Old 01-05-2023, 01:00 PM   #15
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
The biggest I have ever seen fit the stock body is 18x10 +40 on 285/30s square. It requires replacement of all suspension control arms. Here is the thread:
https://www.ft86club.com/forums/showthread.php?t=122384
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
SCFD (01-05-2023)
Old 01-08-2023, 01:51 PM   #16
traffic335
Here is what I think I will try for the first part of the track season. Hoping to get the offsets correct and get an aggressive rear roll/pull. Please chime in if you think I will have any problems. Going for a square setup.
Fronts - Todoroki +30mm bolt on front fenders.
Wheel: 18x10 +40
Tire: Pirelli DH 265/645/18
Rear - Rolled, Pulled
Wheel: 18x10 +40
The section width of the Pirelli seems to be 10.7" - Which is around 272mm
I am also curious if I could step up to the DH 275/645/18 which has a section width of 11" - 279.4mm, but may not know until I experiment with a set and dial in the fenders.
traffic335 is offline   Reply With Quote
Old 01-10-2023, 12:20 AM   #17
Icecreamtruk
Drives: Track preped NA FRS
Originally Posted by traffic335 View Post
Great find on the ESRs. That is right in the ballpark of what I was looking for and it's hard to deny that price. Did you happen to weigh them?
I did, I think 22 or 23lbs for the 18x10.5, which is on par with other flow formed wheels on that size.
Old 01-10-2023, 12:22 AM   #18
Icecreamtruk
Wheel: 18x10 +40
Wheel: 18x10 +40
Front will fit for sure. I fit 275s with 10 to 11 section width on victory fenders which are only +25mm wider. It will be tight but it should fit. The rears, Im on rocket bunny copies that are around 2" wider, using +20 offset and 10mm spacers, so around +10 and it fits fine with still some room, so I think a +40 wheel of the same size will clear OEM fenders if rolled.
Old 01-10-2023, 11:09 AM   #19
traffic335
I was looking into this further and comparing sections widths with what people have reported with the Victory Function and Todoroki fenders. I may be able to step up to a 285/645/18 DH Slick it seems like (11.7" section width). I am aiming to not cut the rear, but I am fine with a heavy roll. It's going to be close, but I think I am going to give it a shot. The Todoroki is advertised as a +30mm, but I'm not really sure if it is any more usable than the VF. I plan to remove the side markers no matter what.
The Following User Says Thank You to traffic335 For This Useful Post:
Icecreamtruk (01-13-2023)
Old 01-12-2023, 09:53 PM   #20
traffic335
I had an extra set of 27/65/18s, so I had them mounted for fitment to size up what I'm working with. Stock body before new front fenders and rolling the rear. It appears I will be able to run a 285/645/18 Pirelli DH Slick. I was surprised that I seem to have extra space in the rear to run more of an offset to cover the tire.
The Following 3 Users Say Thank You to traffic335 For This Useful Post:
Icecreamtruk (01-13-2023), Jdmjunkie (01-12-2023), SCFD (01-13-2023)
FS: Konig torch wheels on slicks georgiafrsguy Wheels and Tires 17 12-13-2022 06:53 PM
DOT "slicks" vs real slicks Captain Snooze Tracking / Autocross / HPDE / Drifting 8 07-03-2017 02:14 AM
WA: Seattle - Perrin Power Package! 3" Cat back, CAI and Inlet package! pik1111 Engine, Exhaust, Bolt-Ons 2 04-20-2017 01:51 PM
TSW Wheels 17" 18" Nurburing + Interlagos and More (Wheel+Tire Package Available) MIKE@MRTIRESOLUTIONS Wheels and Tires 0 12-20-2012 06:12 PM
