Old 02-20-2023, 02:23 PM   #15
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Originally Posted by Turdinator View Post
That is very high, when I had the TRD springs with 1" spacers i didn't like the handling at all. I suspect it messes up the roll centers.
What i see is 2" spacer lift kits normally around here and reddit, I didn't think 1.5" was very high at all. Flatout coilovers can do 3". I'm also fitting larger 27" diameter all terrain tires too, so the spacer is for that extra clearance on top of the spring travel.
This isn't for rallycross or excitable driving, but more for the bad country roads and dirt roads/fields and overland.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 02-20-2023, 08:07 PM   #16
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Overlanding a BRZ is a pretty creative use of the platform.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 02-20-2023, 10:56 PM   #17
Spawn_Of_Creation
Human
Mostly when i go camping. A friend has 100 acers of forested area in east Texas. Nothing as heavy as rock crawling, but plenty of dips and ditches.
Old 02-20-2023, 11:15 PM   #18
Turdinator
Señor Member
Turdinator's Avatar
Makes sense what you're saying. I guess it just swung the compromise too far away from road manners for me.
Once you are done with your mods post some pics in the FRS/BRZ RALLY OR OFFROAD STYLE MEMBER COMPOLATION thread.
1974 TA22 Celica
2013 86 GT
Old 03-27-2023, 10:08 AM   #19
Racecomp Engineering
Update: I replaced the rear bumpstops with a Bilstein set that I had in the shop. It has a nice blue dustboot that goes with it and fits nicely on the shock. Yay for blue dustboots on Bilsteins!
They're 45mm in length, which is 12mm shorter than OEM rears (but remember rear motion ratio means more than 12mm of wheel travel gained before engagement). The big thing though is that the bumpstops are MUCH softer...OEM rear bumpstops are stiff as hell. Mega stiff. That's what was annoying me before so much.
Since cutting a bumpstop makes it firmer AND with the way the OEM rears sit on the dustboot you kinda need to keep the extra stiff portion...I just didn't really want to use a cut OEM rear bumpstop.
And yeah, it's a lot better! Very noticeable and positive improvement in ride quality and grip over bumpy/broken pavement, which is most of what I drive on. And that's with my switch back to my 17 inch summer tires at the same time.
It's much more what I was expecting from this spring and shock package. Simple, plenty of fun, and with a little bit of added height over OEM. Still firm for a "rally" set up, but this feels pretty good right now.
- Andrew
The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post:
bhmax (05-09-2023), Jdmjunkie (03-27-2023), RToyo86 (03-27-2023), SCFD (03-27-2023), Spawn_Of_Creation (03-27-2023)
Old 03-27-2023, 10:10 AM   #20
Also, I thought about but didn't modify the front bumpstop. The standard front internal Bilstein stops take up about 40% of the total travel and these rears about 39% of the total travel. That works. Factory is about 40% front and 50% rear, which is much more rear biased then most cars and plus that rear OEM bumper is so stiff.
The other option was the bumpstops we use with our RCE Yellow springs, which are 35mm in length but I didn't have any I could use laying around. Either way, the 45mm soft bumpstop makes sense for this application for protecting the shock and not being a damn hocky puck.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Old 03-27-2023, 10:39 AM   #21
Capt Spaulding
Persona Non Grata
Thanks. Looking forward to your thoughts on the setup on summer tires.
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Racecomp Engineering (03-27-2023)
Old 03-27-2023, 09:54 PM   #22
Turdinator
Señor Member
Turdinator's Avatar
- Andrew
Do you sell this bumpstop?
1974 TA22 Celica
2013 86 GT
Old 03-28-2023, 11:05 AM   #23
It does have a part number but I've never tried to get it separately. I'll check.
- Andrew
norcalpb (03-28-2023)
Old 04-10-2023, 10:14 PM   #24
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
You can also + size the tires on 17", or better yet 16", for that extra bit o cushion.
Old 04-11-2023, 12:39 AM   #25
Wangspeed
Wangspeed's Avatar
Drives: 2022 BRZ
As an alternative to the MCA traction mod, which is months on backorder, I went with the GP Sports version, which has built in subframe reinforcements in the front section, and a set of aluminum subframe inserts for the rear. The rear inserts are a bit of a problem for my 2022 BRZ, due to the swaybar mount, but I think I can work around it with adjustable endlinks.
dunno why the forum is rotating the photos. Doesn't normally do that...
You can see the change in mounting location in the last pic. The rear suspension feels a bit more compliant. I like the mod a lot for my setup.
Wangspeed is offline   Reply With Quote
The Following 2 Users Say Thank You to Wangspeed For This Useful Post:
bhmax (05-09-2023), norcalpb (04-12-2023)
Old 04-11-2023, 10:42 AM   #26
Attachment 219901
Attachment 219902
Attachment 219903
Looks nice!
Any increase in noise?
- Andrew
Old 04-11-2023, 11:19 PM   #27
Wangspeed
Wangspeed's Avatar
Drives: 2022 BRZ
Looks nice!
- Andrew
Minimal increase in noise. I actually think the only noise I heard was due to me torquing the nuts on the rubber bushings while at full droop. I forgot to compress first. It stopped after a few good compressions on the street.
norcalpb (04-12-2023), Racecomp Engineering (04-12-2023)
Old 04-13-2023, 12:57 AM   #28
norcalpb
norcalpb's Avatar
Looks nice!
- Andrew
What are your thoughts on relocating that trailing arm pickup point from the subframe to the chassis?
[SOLD] FS: New unused RCE yellows, Bilstein B6, Pedders top hats JAS4 Brakes, Suspension, Chassis 2 11-01-2022 02:43 PM
FS: Koni Yellows, TRD Springs, Pedders Top Mounts, Camber Bolts Muskoka800 Canada Classifieds 3 08-15-2022 10:32 AM
Pedders offset mounts alternitive? Ohio Enthusiast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 09-22-2021 10:04 AM
Pedders coilovers vs Eibach Lowered springs MechEngChristian AUSTRALIA 3 08-17-2020 03:29 AM
(Sold) Pedders Offset Top Mounts NIB beanswv17 Brakes, Suspension, Chassis 3 07-16-2020 10:01 PM
