#15 |
Kouki-Monster
9/7 ??
sum ting wong
Rich Anderson
EMPOWER AUTO |
#16 |
Drives: 2013 BRZ, Limited, C7P, 6AT
#17 | |
Kouki-Monster
Rich Anderson
EMPOWER AUTO |
#18 | |
![]() - Andrew |
#19 | |
Kouki-Monster
If I decided tomorrow to go 14/18 on my Soarer... i'd spin around a lot
Rich Anderson
EMPOWER AUTO |
#20 |
All good points. I was just using the OEM spec as the starting point to show that the higher spring rate is actually at the rear. If my understanding of the math holds, the wheel rates, after accounting for leverage multipliers, works out to be very close to the same at both ends...
#21 | |
http://www.ft86club.com/forums/showthread.php?t=9936 Sorry for taking this thread off topic!! - drew |
#22 |
Thanks Drew and, yes, I did read your excellent thread on the subject. I also have a background in mechanical engineering so those are the sorts of things I tend to pay attention to.
Now, getting back to this particular topic, does anyone know if the spring rates from Buddy Club are correct? I'm wondering if it was reversed or if they meant to set their coil overs up that way. If the latter, I would like to understand what their objective was in doing so. That way I can make a fully informed buying decision, Buddy Club or otherwise. Anybody know? |
#23 | |
I like to eat!
#24 |
That's right, the spring rates were not a mistake. There are many people that are running higher rate springs in the front than in the rear. Just because the factory has a higher sprung rear than front from the factory doesn't mean that is the only way you can setup the car.
What it really comes down to is making the car fit your driving style. Some people like the front to feel planted and have lots of turn-in feel with a rear end that is a bit more tame, while others like the rear to be a bit more playful and steer with the throttle. Lots of SCCA autocrossers are swapping front and rear springs on their KW setup for a more biased front, I remember Sam Strano also running a higher rate up front, and the gentleman in the link below surely likes this exact coilover. http://www.ft86club.com/forums/showt...ght=buddy+club Cheers! -Yo |
#25 |
With the spring thaw upon us here in Iowa, we are ramping things up for the builds on both cars. STX is the target auto-x class for our Firestorm car, we got a huge chunk of goodies installed that will get us in a competitive state.
First up, suspension. Just a simple bolt on of Buddy Club Racing Spec coilovers for the first round of suspension bits. We are waiting on sway bars from Whiteline to show up on Tuesday. Already a huge improvement in turn-in and grip from these coils. Steering feel is much heavier over stock and the feedback is still there, just perfect in my opinion. We will see how they perform on track this coming Friday when our local road course opens up for the first open lapping day of the season. My initial reaction is the ride is quite firm on these. I do have it only 2 clicks from full-stiff, but I am not sure full soft will make it change dramatically. Every bump, crack, and undulation in the road can be felt with this setup. I guess you can say, these are not for the faint of heart. Today, I went back and adjusted the dampeners. This time I went all the way to 2 clicks from full soft. I can say that the ride dramatically improved. Instead of being shaken to death, the suspension actually eats up some of the bumps and cracks in the road. It is definitely liveable, but barely! People that are more hardcore than myself would be perfectly fine and tell me I am a sissy, I'm sure ![]() More to come on the suspension after our track day For now, here are some pics![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#26 | |
Boosted
Drives: Not a supra....yet
may i ask how hard is a coil over install in general, and is it something doable with jacks on the weekend ? |
#27 | |
Pull the spring and strut assemblies off as one piece and install the coilovers as one piece. Adjust the ride height, eyeball alignment, drop her back on the ground, take her to get an alignment, and call it good. A little more involved than that, but that is basically it ![]() Cheers! -Yo |
#28 |
Drives: 2013 scion FRS
im thinking about tein flex coilovers, do you recommend these over teins for a daily driver looking for comfort and handling if i need it?
| Wheel Directory: Buddy Club P1 Racing 17x7.5 +50 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 08-10-2013 01:24 PM |
| First set of Buddy Club Racing Spec coilovers! | jdmitr | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 06-28-2013 05:59 AM |
| Buddy Club Racing Spec coilovers, anyone install them yet? | Mark Slide Squad | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 06-28-2013 02:17 AM |
| ***Invidia N1 FRS / BRZ SALE*** Videos and Photos - FT-86 SpeedFactory does it again! | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 33 | 10-24-2012 10:11 PM |
| ***FORTUNE AUTO COILOVERS*** FT-86 SpeedFactory **EXPERTS** | FT-86 SpeedFactory | Brakes, Suspension, Chassis | 32 | 09-21-2012 10:42 PM |
