Old 10-01-2023, 11:03 PM   #15
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
It's a bitch to slide on there while under the car.
I used a torque solutions brand which is the same effect and ended up heating mine up in a pot of boiling water in a attempt to expand it a bit then greased it. Still put up a fight but eventually was able to get it on.
I did the front carrier bushing while I was under there as well. Adds a subtle NVH whine noise under certain conditions but shifts feel great. Noise was much worse with a short shifter before I uninstalled it. Having the carrier be more ridged makes shift engagement feel more solid. Doing the front + rear was more noticeable than just rear. I felt the rear bushing only on a friend's car before deciding what to do.
White line transmission insert also does a good job with slop but further adds some NVH. TRD/STi trans mount does a pretty good job doing essentially same thing with no added NVH.
Old 10-08-2023, 09:50 PM   #16
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Finally got the thing in. I used a heat gun and their lube. I couldn't get their bolts started so used a pair of these I had laying around. Much easier.
I suggested some kind of stamp on the bushing saying this end up and maybe an arrow pointing to the front of the car for orientation and additional instructions saying to lube and heat.
All in all, I fixed something that wasn't broke and I probably won't even feel the difference. LOL
Old 10-26-2023, 09:36 AM   #17
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
glad you got it..hmm maybe hole was smaller on yours? mine went in pretty well
did you also install other bushing while you are at bottom? both bushings will make so much difference
Old 10-26-2023, 11:22 AM   #18
blsfrs
blsfrs's Avatar
I used Cusco bushings on the front part. They went in without too much trouble. My old bushings were in pretty good shape so overall I didn't feel much difference.
FS: Energy Suspension Rack And Pinion Mount Bushing Set Jtrem Brakes, Suspension, Chassis 1 02-25-2018 11:04 PM
Energy Suspension front arm bushing kit Satanasso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 02-08-2017 08:56 AM
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 09:57 PM
Perrin Shifter Bushing rebranded Energy Suspension? BRZach Engine, Exhaust, Transmission 10 01-12-2016 02:17 PM
Whiteline transmission bushing and Perrin shifter bushing review. Superhatch Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-09-2012 08:40 PM
