Old 04-01-2023, 04:26 AM   #15
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
My current LCA’s are on spherical’s already and they are the least of my nvh issues.
haha that is fair Maybe I will open my mind to spherical parts when I start upgrading the suspension. Thanks
autoracer86 is offline   Reply With Quote
Old 04-03-2023, 08:30 AM   #16
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
Damn it I just installed KTA216A. Wish I knew about those before
MrSkubi is offline   Reply With Quote
The Following User Says Thank You to MrSkubi For This Useful Post:
norcalpb (04-03-2023)
Old 04-03-2023, 11:33 AM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
In the grand scheme of things, the sphericals on the LCA's are not really a big deal as far as NVH. I didn't really notice them when my car is more stock and I think the subframe bushings do a good job absorbing a lot of the NVH aftermarket suspension components generate. I saw in your other thread you are going to the whiteline subframe inserts, which may cause them to generate more NVH, I dunno for sure. I am on solid subframe bushings along with a bunch of other parts so "NVH" may as well be my car's middle name.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
autoracer86 (04-03-2023), norcalpb (04-03-2023)
Old 04-03-2023, 05:58 PM   #18
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
Me too. I ordered a set of these. I think I have someone already on the line to take the (literally) unused set of the KTA216a's.
RT-BRZ is offline   Reply With Quote
The Following User Says Thank You to RT-BRZ For This Useful Post:
MrSkubi (04-04-2023)
Old 04-03-2023, 06:07 PM   #19
autoracer86
Drives: Toyota GT86
Yeah that all makes sense to me. Thanks for the info !
The Following User Says Thank You to autoracer86 For This Useful Post:
NoHaveMSG (04-03-2023)
Old 04-03-2023, 06:09 PM   #20
norcalpb
norcalpb's Avatar
I always thought “pillow ball” was literally a ball sitting on pillows. I mean, how much more comfortable can it get than that! Learned that the pillows are a lie.
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
NoHaveMSG (04-03-2023), Racecomp Engineering (04-04-2023)
Old 04-03-2023, 08:12 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Threads are 16x1.5m, kind of an oddball. Threaded shank is 61mm long and bore center to end of shanks is approx 90mm. Bore is for 12mm bolt and is just under 43mm thick. Mostly posting this for my own posterity when I try to find a spherical that will fit.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Old 04-05-2023, 11:52 AM   #22
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Racecomp Engineering View Post
Be very sure that the poly joint rotates easily and doesn't bind after installing. I've had an issue in the past on a different part.
- Andrew
I got these in the other day and partially installed them on the car. I intentionally mounted the subframe side and just hit them with my impact like someone who doesn't know any better to see if the joint would bind and it doesn't. Doesn't rotate smoothly like a spherical, but isn't bound and moves properly.
Another side note, these are like twice as heavy as the RacerX arms they are replacing.
Racecomp Engineering (04-05-2023), RT-BRZ (04-05-2023)
Old 04-05-2023, 12:21 PM   #23
RT-BRZ
RT-BRZ's Avatar
I installed mine last night. I'm one of the dumba$$es that hit it with my impact but it's the baby Dewalt impact so it's not super strong. They don't bind in my case. You're correct that they are heavy and, compared to the KTA216A, they are considerably heavier. It's sprung weight so it doesn't matter, right?
Side note; those are my "storage and offseason" tires. I do track the car but if those babies are still good they are kept warm inside the house in the offseason.
Here's a pic:
The Following 3 Users Say Thank You to RT-BRZ For This Useful Post:
MrSkubi (04-06-2023), NoHaveMSG (04-05-2023), norcalpb (04-05-2023)
Old 04-05-2023, 05:47 PM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah I noted the Shaftworks coilovers so I figured
RT-BRZ (04-05-2023)
Whiteline IsaiahW Engine, Exhaust, Transmission 8 12-15-2021 06:38 PM
WTB: Whiteline LCA's Skurj Canada Classifieds 0 06-21-2017 06:11 PM
FS: Whiteline Rear sway bar endlinks, New Whiteline rear swaybar mount braces e1_griego Brakes, Suspension, Chassis 1 02-15-2017 12:00 PM
FS: Whiteline Positive Shift & Perrin Rear Shifter Bushing + Whiteline Front Diff Bus neilvosko Brakes, Suspension, Chassis 1 11-21-2016 02:44 PM
FS: Whiteline Rear Toe Arm/ Whiteline Rear Camber Adjust Kit Quanye Brakes, Suspension, Chassis 7 02-07-2016 01:55 PM
