Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 08-01-2020, 03:12 AM   #1
MechEngChristian
Drives: 2020 BRZ
Question Pedders coilovers vs Eibach Lowered springs
Hi Everyone,
I'm in two minds between Pedders XA coilovers for my 2020 BRZ or Eibach Lowered springs. Has anyone fitted the Pedders coilovers or Eibach springs to their street car?
MechEngChristian is offline   Reply With Quote
Old 08-10-2020, 06:35 AM   #2
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
Depends what you want to do.. if you want bigger/wider wheels you’ll need coilovers to give you camber once you get past 18x8.5” +38, using Rays anyway. Having said that if you want bigger wheels on the rear you’ll need adjustable LCA’s anyway.
I’ve had Eibachs and they were fine for just dropping the cars height And being a bit firmer, and they work fine with the OEM shocks. I’ve now had the MCA Blues and currently have the MCA Reds. Probably overkill in my situ but why not if you can.
Bodalenko is offline   Reply With Quote
Old 08-11-2020, 10:02 AM   #3
MechEngChristian
Drives: 2020 BRZ
Thanks heaps for the info Steve much appreciated mate. I do want to lower the car, just to close up the wheel/fender clearance a bit, which the springs would do, but also think like the option to go to a wheel wider than 8.5 in the future would be a good idea. How is the ride quality on the MCA's? Are they a super stiff ride?
Old 08-17-2020, 02:29 AM   #4
Bodalenko
Steve Bodalenko
The Reds are very much a track coilover BUT you can tune them, via spring choice and valve via a screw on top, to be a softer ride and they are fine for DD..
SOLD! Eibach Multipro R1 Coilovers with Extra Springs tws98 Brakes, Suspension, Chassis 3 08-25-2018 01:36 PM
HKS Hipermax SP Coilovers, Superpro Rear Endlinks, Eibach 450 lb/in Springs jonesy Brakes, Suspension, Chassis 2 08-25-2017 10:39 AM
Eibach R1 coilovers and RCE Yellow springs for sale!! jason t Canada Classifieds 1 12-03-2013 01:48 PM
FS: Eibach R1 coilovers and RCE Yellow springs jason t Brakes, Suspension, Chassis 3 11-27-2013 08:04 PM
New Pedders Coilovers for the BRZ and FR-S! RallySport Direct Brakes, Suspension, Chassis 4 06-11-2013 05:42 PM
