#15 |
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
Sorry I could not make it to my shop today for a dyno. Hopefully next Monday or later this week.
#16 |
update
Finally got the dyno done today and I am loosing massive power. I am loosing 6hp over stock and about 12 with my exhaust. We took everything off to see if i had something stuck on the filter or in the box and all was clear. I never reset the ECU after my install. I am going to leave the battery off tonight and see if resting it helps. gonna redyno it next Monday otherwise i have no clue whats going on.
I guess the power i thought it had was just the difference of me driving it around with only 1 person in the car. sense i never drive the thing i have no clue if had missing power the whole time or not. Or it cold be just because there is crap gas in it. |
#17 |
I would put the stock intake back on and focus on why you are losing power with the AP exhaust. Once that's figured out, you can try and put the Afe intake back on.
#18 | |
167hp 134Tq was my base. The best I got with exhaust was 173hp 141Tq. Now I am all the way down to 159hp 134Tq
#19 |
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Power isn't stackable on the mods, and just because you made more power with the exhaust doesn't mean that adding an intake will 'stack' on top of that.
However, 159 is pretty low, and do you have the before and after dyno charts for comparison? |
#20 | |
I just not sure why i would be loosing power with after my intake was installed. Even without doing a ECU reset ![]() I disconnected the battery for an hour then went for a drive. The car seems a little more punchy and seems to have a more throaty tone to it. i guess ill see what the dyno next Monday says about it. Here is the dyno comparison between all stock and my best agency power exhaust runs. ![]() My guys mistakenly added my 3rd best exhaust run VS my intake and exhaustrun also note that little jump at the beginning of they dyno was just a oddity in this particular run, we did 4 pulls today and this is the only one with that jump. I don't know why i did not think to just disconnected my battery to reset the ECU while i was at the shop. ![]() On the side how long should i disconnected it for to reset it anyhow. Thanks for looking at my issue
#21 |
Drives: FR-S, BR-Z, 86
Do you have a log of your Air/Fuel ratio with the dyno?
I know from one car I tested, it ran rich and lost power after a catback was installed. |
#22 | |
if I'm still having problems after my ECU reset on Monday when I get my next dyno ill see about hookin one up. I don't know if the air fuel ratio is just something that can be read from the OBD 2 or if I need to make a bung to install an AFR sensor. I'll ask my guy on Monday. |
#23 | |
#24 |
Track Junkie
Drives: Faster than the Stig!
Does AFE make a sound tube delete version?
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
#25 |
#26 |
yeah it's actually blocked, but I left the tube on there because to lazy to take it off. I just started reading about the FA20club tune i was interesting in buying it. I just now started reading up on it for the first time. is there something else i need to buy or do I just buy the program? and also how does the reflash work if I go to get smog test in California. is it easily put back to stock mode if I need to go in
#27 |
Drives: 2013 86 white
what is the HP and TQ gain over the stock ?
#28 |
Drives: 2013 WRB BRZ limited Gold RPF1'
Hey did you remove the snorkel from inside the bumper by any chance ? I installed my aFe intake with the snorkel on and after a month removed the snorkel and noticed a change in engine tone and punch.
| The Following User Says Thank You to BlueBrzKenny For This Useful Post: | aFe POWER (12-08-2015) |
| *AFE TAKEDA INTAKE SYSTEMS FOR FRS/BRZ LIMITED QTY* | genometuning | Engine, Exhaust, Bolt-Ons | 105 | 07-29-2013 05:35 PM |
| Finally got my afe takeda intake! | Coultergeist | Engine, Exhaust, Transmission | 68 | 10-07-2012 08:36 AM |
| New Takeda Cold Air Intake! *Ships Last Week Aug* | SpeedBRZ | Engine, Exhaust, Bolt-Ons | 2 | 07-30-2012 05:42 PM |
| Takeda Cold Air Intake for the FR-S/BRZ at Redline360! | Redline360 | Engine, Exhaust, Bolt-Ons | 3 | 07-24-2012 02:34 AM |
| Takeda intake by afe | FrsSwag | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 27 | 06-27-2012 04:27 PM |
