Old 05-12-2023, 06:52 PM   #15
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Originally Posted by Breadman View Post
I actually went back and checked no my old engine since i just got my trucks oil back and i did have some. Id still recommend the heavier oil if you autocross tho
For sure I been running 5w-30 since I bought the car. See no reason not to...
autoracer86 is offline   Reply With Quote
Old 05-12-2023, 09:28 PM   #16
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I wouldn't overthink it. Keep collecting more data and watch for trends. API rated oil, proper oil temperature management, regular changes.
My car has used normal pedestrian 0W20 all its life (Castrol Edge). Over 135k miles, 30 track days, tracked all weathers (ambient temp >100F ), always 3-4 track days (~5 hrs of road course HPDE) per full 7500 mi interval.
EndlessAzure is offline   Reply With Quote
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
autoracer86 (05-13-2023), SCFD (05-13-2023)
Old 05-13-2023, 07:01 PM   #17
vindiesel
vindiesel's Avatar
Drives: 2023 brz limited 6mt red
My advice: don’t do oil analysis; willful ignorance in this regard will supersede any worries.
I argued with somebody in another forum about oil analysis. For the average consumer that doesn’t have a sponsored built turboed engine that is required to win races. I don’t see the point. Oh it shows I’m high in this or that. You going to rip the engine out? You going to black stone oil analysis your lawnmower too? I feel like this is a special automotive Fetish almost. I can’t wait to be at a car show and someone laminated their black stone oil report. Ha ha.
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles
vindiesel is offline   Reply With Quote
The Following User Says Thank You to vindiesel For This Useful Post:
Jdmjunkie (05-13-2023)
Old 05-13-2023, 08:56 PM   #18
soundman98
ProCrastinationConsultant
soundman98's Avatar
the idea with 'standard vehicle' oil testing is as to determine a pattern.
i wouldn't even recommend sending in every oil change. i would suggest sending in 3 at first to establish a common wear pattern, then 1 every 6-12 oil changes to verify the pattern is consistent.
but in either of these cases, we're not checking engine health so much as we're watching for symptoms of engine issues, so that the motor can be pulled and corrected before it becomes a major issue.
vehicles are some of the highest-priced pieces of equipment most of us own. like you said, we're not going to tear into the motor, so the UOA gives insight into the condition of the motor without opening it up.
it also gives indications on individual usage wear patterns, and how much oil life is left at the time of changing. for these cars not so much, but in large diesel motors that can take almost 50 quarts, UOA can easily pay for itself by adjusting maintenance intervals to get the most use out of the oil additives.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
autoracer86 (05-14-2023), NoHaveMSG (05-15-2023)
Oil Analysis - 1st oil change R L Newb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 375 11-19-2021 09:24 AM
Oil analysis JIM THEO Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 11-14-2018 06:42 PM
Analysis Paralysis athos56 BRZ First-Gen (2012+) — General Topics 98 10-08-2017 10:04 PM
Blackstone Oil analysis at 52k/45k/37k strat61caster Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 07-06-2017 12:26 PM
Used Oil Analysis @ 51k miles 8RZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 29 04-21-2017 07:35 PM
