Old 04-20-2023, 12:10 PM   #15
KillerBMotorsport
KillerBMotorsport's Avatar
Originally Posted by mav1178 View Post
unless you're doing UOA at every interval its not super important.
more important is regular maintenance as needed.
We do UOAs at every oil change and beat this thing like a rented mule, and have very good UOA results, because as you mentioned OCIs appropriate to usage is important.
KillerBMotorsport is offline   Reply With Quote
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
blsfrs (04-20-2023)
Old 04-20-2023, 01:37 PM   #16
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by KillerBMotorsport View Post
No. It's a fraction of what's remaining in the engine anyway.
7/19
blsfrs (04-20-2023)
Old 04-20-2023, 01:47 PM   #17
Ultramaroon
not playing cards
We tee in a drain valve, or if access is easy, just pull the lower line. OEM coolers tend to be more user friendly with a drain and decent access. Wish more aftermarket coolers did the same.
I have the big series-1 setrab. I hook up a fill hose and flush it with fresh oil until I see clean come out the return side.
blsfrs (04-20-2023)
Old 04-21-2023, 02:10 PM   #18
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I’m guessing this requires disconnecting both lines from the adapter plate. I applaud your dedication. I’d make a huge mess doing that.
I just run a version of the oem turbo engine cooler setup. It’s decently effective for my needs and it seems self draining.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
blsfrs (04-21-2023), Ultramaroon (04-21-2023)
Oil changes/Fumoto valve... CincyJohn BRZ Second-Gen (2022+) — General Topics 39 05-30-2022 09:48 PM
FS: Fumoto Valve w/ Lock byun Engine, Exhaust, Bolt-Ons 1 06-14-2016 12:03 AM
FS: Fumoto Valve jvenetto Engine, Exhaust, Bolt-Ons 6 10-01-2015 08:16 AM
Fumoto valve in the winter? Muskokan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 02-25-2014 01:06 PM
FS: Fumoto quick valve Laika Engine, Exhaust, Bolt-Ons 1 01-08-2013 02:51 PM
