Old 09-08-2023, 01:20 AM   #15
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Originally Posted by e1_griego View Post
@Locust please share your washer fluid strategy.
Empty before every event and put it back in after. Takes less than 30 seconds to do each. You've all known this for a long time. I've had it measure at 2567 on the SCCA scales after 3rd runs. Could probably still knock another 20-40 off with seats, brake kit, and titanium header. I've added it all back on the driver this year though. Can't empty that as easily.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 09-08-2023, 01:59 AM   #16
Locust
Custom User Title
Locust's Avatar
Yeah I try to show up with >1/4 tank and I don’t waste any more energy thinking about it until I’m on my way home and deciding where I need to fill up so I’m not overly late to work on Monday.
Pretty much the goal for STX. 1/4 tank = sweet spot and if you end an event with the gas light coming on as you finish then you've hit it just right. For street I'd run it 1/8 tank.
Originally Posted by SCFD View Post
Trying to optimize the car based on fuel levels is probably highly dependent on the driver's skill and competition. You'd need to be a fast and consistent enough of driver for it to matter. Subjectively, I prefer how the car feels with a full tank compared to one near empty. Although every little bit of advantage adds up, I personally never felt my results would've changed due to the amount of fuel in my gas tank.
Have you tried changing some of your settings with a less full tank to see if you can get it to feel the same way? Not discounting your feel for the car at all but if you have the knobs available you probably can get it there.
Originally Posted by Autoxer62 View Post
Not all weight is created equal, your problem there is the wrong passenger. I had a friend that had a passenger seat in his EMod car to take "babes" (his term) for ride alongs, he said he went about a half second faster.
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 09-11-2023, 02:57 PM   #17
jcaserta
Drives: 2015 FR-S
Man if only I'd known this before nationals. How do you empty washer fluid in 30 seconds? I tried searching and came up with nothing. I guess the hose is accessible, or do you use a transfer pump of some kind?
Realistically I just keep it at the lowest level that barely registers on the bottom of the dipstick. That allows me to not mess with it and it's likely negligible weight, but if I need a quick spray there's some in there.
jcaserta is offline   Reply With Quote
Old 09-11-2023, 03:52 PM   #18
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
I started the super challenge on the low fuel light and ran the 3rd place runoff with the needle even with the red line. Zero issues. Even had enough gas to go and get more gas.
Autocross nut
AustinTX is offline   Reply With Quote
Old 09-11-2023, 04:19 PM   #19
jcaserta
Drives: 2015 FR-S
I added gas before sunday runs since the light was on but it didn't move the level. Then I added a bit more before the challenge, still reading below E. Then midway through the challenge added even more just in case. Even with that I was convinced I'd run out of gas at any moment, especially by the time I ran against you for 3rd place. Then added even more before my tuesday tnt runs, still no movement. Thankfully a little later on tuesday finally it updated. Over half a tank lol. So I ran nats (and I guess the challenge) with more gas. Oh well.
Now I'm wondering if my fuel gauge is wireless and it was reading your fuel level the whole time
Old 09-11-2023, 05:05 PM   #20
strat61caster
strat61caster's Avatar
We learned that lesson at Lincoln last year lol, renfield explained it, unless you throw about 3 gallons or more in the tank at once it doesn’t register as a fillup and keeps calculating fuel level based on consumption (I assume to minimize the needle bouncing around it rarely takes a real level reading). Guess it prevents getting a false level if parked on a hill or something? Idk. But yeah if you’re adding 1-2 gallons at a time the gauge will keep going down until you add about 3 gallons at once, might be able to get away with 2.5, I haven’t gotten scientific about it.
We panicked and did the same with an overfill halfway through the pro I think last year.
ineedyourdiddly
Old 09-11-2023, 05:09 PM   #21
steverife
Drives: 2016 Scion FRS
My gauge seems to pick up any addition of fuel. I've added half a gallon during challenges with the fuel light on and it turns off the light and moves the needle.
But I've talked to several others that will add 2 gallons, not move the needle off E, then add another 2 gallons, and find themselves at like 5/8th's of a tank.
steverife is offline   Reply With Quote
Old 09-11-2023, 06:03 PM   #22
foshjowler
Drives: 2022 BRZ; 2014 BRZ
The second gen has a similar response, you need 2-3 gallons for it to register anything. Haven't tried it yet in the first gen, but sounds like they probably use the same programing.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
foshjowler is offline   Reply With Quote
Old 09-11-2023, 09:52 PM   #23
Locust
Custom User Title
Locust's Avatar
The hose is clipped into the driver side fender under the hood. You can detach it easily at the back clip and feed it into a 1 gallon fuel container (be warned, though, that the overall capacity is above 1 gallon on these cars and is more like 1.4 gallons). After that just turn on your car and pull the lever back until you hear the pump noise change (it'll get louder and kind of higher pitched when it's an empty pump).
LOCUST
Instagram:
LocustAutoX
Sponsors:
The Following User Says Thank You to Locust For This Useful Post:
jcaserta (09-12-2023)
Old 09-11-2023, 09:59 PM   #24
Locust
Custom User Title
Locust's Avatar
It's definitely some kind of sloshing/uneven ground safety mechanism and it's a total trip running an event with the meter at negative quarter tank. You need to track your fuel consumption across an average 60s course. Once you hit the fuel light you have ~2 gallons and it won't re-adjust until you add 3 gallons. So if you add a gallon after every 3 runs you're usually good to go from there.
And to clarify - It's not an "at once" thing. You can add a gallon, take a run, add a gallon, take a run, and then add another gallon and it'll update. It has to come up a certain amount below the level it thinks its reading at before it'll believe itself. I haven't figured out what the trigger point for when this behavior kicks in is yet but it's at least below 3/4 and above 1/8 because you can throw in gas at near full and it'll update immediately.
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 09-12-2023, 09:20 AM   #25
foshjowler
Wonder if these cars are like the ND Miata where you can plug in an OBD dongle and get to the exact percentage the ECU reads. They otherwise act the same with 2 gallons left when the gas light comes on and don't register a fill up if it's less than a couple of gallons.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
Old 09-12-2023, 10:02 AM   #26
jcaserta
Drives: 2015 FR-S
Thanks! I knew that sometimes it wouldn't update if you put in only a gallon or two, but I've never left the light on long enough after that to see it actually go down to any significant degree. I always assumed it would just stay in one place and not go down further. Seeing the needle actually go down a bunch made me think that it really was reading. But what you're saying lines up.
I'll set up the fuel level PID in racecapture and at the next event try to determine if it's like the ND or not (where the dash is inaccurate but the obd signal is correct)
Old 09-12-2023, 11:10 AM   #27
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Yes, you can check live fuel level with an OBD2 reader.
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
jcaserta (09-13-2023), strat61caster (09-12-2023)
Old 09-12-2023, 01:04 PM   #28
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Well that explains a lot lol thanks
autoracer86 is offline   Reply With Quote
P0462 - Fuel Level Sensor TurboBRZ Issues | Warranty | Recalls / TSB 20 05-13-2019 09:04 PM
Fuel level Gauge swap. knopper91 Cosmetic Modification (Interior/Exterior/Lighting) 1 02-13-2016 12:58 PM
Remote Fuel Level Gauge pleong Electronics | Audio | NAV | Infotainment 5 08-21-2015 10:50 AM
Low fuel level and engine performance whatsinaname BRZ First-Gen (2012+) — General Topics 20 12-03-2013 01:55 PM
Fuel level GeeTee86 Issues | Warranty | Recalls / TSB 6 05-21-2013 06:57 AM
