Old 10-01-2012, 09:23 PM   #15
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
Sorry I could not make it to my shop today for a dyno. Hopefully next Monday or later this week.
clayrush is offline   Reply With Quote
Old 12-03-2012, 07:38 PM   #16
clayrush
update
Finally got the dyno done today and I am loosing massive power. I am loosing 6hp over stock and about 12 with my exhaust. We took everything off to see if i had something stuck on the filter or in the box and all was clear. I never reset the ECU after my install. I am going to leave the battery off tonight and see if resting it helps. gonna redyno it next Monday otherwise i have no clue whats going on.
I guess the power i thought it had was just the difference of me driving it around with only 1 person in the car. sense i never drive the thing i have no clue if had missing power the whole time or not. Or it cold be just because there is crap gas in it.
Old 12-03-2012, 09:10 PM   #17
jflogerzi
jflogerzi's Avatar
I would put the stock intake back on and focus on why you are losing power with the AP exhaust. Once that's figured out, you can try and put the Afe intake back on.
Old 12-03-2012, 09:44 PM   #18
clayrush
I guess it is possible. But I initially gained power with my exhaust. Then after the intake was put on I lost power. but maybe you are right and something is messed up. When my GF get home ill lift it up and take a quick look and see if something is bent or loose.
167hp 134Tq was my base. The best I got with exhaust was 173hp 141Tq. Now I am all the way down to 159hp 134Tq
Old 12-04-2012, 12:29 AM   #19
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Power isn't stackable on the mods, and just because you made more power with the exhaust doesn't mean that adding an intake will 'stack' on top of that.
However, 159 is pretty low, and do you have the before and after dyno charts for comparison?
Drift-Office is offline   Reply With Quote
Old 12-04-2012, 01:36 AM   #20
clayrush
I know it is not stable. I just not sure why i would be loosing power with after my intake was installed. Even without doing a ECU reset
I disconnected the battery for an hour then went for a drive. The car seems a little more punchy and seems to have a more throaty tone to it. i guess ill see what the dyno next Monday says about it.
Here is the dyno comparison between all stock and my best agency power exhaust runs.
My guys mistakenly added my 3rd best exhaust run VS my intake and exhaustrun also note that little jump at the beginning of they dyno was just a oddity in this particular run, we did 4 pulls today and this is the only one with that jump. I don't know why i did not think to just disconnected my battery to reset the ECU while i was at the shop.
On the side how long should i disconnected it for to reset it anyhow.
Thanks for looking at my issue
Old 12-04-2012, 05:12 AM   #21
Crossover Auto
Drives: FR-S, BR-Z, 86
Do you have a log of your Air/Fuel ratio with the dyno?
I know from one car I tested, it ran rich and lost power after a catback was installed.
Crossover Auto is offline   Reply With Quote
Old 12-05-2012, 03:30 PM   #22
clayrush
no the AFR was not read.
if I'm still having problems after my ECU reset on Monday when I get my next dyno ill see about hookin one up. I don't know if the air fuel ratio is just something that can be read from the OBD 2 or if I need to make a bung to install an AFR sensor. I'll ask my guy on Monday.
Old 12-05-2012, 03:40 PM   #23
2forme
Usually dyno places have a clip in sensor that they put in your exhaust tip. I would def get that read. Running too rich or too lean is never good for a motor.
Old 12-05-2012, 03:41 PM   #24
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Does AFE make a sound tube delete version?
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 12-05-2012, 03:45 PM   #25
2forme
It's default config is a sound tube delete.
Old 12-05-2012, 03:53 PM   #26
clayrush
yeah it's actually blocked, but I left the tube on there because to lazy to take it off. I just started reading about the FA20club tune i was interesting in buying it. I just now started reading up on it for the first time. is there something else i need to buy or do I just buy the program? and also how does the reflash work if I go to get smog test in California. is it easily put back to stock mode if I need to go in
Old 12-12-2012, 02:57 PM   #27
TRD_86
Drives: 2013 86 white
what is the HP and TQ gain over the stock ?
TRD_86 is offline   Reply With Quote
Old 12-04-2015, 04:33 PM   #28
BlueBrzKenny
Drives: 2013 WRB BRZ limited Gold RPF1'
Hey did you remove the snorkel from inside the bumper by any chance ? I installed my aFe intake with the snorkel on and after a month removed the snorkel and noticed a change in engine tone and punch.
BlueBrzKenny is offline   Reply With Quote
The Following User Says Thank You to BlueBrzKenny For This Useful Post:
aFe POWER (12-08-2015)
*AFE TAKEDA INTAKE SYSTEMS FOR FRS/BRZ LIMITED QTY* genometuning Engine, Exhaust, Bolt-Ons 105 07-29-2013 04:35 PM
Finally got my afe takeda intake! Coultergeist Engine, Exhaust, Transmission 68 10-07-2012 07:36 AM
New Takeda Cold Air Intake! *Ships Last Week Aug* SpeedBRZ Engine, Exhaust, Bolt-Ons 2 07-30-2012 04:42 PM
Takeda Cold Air Intake for the FR-S/BRZ at Redline360! Redline360 Engine, Exhaust, Bolt-Ons 3 07-24-2012 01:34 AM
Takeda intake by afe FrsSwag FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 27 06-27-2012 03:27 PM
