Old 09-08-2023, 12:16 PM   #15
Ultramaroon
not playing cards
Ultramaroon's Avatar
it almost sounds like an rc car servo with some missing teeth...
Ah, but those are hard failures. If I get what you mean, that would be catastrophic in the EPS gearbox. Definitely not the issue here.
Old 09-11-2023, 10:58 AM   #16
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Another funny thing. When I jacked my car up to check the clutch problem, I found that my Tien Flex A's had completely "self lowered". Obviously, I didn't get the lock rings tight enough. Now I've got to find my notes on ride height and reset.
Maybe that will fix my noise. (After I replace the *&$#@ Act clutch.)
Old 09-11-2023, 12:42 PM   #17
RedReplicant
Drives: None
Your noise could be spring bind, it sounds different than what I've experienced but if you have someone turn the steering wheel while you put a finger on your coilover top hat you'd feel the vibration.
Also, brass punch to tighten collars.
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
blsfrs (09-11-2023)
Old 09-11-2023, 12:59 PM   #18
Ultramaroon
not playing cards
Does anyone use Loctite 222 on the collars? I've never used it for such large surface areas but from prior experience would think it's perfect here.
blsfrs (09-11-2023)
Old 09-11-2023, 01:48 PM   #19
RedReplicant
Drives: None
It might work, I just use Torrington bearings under the springs
They're cheap on McMaster. Bearing and two washers per coilover you want to put them on.
https://www.mcmaster.com/products/ne...rust-bearings/
blsfrs (09-11-2023)
Old 10-02-2023, 08:29 PM   #20
blsfrs
blsfrs's Avatar
The noise is mostly gone. I pulled the right front wheel off. The bearing felt good. The only thing I found were ridges on the outside edge of the rotor. My newer brake pads are apparently slightly wider that the previous set. The inside ridge was probably 1/16" wide and maybe a 32nd deep. The outside one was smaller. I ground them down flush with the rest of the rotor.
I occasionally hear a faint noise that goes away when I touch the brake.
Fingers crossed.
Creaking noise while turning WRITEX Issues | Warranty | Recalls / TSB 20 01-26-2020 05:25 PM
Noise when turning Autoenthusiastasm BRZ First-Gen (2012+) — General Topics 7 01-21-2019 10:14 PM
Hissing noise after turning off car Coop Issues | Warranty | Recalls / TSB 7 09-14-2018 01:28 PM
grumbling noise from front end when turning vramsaran Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-26-2016 07:29 PM
Here's a weird one...noise hours after turning off sa1126 Issues | Warranty | Recalls / TSB 12 10-12-2012 03:15 PM
