Old 12-07-2022, 01:26 PM   #15
Ultramaroon
not playing cards
Ultramaroon's Avatar
"Now cough ...
Again ... "
Am I dying?
Old 12-07-2022, 02:11 PM   #16
Am I dying?
Yes. We all are
soundman98 (12-07-2022)
Old 12-07-2022, 02:12 PM   #17
Ultramaroon
not playing cards
Yes. We all are
Old 12-07-2022, 08:19 PM   #18
soundman98
ProCrastinationConsultant
soundman98's Avatar
Yes. We all are
some of us slower than others
Old 12-08-2022, 05:33 PM   #19
blakkoutdarko
blakkoutdarko's Avatar
Drives: 2017 Toyota 86 (Raven)
Originally Posted by Falkon240 View Post
From what I can see, none of those things on the OFT indicate there's a problem.
I think the better question, is why are you asking if it's healthy? Is it characteristically doing something wrong? CEL? Running rough? Weird sounds?
If not, a compression test and oil analysis will tell you more.
No, it’s not running rough or anything but when I first tuned it to the stage 2+ tune the car felt a little more snappier. But when I look at it that was when I still was running stock tires and wheels. Now I’m running Rays Gram Lights 17x9 38+ and Falken Azenis 245/240ZR17. But I did my last oil change less than 3k miles ago and it’s so clear it’s hard to see on the dipstick lol
blakkoutdarko is offline   Reply With Quote
Old 12-08-2022, 05:37 PM   #20
blakkoutdarko
Uhh... Advance multiplier is 0. That seems bad. You normally want that at 1. (Edit, unless the tune has IAM set to 0, but that seems odd for an OFT tune)
OP, take a log and post it to datazap or something. Screenshots don't actually tell anyone much of anything.
Also an oil analysis will tell you how the hardware inside the engine is doing.
Edit:. Wow, how'd you screenshot stft at 0? That's normally all over the place.
I mean it was at idle, should I reconnect it to the OBD2 and drive for a bit then look to see where it is? I’ll definitely look into this as I wanna have the car for as long as possible.
Old 12-08-2022, 08:14 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It doesn't matter. Depending on tune it should default to an IAM of 1, or .7 if it is a V4 tune. Do you know what you flashed your car with and what your calid is? It sounds like an issue with the tune though the car runs fine, it is just not logging correctly. It's in the thread @Spuds linked. Read the responses by steve99.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Spuds (12-08-2022)
Old 12-08-2022, 11:54 PM   #22
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I'm going to start with basic info, apologies if this is stuff you already know.
So, the OFT has software that allows it to interpret the 1s and 0s coming across the CAN bus. Not all BRZ/FRS/86 ECUs speak the same language across that bus, even though they use the same interface. ECUs in different regions and different model years have different CALIDs. The CALID determines, among other things, how messages are sent across the CAN bus. Example: If the CAN bus were a book, the CALID would determine whether it is written in English, French, or Spanish. The OFT is supposed to be able to read from any CALID for the twins, but it needs to know what language it it reading first.
This is important to know because there might be an error with one of the CALIDs in the OFT. Particularly if the OFT doesn't have the latest updates from openflash. It's essentially missing a word from it's vocabulary in one specific language. I think a lot of these were fixed over the first few years, but the OFT may need to be updated to get those fixes.
Step 1 is to find the CALID for your car. The OFT should be able to tell you that from the vehicle information(?) screen. My car is in pieces right now so I don't know the menu exactly.
Step 2 is to find out if there are any known issues with that CALID and confirm the OFT is using the right one. My guess is yes and yes, but weird stuff can happen.
Step 3, if step 2 checks out, connect the oft to a computer connected to the internet, then open the "openflash manager" software. You can get it from the openflash website last I checked. This should update your OFT software if you let it sit for a while.
Step 4, is to plug it back into the car and see if that fixed anything.
Once you are able to do that, let us know how it went. Good rule of thumb, advance multiplier should be 1 or 0.7 at first, or at least not 0. There may be further steps needed to get your OFT all set up. Once it is fully set up, we can help you interpret the readout and logs.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
NoHaveMSG (12-10-2022), soundman98 (12-09-2022)
Old 12-09-2022, 02:27 PM   #23
jflogerzi
jflogerzi's Avatar
Also to take a log at Full WOT and some driving logs. Look for bad AFR's, Knock corrections alot, Falling IAM Value. Use this app to read the Log. All this can be done on the OFT
https://datazap.me/
2013 Series 10 FRS #553
Old 12-09-2022, 03:27 PM   #24
Sasquachulator
Pavement Grey
Am I dying?
Did you get the jab?
Old 12-09-2022, 03:32 PM   #25
Ultramaroon
not playing cards
soundman98 (12-09-2022), Spuds (12-10-2022)
Old 12-10-2022, 12:29 AM   #26
Spuds
The Dictater
Spuds's Avatar
https://datazap.me/
Those were going to be my follow on steps once OP has the updated software. First order of business is to make sure the software is reading right. Logs are useless if you aren't logging the right parameters.
Is this a healthy log? D00C cookiesowns Software Tuning 3 08-26-2014 04:39 AM
Is she healthy, log. OFT v86 Software Tuning 7 08-18-2014 08:29 PM
◙◙◙ The "Keep Your Car Running Healthy" Thread | Real Auto Dynamics ◙◙◙ Kevin@RAD Announcements, Contests, Giveaways 36 06-07-2013 02:26 PM
