Just make sure you get one that can be fitted or come with camber plate to dial in proper wheel alignment.
Microfiber cloths. recommendations? TofuDelivery Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 30 11-09-2012 04:42 PM
car covers. recommendations? TofuDelivery Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 15 09-28-2012 11:05 AM
Helmet recommendations? denverizzles Tracking / Autocross / HPDE / Drifting 9 09-10-2012 02:55 PM
M7 JAPAN COILOVERS for SCION FRS SUBARU BRZ, JDM COILOVERS AMPLIFIED MOTORSPORT Brakes, Suspension, Chassis 0 08-16-2012 03:45 AM
Driving school recommendations denverizzles Tracking / Autocross / HPDE / Drifting 21 07-30-2012 08:10 PM
