#15 |
Drives: GT86
#16 | |
Drives: 2017 BRZ PP
Thread revival... I just installed an AEM wideband and removed the O2 sensor downstream of the cat in order to prep for FI. Of course the CEL came on but consequently noticed that cruise control doesn’t work anymore. Does a CEL really disable cruise control?? Sent from my iPhone using Tapatalk |
#17 |
Huge E85 fan!
Drives: 2016 Scion FRS
yes
#18 |
#19 |
Drives: 2017 BRZ PP
Any idea as to the reasoning and logic behind disabling cruise control when there’s a catalyst inefficiency?
#20 |
It thinks the inefficacy is a failure of the system and is trying to protect the engine from damage. The system doesn't know why the issue occurred it just knows it did.
Pretty much any CEL that could cause damage triggers what is nicknamed "limp mode".
| The Following User Says Thank You to Tcoat For This Useful Post: | kimcheefists (02-21-2018) |
#21 | |
This. It's a liability issue for toyota and subaru for the P0420 codes and other catalyst codes. Because your AFR data reads "incorrect'" now and the pre cat and post cat O2 data is also "incorrect" letting cruise control run would be dangerous, it could very well go full throttle and lean the car out, or make its acceleration choppy and sporadic in an effort to counter the engine issue. Making a cruise control system that takes into account engine codes and does a limp home cruise control type deal would be very difficult and also defeat the purpose of being efficient. This is why your tuner will disable the P0420 code when you finish the FI install, or when others install things like a header.
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | kimcheefists (03-03-2018) |
| Cruise control temporarily disabled? | DarrenDriven | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 06-29-2016 09:35 PM |
| Anyone considering a cruise in dallas | Exhaust | Southwest | 220 | 09-18-2012 03:12 PM |
| First Malfunction? | Ishii Motors | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 06-09-2012 01:16 PM |
| FR-S as a relaxing cruise... | eriktherod | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-07-2012 09:44 PM |
| Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) — General Topics | 40 | 04-25-2012 12:20 PM |
